Question about Kustom KPM4080 80 Watt Powered Mixer
The power lite comes on but it will not work on any channel
No audio from main speakon outputs A and B
Hi, I think in most amps switching to bridge mode simply means the amp supplies its total power through the left channel only. It's the best way to use all of your amp's power but nothing comes out of the right channel. Having speakers connected to both channels would simply mean that only the Left channel works, it would not blow it. Some amps have the speakers wired to binding posts and this varies according to whether you want mono, stereo or bridged. I can't help with the power board sorry
Apr 07, 2014 | Behringer Pmp3000 16 Channel Audio Mixer
No sound coming from my power amplifier gemini xga-4000
I have a Gemini xga 4000 that only channel 2 works fine but channel 1 is very very low .......
Jan 09, 2014 | Gemini Sound Products GEMINI XGA 4000 4000...
I have a Peavey amp but no sound is coming out?
Bad output transistors or bad Soldier joint in output section
Nov 26, 2013 | Peavey Xr 8600 8 Channel Powered Mixer
Power light comes on but individual mute and channel lights are not working . No sound outputting.
This is likely a power supply failure within the unit. Needs to go to a shop for repair.
Sep 20, 2011 | Samson S Phone 4 Channel Headphone...
There is no sounds coming out of the left channel
Assuming your PAN controls are centered at 12 o'clock, likely one of the power amps has failed. There is a design weakness in insulation on the circuit board of channel A that often fries three to 5 transistors and a Zener diode and sometimes a metering resistor. The board gets charred and requires a lot of work to carve out the cancer and restore the insulation and circuit traces. If the problem persists and one continues to use it, sometimes further arcing will destroy the power supply as well.
Nov 10, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Fender Concert II preamp is faint and distorted on 2 channel
It sounds like a job for a technician. There are high voltages in the chasis and the potential for a serious shock to the unwary.
That said, I can suggest several possibilities.
First, make sure the controls aren't causing the problem. Contacts can build up dirt and oxides and block the signal. Try twiddling the controls and see if the problem comes and goes, or if you hear scratchy noises. If symptoms are found, buy a contact cleaner spray, take out the chasis after unplugging and letting it set for an hour, being very careful not to touch any exposed conductors inside. You'll see some holes in the control bodies; squirt cleaner for 2-5 seconds and work the controls.
Also see if the problem happens without the footswitch, and try the channel switches several times - same problem, dirt and oxidation.
Other possibilities - cathode bypass capacitors drying up, and it looks like the amp uses some opto-couplers at various stages.
Nov 09, 2009 | Fender Hot Rod Deluxe Guitar Combo...
Psr-60 serial no 008012
Yamaha PSR 60. Power light comes on but no sound from any of the keys or anything else. Can anyone advise
Jul 28, 2009 | Yamaha Portable Keyboard
SPEAKER OUTPUT CHANNEL FAULTY, TWO MIKE CHANNELS DOWN
These are a real pain to open. You have to remove the front panel to remove a shield to remove the back amplifier power supply area. The power supply is a switching type and has lethal voltages present. Working on this should be done using an isolation transformer. With your symptoms, it is likely one side of the power amp MAY be blown, but do check that the wiring hasn't fallen off and the jack itself. Two pairs of wires come from the power amp to the front panel jacks. document location of ALL the cables you disconnect as they CAN be confusing to restore.
May 13, 2009 | Fender Passport Deluxe 500watt Sound...
Kustom KPM4080 80 Watt Powered Mixer Logo
15 people viewed this question
Top Kustom Music Experts
Torashi
Level 1 Expert
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Kustom Music Expert? Answer questions, earn points and help others
