Question about Mavic Ksyrium SLR Rear Wheel/Tire
How do I replace a Tracomp spoke on a Mavis Ksyrium SLR rear wheel? Can't work out how to release the hub end.
  • 4 Answers
I believe you'll have to undo the spoke at the rim end (Mavic uses a torx style head on the nipple). With the hub end of the spoke, looks like a ball but with two flat sides. When the spoke is tensioned it seats the ball end into the straight pull flange. This style is used in pretty much all of Mavic's high end wheel sets (Road or Mountain). Some have a plastic clip-on type cover. This can be removed with a flat head screwdriver. Good Luck!
Posted on Oct 14, 2013
I want to buy 1 of MAVIC KSYRIUM SSC SL SPOKE KIT REAR, DRIVE-SIDE, 272MM and MAVIC KSYRIUM SSC SL SPOKE KIT FRONT, 281,5MM SILVER, I want to know if you have in stock this kits and help to me to find road...
Hi, Edurado for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary, transport your bike to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your problem. For more information about your issue and valuable free downloads that you will need please visit the websites below. Good luck and have a nice day.
http://roguemechanic.typepad.com/roguemechanic/2012/07/mavic-spokes-and-parts-in-stock.html
Mavic Ksyrium SL SLS Replacement Spokes 4 81
http://www.tech-mavic.com/tech-mavic/uk/sources/Produits/ROUTE/Roues/KsyriumElite/KsyEliteSpokeReplacement.pdf
Where to get older Mavic Ksyrium SSC SL Spokes The Paceline Forum
Mar 16, 2015 | Road Motorcycles
Broke spoke on mavic kyserium sl can't ride bike, miles from home
being a french bike I don't know who can get you a replacement , but if its just a spoke or two,, wind the broken ones around so they don't rub on the fork or frame, and I'll keep looking , so check back, wow those are expensive,, heres a link
http://www.amazon.com/Mavic-Ksyrium-SL-Bicycle-Rim/dp/B0034L0872 Is it the front or rear ? heres a rebuilt one for less http://www.competitivecyclist.com/product-components/2011-mavic-ksyrium-sl3espremium-wheel-rebuild-4051.1849.1.html
Jul 15, 2011 | Mavic Cycling
I have been having issues with my real wheel on my bicycle. I have Mavic Ksyrium Equipe wheels, and the rear wheel seems to be flexing too much under loads (i.e. sprinting, climbing, descending, and...
It's hard to believe a shop can't deal with what sounds like loosening spokes. OTOH, we Clydesdales are tougher on wheels than the lil guys. I used to break a lot of spokes under high torque demands, especially on several sets of Spinergy Spox wheels, then I bought a Park spoke tension gauge and meticulously trued and tensioned all the wheels on all my bikes. Haven't had a spoke issue since then.
Or you could get an old set of Spinergy Rev-X like I did a long time ago before I figured out the tension thing. If you can break or bend them you are not human.
May 21, 2011 | Mavic Cycling
A spoke on the rear wheel has snapped off how can I repair it?
Simply buy a replacement spoke. Unscrew the dustcap on the tyre valve and deflate the tyres inner tube. Remove tyre using tyre levers(as you do to repair a puncture). Next remove the inner tube to reveal the spoke tensioners. undo the tension nut and allow the broken spoke to fall out, feed the other part of the broken spoke out of the hub. feed the replacement spoke through the hub and into the hole on the wheel rim. Now screw on the tensioning nut to the spoke.Tighten up to the same tension as the other spokes. replace inner tube and tyre, then reinflate. Viola!
Jan 30, 2011 | Cycling
My back wheel is making a ticking noise when i stand up and pedal. I lubricated the cross points of the spokes and it is still making the noise. I took the tire and tube off but i'm wondering how to get to...
You may have a loose spoke or two. A rubber liner usually covers the spoke heads. If you do your own repairs, invest in a spoke tension gauge and the tool to adjust the spokes.
Jul 28, 2017 | Mavic Ksyrium Elite Wheelset
Wheel does not stay true
Check if your spoke are tight enought, sometimes if the spokes are loosen the wheels will bent really easy.
May 18, 2010 | Mavic Ksyrium Elite Wheelset
Squealing noise for no apparent reason rear wheel when freewheeling
Could be a bearing..
If there is a grease fitting - try pumping some grease into it..
Other than that - try some penetrating oil or white lithium grease where the bearing are..
Jul 09, 2009 | Mavic Ksyrium Elite Wheelset
Noisy Rear Mavic Ksyrium Hub
Sounds like a road wheel with a worn FTS-L freehub body. You'll need to have it replaced.
What happens is that the nylon bushing wears, causing there to be play between the freehub and the nose of the wheel. Once there is enough play, the freehub can actually vibrate against the nose, causing noise and friction - which is why you see the chain slacken. This is commonly called the "squeal of death," meaning it is an indication that the freehub body is "dead."
A new FTS-L freehub body should be about $50-60 and shop shouldn't charge more than about $20 to change it out. Just be sure to tell the shop one very important thing:
"Do not lose the metal washer that sits on the axle between the outer bearing of the freehub body and the outer bearing of the nose of the wheel!"
This is so incredibly important - but time and time again, shop mechanics will lose this washer before they reassemble the wheel, causing a series of nightmares with the wheel.
Jun 09, 2009 | Mavic Ksyrium Elite Wheelset
Mavic Ksyrium SLR Rear Wheel/Tire Logo
138 people viewed this question
Top Mavic Cycling Experts
Eric Hidle
Level 1 Expert
Michial Gueffroy
numbers819
Level 1 Expert
Are you a Mavic Cycling Expert? Answer questions, earn points and help others
