Question about iLO (2 GB) MP3 Player
Help what do i do if the comp wont recognize it?
  • 8,596 Answers
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on Jul 05, 2008
Iwave video mp3 player wont turn on
well it depends did you download it cause if you did that could also probably be why its saying it wont reconize
Apr 23, 2010 | Audio Players & Recorders
My go gear mp3 wont even turn on and its not recognized by my comp. what can i do to fix it
Hi you need to make sure you have charged the player, does it light up when charger is plugged in??
PC will not recognize the player unless it is powered up.
Apr 06, 2010 | Philips GoGear HDD6330 MP3 Player
USB wont connect garmin to comp
usb doesn't need to be connected to both inputs just try one or the other
Jan 13, 2009 | Garmin nuvi 250 GPS Receiver
Frozen and my comp wont recognize my dj
Hold pause down, press reset button with paperclip (in the little hole on left side), then choose clean up, then select reboot. It will reload your library and it wont erase your files try it, I did and it worked fine after that.
Sep 16, 2008 | Dell DJ MP3 Player
Cannot boot into windows.
Try putting the jumper on your drive to CS (cable select) and make sure your hard drive is located at the end of the ribbon cable. This is assuming you are using a 80-conductor cable and not 40. If you happen to be using a 40-conductor cable (unlikely) make sure its on the middle of the ribbon cable. See if this works.
Jan 20, 2008 | Asrock P4VM800 Socket478/SAT/A&V&L/Modem...
My computer doesn't recognize my Sansa E200
Make sure player's usb menu is set to MSC, so computer will recognize it. Not sure why, but sometimes it helps to try another usb port on the computer. Good luck.
Dec 29, 2007 | SanDisk Sansa e200 MP3 Player
Powershot SD300 wont appear on computer
nothing on a sd300 but there is on a Ixus 40, see below for IXUS drivers and manuals
Sep 12, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
My comp wont recognize the mic
Have you tried another USB cable? Failing that, can you try the mic on another computer, take it round to your friends house or something?
If it still misbehaves, it's obviously gone faulty and needs fixing. Get in touch with the retailer or Samson support.
Sep 05, 2007 | Samson C03U Professional Microphone
iLO (2 GB) MP3 Player Logo
22 people viewed this question
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Michael Vincent Cruz
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
