I have an lcd ecco tv model no:T315XW03 V3 XXXXG it bust the fuse all the time when I plug the power
2 Suggested Answers
SOURCE: Element LCD tv with no power. I replaced fuse,
You probably need a new power source. Take it to you repair shop. That's what I had to do and it was relatively inexpensive.
Posted on Mar 23, 2009
I have a 46" Flat Screen TV. Model Number
First thing you do is to check the outlet if there is a power output the check the power cord and plug.If there 's a power in the power cord,Check the fuse of your television.The fuse is located at the power supply.You can see the power supply when you open the back cover of your television at the upper right side.Replace the fuse if busted with the same value of fuse.That's the step you can do first..Thanks..
Aug 25, 2011 | Televison & Video
My tv wont power on could it be the fuse
unless you know how to open a plat panel tv you can check the fuse if it's busted or is it your tv is 110v and somebody plug it to 220v the fuse busted first then some parts maybe affected too
May 21, 2011 | Memorex Televison & Video
MODEL V27DMBX- NO POWER, WON'T TURN ON.
good day sir
the problem of your TV is on the power supply
I teach you some D.I.Y.tips and troubleshooting for your problem
I give it to you step by step
first remove the cover of your TV by unscrew it at the back
secondly after that the power supply reveal it is the one that have a ac input from your ac cord or supply
thirdly,check your fuse if busted,replace fuse if busted and also check the regulator transistor if shorted then replace also
after that,also looking for bulging top capacitor/leak replace it in same type and rating voltage/microfarad
and finally after same troubleshooting..test it by power it on again
thank you
Apr 02, 2011 | Tatung V27DMBX 27 in. LCD Television
No picture when powering on tv want to fix myself
If you don't see any lights on the panel, It could be a busted fuse. But usually based on my experience in fixing TV's (whether CRT or LCD) if the fuse was indeed busted, It only means that there's a short circuit somewhere along the circuitry. It may be a shorted power regulator (which is usually the case) or an open diode or resistor.
But try plugging the cord to another wall socket first or replacing the power cord (if possible). If none of them work, don't try to open and fix it yourself. Even with the power cord unplugged, you can still get a shock which might lead to a more serious injury.
Bottomline, Don't try it to fix it If you don't even know how to pronounce the word "diode"
(Remember that electricity is invicible. And what you can't see, can kill you)
Jan 26, 2011 | Insignia NS-LCD19 19 in. LCD TV
Samsung TV plugged into the wrong power outlet
maayong buntag dong,,you can do it by your self i teach you how,Open the back cover of your TV.Along with the AC power cord there is a component called varistor this varistor serves a protection for over voltage.Its color is green round shape with two terminal pins just remove it from the board replace the fuse with same rating and your tv will work again..anyway im from bicol albay.
hope i helped you..
please rate my help tnx dong!
Jun 06, 2010 | Televison & Video
My lg rear projection tv stopd working at onece and there is no light in the indicators .its model no is mw-60sz12. can it happn becouse of lamp
1. Unplug the cord & check if there is power at the
outlet.
2. Check for a busted fuse/or tripped off circuit
breaker at the main power panel pf your house.
3. Check for the busted fuse inside the case of your
projection TV. This is just near where your power
cable of your TV is connected.
4. When you are done, plug back your cord to the
power outlet, and put the power on.
This should correct your problem. Send us your email and keep us informed.
Sep 27, 2009 | Televison & Video
Power on TV went out and it will come back on.
Check for busted fuse inside your TV, so you can switch it back on. So, open it up. Follow the power cord going inside your TV. The fuse is just near to it. Have it replaced, and have it carefully clean free from dust using 1/2 inch paint brush. Put the case back close, and plug it back to your outlet. Switch it on. Hope this
help you, and thank you for casting your vote.
Sep 22, 2009 | Sharp Aquos LC-20B2U 20 in. LCD Television
Won't turn on.
Your LCD TV has a problem in power supply circuit board maybe the fuse is busted already just open your unit and locate the fuse.
Good luck:
Regards:
VOTIT
Don't forget to rate:
Jul 07, 2009 | Vizio L32 32 in. LCD HDTV
Maxim 32'' monitor style tft lcd tv
Maybe your tv has a busted fuse replace it same value. if a new fuse busted again it means your tv has trouble maybe in primary or secondary power.
Apr 10, 2008 | Televison & Video
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
Electro Med Services...
