Question about Garden
I'm looking to buy a flymo XLT2000+ Grass trimmer but i have no idea what is the engine size on that make.PLZ help how big is the engine
5 Suggested Answers
  • 246 Answers
SOURCE: no user manual
Hello:
Most 2 Cycle Engines use a 32:1 or 40:1 Fuel Mix Ratio.
The Newer 2 Cycle Engines use a 40:1 or 50:1 Fuel Ratio.
For Better Performance and to be sure you have Plenty of Oil to the Engines Internal Components, I Suggest (and I Use) a 32:1 Ratio in All my Equipment except for Post Hole Diggers.
Post Hole Diggers Use a 25:1 Fuel Ratio.
Hope this Helps.
Good Luck
Respectfully
John
Posted on May 10, 2009
rycgl
  • 1545 Answers
SOURCE: how to put together a black n decker grass
No, it is not heavy duty enough to drive a blade. It should have cuttting line in it and it only can use up to .065" string (factory recommended).
Posted on Oct 12, 2010
  • 144 Answers
SOURCE: when my flymo lite 250 engine is running the end does not turn to cut the grass
Could be anything from a stripped drive shaft to a loose or stripped trimmer head. You'll probably need to take it to a repair shop to have them diagnose the problem and locate the replacement parts if it's anything other than a stripped trimmer head bolt.
Posted on Nov 03, 2011
Why would my Flymo grass trimmer Contour 700 stop working
used to have one ... tossed it in the bin
check
sealed plug
orange lead for broken insulation
electric on off safety switch
if the motor starter winding worn out
Sep 11, 2016 | Garden
My Flymo Contour 700 stopped working when in use how do I get it to work again
check its safe to keep using
an electrician or flymo service center to check it all over
What do i need for replacement string? Can i go heavier or stay with the smaller string? This is for mastercraft 20v grass trimmer. thanks
the size of the string is critical in electric driven trimmers
it does have mass and the thicker string will over load the motor
stay with the recommended string size and keep to the recommended distance to the grass being cut
string line cutters work on the principle that the tip speed of the string is what does the cutting and that means that the first 1/2" of string cuts the grass
the rest back to the hub acts like a brake as it is dragged across the grass and slows the cutting speed and loads the motor
remember that the machine is designed to trim edges and not to cut down growth-- that is a job for heavier duty units
May 13, 2016 | Garden
When my flymo lite 250 engine is running the end does not turn to cut the grass
Nov 01, 2011 | Homelite Mighty Lite Lawn Trimmer
I have a Black & Decker 12v, 12" cordless trimmer (CST2000). The charger is missing. Can I buy a replacement? Is there a part number?
Do a random Google search for your model and maybe even serial number and you will find what you are looking for.
Aug 30, 2010 | Black & Decker Cst2000 12 - Volt Cordless...
Spool cover required for hg500b grass trimmer
Hi, mine broke yesterday (Sovereign HG500B Grass Trimmer). I took the grass trimmer to Homebase but they've told me that this model has been discontinued and they don't sell spare parts for it. I believe it's still within the guarantee period so if I can find the reciept they'll organise some sort of replacement, but if I can find somewhere that sells a replacement spool cover I'd rather just buy that and replace it...so far no luck.
Aug 04, 2010 | Garden
Replacement line for grass trimmer
Where do I find line for my cordless lawn trimmer spectrum 60-2270-0 12 v
Jul 28, 2010 | Garden
What replacement line do I buy and how do I replace it?
Hello, W/D here.
There are a variety of sizes. Pull your spool off and where the notches are at the bottom ogf the spool are the sizes that your trimmer and spool can use. It'll read in decimals, like .050, .089, etc.
Best regards, W/D
Aug 16, 2009 | Black & Decker 14" Grass Hog Xp...
No user manual
Hello:
Hope this Helps.
Good Luck
Respectfully
John
May 10, 2009 | Garden
Lack of information before purchase
Hi. I think I can put your mind at rest.  I work in a Flymo service agency. The Flymo Contour Cordless Power Plus has a guide wheel for accurate edging but, in common with all other Flymo edgers and trimmers, the actual cutting is done by a whirling thin (1.5mm) plastic cord that is designed to wear out and is fed from a replaceable reel under the cutter shield.  The only risk in cutting up to stone, concrete or other hard material is rapid wear of the plastic cord.  Unless your step is made of exceptionally soft stone there is no reason to think that the step will be damaged at all.
Good luck.  If this helps, please rate my response.
Apr 14, 2009 | Vacuums
Garden Logo
15 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
