SOURCE: distributor settings for a 1969 grand pre?
Hi
I believe the points setting is around 0.016'' for these engines.
Very best regards
Geordie
SOURCE: 1969 pontiac firebird oil pan.
you can take the oil pan off by just undoing the bolts just lift the car up then since it is just pin holes you can probly just spot weld them or maybe use a high streangth solder
SOURCE: trying to find info on my 2003 pontiac bonneville
Model: 2HX69 -2003 BONNEVILLE SE SEDAN
Gross Vehicle Weight Rating: 2073 kg (4571 lb)
Build Date: 07/26/2002
OPTION CODES
AG1 - 6-WAY POWER DRIVER SEAT
AK5 - DUAL FRONTAL AIR BAGS
AS7 - SEATS, CLOTH BUCKET
AU0 - REMOTE KEYLESS ENTRY
B0M - VEHICLE GM PROD WEEK 30
C67 - AIR CONDITIONER WITH ELECTRONIC CONTROLS
DG7 - DUAL POWER SPORT MIRRORS
DH6 - ILLUM VISOR VANITY MIRRORS
D55 – CONSOLE
FE1 - SUSPENSION SYSTEM, SOFT
FE9 - 50-STATE EMISSIONS
FLT - FLT-FLEET ORDERS
FQ3 - AXLE RATIO 2.86
IHB - TRIM INTERIOR DESIGN
JL9 - ANTILOCK BRAKES - 4 WHEEL DISC
KCV - FLT-ALAMO RENT A CAR
K68 - GENERATOR 105 AMP
L36 - 3.8 LITER 3800 SERIES II V-6
MN3 - TRANSMISSION, AUTOMATIC 4-SPEED
MX0 - 4-SPEED AUTOMATIC TRANSMISSION
NK5 - STEERING WHEEL, STANDARD
NT9 - FEDERAL EMISSION SYSTEM
ORN - PLANT CODE ORION, MI
PF5 - WHEELS, 16" PAINTED ALUMINUM
QNX - P225/60R16 BSW STL TOURING
R6F - IDENTIFY B CODE USERS
R8M - AVIS/NATIONAL RAC TRACKING CODE
T43 - REAR DECKLID SPOILER
UA6 - THEFT DETERRENT SYSTEM
UB3 - RALLY GAGES W/TACHOMETER
UV7 - ANTENNA, REAR WINDOW
UW6 - 6-SPEAKER SOUND SYSTEM
U1Q - RADIO, AM/FM WITH CASSETTE, CD AND PROGRAMMABLE EQUALIZER (REPLACES STD/OPT PKG RADIO)
U2J - DELETE XM SATELLITE RADIO
VM4 - BUMPER STD IMPACT,FRT 5, RR 2.5
VN9 - DAILY RENTAL REPURCHASE PROGRAM
V2G - CREDIT IN LIEU OF FUEL
V73 - VEHICLE CERTIFICATION U.S.
1SB - OPTION GROUP - 1SB
1SZ - HEAT AND SEAT DISCOUNT
54U - LIGHT BRONZEMIST METALLIC
56B - TRIM, TAUPE
56I - TRIM, TAUPE
6DK - COMPONENT FRT LH COMPUT SEL SUS
7DK - COMPONENT FRT RH COMPUT SEL SUS
8CM - COMPONENT RR LH COMPUT SEL SUS
9CM - COMPONENT RR RH COMPUT SEL SUS
SOURCE: engine harness diagram for a 1979 pontiac 400
I need to put the steering wheel back together on my 78 Trans Am
SOURCE: 1967 PONTIAC 400 cu.in. ENGINE-What is the right
Pretty skimpy info there toolbox. Which engine do you have?
In 1967 Pontiac made 326, 400, and 421 engines. They all have the same main bearing size, 3.00 inches, rod size, 2.250 inches and the same stroke, 3.750 inches.
In 75, they only made the 400 and 455. The 75 400 uses the same crank but the 455 uses the same rod size but a larger 3.250 main, and 4.210 stroke.
So any year 400 crank will fit any other year 400, 389, or 350.
Google Kauffman Racing, Wallace Racing or Pontiac Dude.
Cheers
Matt
