Washing Machines
Problem for Washing Machines
Generic problem for all Washing Machines
I believe the timer on Whirlpool washer is ...
By beth817 on Apr 24, 2009
I believe the timer on our Whirlpool LSQ9544KQ0 washing machine is bad. How do I test this by using a voltmeter?
Best Solution
posted on Apr 24, 2009
Helpful)
jmgldsmth
Rank: Guru
Rating: 86%, 460 votes
A timer consists of vertical cams (disks with pieces missing that sit on a horizontal shaft, the shaft is powered by a very slow geared down AC electric motor as the motor turns; lever switches above and, below the cams ride upon the cams opening and closing to program the machine to fill, agitate etc. the length of the cutout in the irregular disk (cam) is the lengh of time a certain procedure or,device i.e. a spin cycle, or, solenoid takes or, is activated and, it's corresponding switch is closed. All machines come with a small packet usually mounted inside the control center that has a frequency and, duration chart for the timer. this will show you the conectors on the timer that should be closed at a certain time in the cycle you can then manually turn the timer to the spot wher the meter should read continuity The most offen encountered problems with timers are burned switch contacts and, dead timer motors.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Washing Machines
Questions and Unsolved Problems for Washing Machines
Answer
Whirlpool Cabrio WTW6300 worth the $$?
Answer
elite oasis is that a quaitly machine
Answer
how do you clean the filters onthe LG top loader Fuzzy Logic
Answer
flashes E30 fault code
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing... Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
