Question about Refrigerators
KIC Supercool Fridge Freezer Temp. control. At what setting should the temp. dial be set for warmest in the fridge
4 Suggested Answers
meBNme
  • 334 Answers
SOURCE: fridge too cold
The temp sensor or the thermostat is bad.
It is reccomended that the sensor be replaced whenever a T-stat is replaced.
You can purchace both for less than 50 bucks with most models at your local appliance parts warehouse.
(The T-stat is the part that you turn up or down to adjust temp and the sensor is the wire coming off of it to a remote location in the fridge. With some models it is all one part, with others the sensor can be removed seperatly.)
Posted on Dec 30, 2008
bobicehouse
  • 1524 Answers
SOURCE: Freezer -5 Fridge 50
You have a defrost problem. Refrigerator gets cold via freezer. If blocked with frost, will restrict cold air into refrigerator.
Posted on Apr 26, 2009
flamingsk689
  • 5 Answers
SOURCE: LG fridge freezer gwl227ybqa soft touch controls
with all five bars lit up it be at its coldest and vice versa when one bar is lit it will be at its warmest
Posted on Oct 07, 2011
Kic fridge not cutting out,whats the solution?
probably a thermostat not working correctly
could also be door seals not sealing properly
could be cabinet temp setting too low and the unit is struggling to get the temp down that low
fridge temp is between +3 -7 degrees c and the freezer up to -15 degrees c
check your setting on the control
Jan 21, 2016 | Refrigerators
My fridge keeps freezing how do i change the temp settings
Hi!!
You didn't mentioned brand and model of your fridge, so I will give you a general answer.
Usually the controls are in the fridge compartment, either on the right or back upper wall. Usually is one control for the freezer and another for the fridge. The normal settings should be about 1/3 of the dial's range, ie. If dial have 9 numbers, the setting should be between 3 and 4, depending on use and outside temp.
Wait 24 hrs. between adjustments to allow the system to stabilize.
.NOTE:
The Freezer Temp. Dial is the main temp. controller, if you set it too low, it may not have time to cool fridge side properly.
Good Luck!! Don't forget to rate this post!!!
Aug 03, 2010 | Refrigerators
Fridge of my Hotpoint FFA90 fridge-freezer freezes
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Mar 11, 2010 | Hotpoint FFA90 Bottom Freezer Refrigerator
Vegetables kept out of the crisper drawer feeze up why does this happen even the temperature control is set below 1 on the dial
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Sep 19, 2009 | Refrigerators
GE Profile GSS25LGMB
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 05, 2009 | GE GSS25LGM Side by Side Refrigerator
My performa refrigerator,on top,of unit is freezing all the food .where should the dial be set?
The fridge section shouldn't ever freeze anything.
Sep 02, 2009 | Maytag Performa PAV2200
Apr 26, 2009 | Refrigerators
Dial goes from 1 to 5 in fridge, what is correct setting
1 is warmest and 5 is coldest. set to 3 and just see if that gives you a reasonable temperature. fridge temp should be about +4degC and freezer temp about -18degC
Sep 05, 2008 | Refrigerators
Refrigerators Logo
237 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
