Question about Android Apps
I have a internet stick on my Samson flat screen tv. added Hughes satalite for good speed. I added an extender also.
I have internet tv stick. Added Hughes Sat for good speed. Added extender and still no Netflix without buffering. Photo is of extender
  • 22 Answers
Can you run netflix on a computer without buffering? It might be your internet connection. Usually Netflix will lower the quality of the picture to avoid buffering and will increase in quality when the internet picks up. Netflix also uses different software depending wether it's computer (Microsoft silver light), a gaming console, or a smart tv in your case.
I’m happy to help further over the phone at https://www.6ya.com/expert/tarik_f88885a87e319a0d
Posted on Oct 17, 2013
I upgrade to 200 pro with 400mb but my hughes net meter to be the same as before. my downlowable time remain the same.
Speeds (uploading and downloading) may vary based on several factors such equipment, line-of-sight (dish to satellite), your Internet package, other users, and FAIR USAGE POLICY. Have pasted the fine details below.
*Speeds
Speed comparison based on 53 Kbps dialup. Actual speeds may vary. Uninterrupted use of service and speeds are not guaranteed. Usage is subject to the Fair Access Policy. Listed speeds are available only through Hughes' SpaceWay satellite. Most subscribers will have access to the listed speeds.
The Power 200 service plan is only available through the new HughesNet satellite. Approximately 1% will not be able to receive the Power 200 plan as a result of trees or other obstacles that block the signal from the satellite to the home.
Actual upload speed will normally be lower than speeds indicated during peak hours. Download speeds may also be temporarily slowed in cases when patterns of system usage exceed the download threshold for an extended period of time. See the HughesNet Fair Access Policy for more information.
**Download Threshold
Each plan is subject to a daily download threshold as follows: Basic 200 MB, Power 150 300 MB, Power 200 400 MB. 50 MB per day additional Download Allowance can be added to any plan for just $10 per month.
+Equipment
Provided HughesNet equipment may be new or refurbished. Any refurbished equipment will have the same warranty as new equipment. In the event that you elect the purchase option, and the equipment installed at your location is refurbished, we will provide you with a $25 credit on your first Service invoice.
www.nationwidesatellite.com/HughesNet/service_plans/HughesNet_plans.asp
The speed difference between their packages is only 50Kbs. May be difficult to read. May wish to use third party Internet speed rater - www.speakeasy.net/speedtest/
Apr 01, 2011 | Computers & Internet
I have a mitsubishi flat panel tv, model # LT40133, serial #109250, it has a faulty lcd panel, purchase date was 2/28/2008 - service technicion informed me that this is a model that had the warranty...
The extended warranty was only an additional year added on to the original from date of purchase. Since that is the case your extended warranty expired 2/28/2010. The panel is part number 289P101010 and is around $1700. Call Mitsubishi and see if they will cover your panel..
Sep 08, 2010 | Mitsubishi Televison & Video
The tv turns itself off after 5 minutes being turned on
There can be several causes for this, few of which you can do anything about. However, a few things to try.
1) Replace the batteries on your remote control.
2) Try resetting the logic functions on your tv by unplugging it for a minute, then plugging it back in.
3) Try covering up the infra-red receptor on the front of your TV to see if you're getting unwanted signals from the receptor. taping a piece of foil over that area is perfect. If it doesn't stop after doing these two things you'll probably need to take it to a shop.
4) If this does stop it, then look for unexpected signal sources. Have you added a remote control extender? Added a new device to your audio-video system? Changed to a new remote?
Good luck with your problem...I hope you can work it out.
Mar 28, 2010 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
My sk-26h730s turns itself off and on and turns its volume up all by itself. HELP before I take this thing out and shoot it!
Mar 21, 2010 | Westinghouse Electric SK-26H730S 26 in....
Powers off by itself in summer turns right back on when you push the power button
Mar 20, 2010 | Olevia LT26HVX 26 in. LCD Television
Tv when turned on turns itself to off until left for about an hour then unplugged then turned on again, the tv is a Philips plasma
Feb 28, 2010 | Philips 42 in. Plasma TV
Westinghouse tv turns off by itself
There can be several causes for this, few of which you can do anything about. However, a few things to try:
I hope this helps. Joe
Jan 19, 2010 | Westinghouse 26" LCD Flat-Panel HDTV
Cant hook up
ok... so im guessing your using sat for internet, so you would set one plug with zyxel PL-100 and it sending signal in, while adding zyxel PL-100 a computer works, and another craps out... Solution: use a router
insert satalite into wan port, set up router
run a client wire from the router to a zyxel PL-100
and the others should pick up off that one..
like so.. :direct from zyxel website specific for pl-100
http://www.zyxel.com/upload/images/app_diagram/app_pl100_550x0.gif
Apr 22, 2009 | Computers & Internet
I have a hughes hrmc-11 remote control and i have a proscan flat screen tv i was wondering if there is a code so i can use the hughes remote to ctrol my tv
auto code search.
hold down the tv button and mute button until the tv button light stays on. press the channel up button(this will cycle thru codes) test with the power button. process may take a few minutes. when the tv turns of press the tv button to store code
Jan 02, 2009 | Hughes HRMC11 Remote Control
Android Apps Logo
147 people viewed this question
Top Apps Experts
Brett Duxbury
Brett Duxbury
Are you an App Expert? Answer questions, earn points and help others
