Question about Intertherm P3RA-048K Air Conditioner
The inside unit is starting to make a hissing sound. Then about every five to ten minutes it makes a different sound like something is caught in the fan
  • 128 Answers
Pls check the motor beaings sleeves
Posted on Apr 27, 2009
Polo screeching sound
It's probably a worn or loose (or both) drive belt
Jan 30, 2013 | Volkswagen Polo Cars & Trucks
Wife used cig lighter adapter last night to blow up air mattress this morning new battery less than 1 month old wont start car. charged battery now when i turn the ignition key to start car the car alarm...
turn the igntion on, don't start, let it set for ten minutes Turn it off for 5 seconds then try to start it. If it lost memory for some reason and doesn't start . then do this three times , after the third time start it. that is the relearn procedure. Have a charger on it for the 30 minute relearn. Relearn is on for ten m off five s on ten off five on ten off five then start
Jul 02, 2011 | Chevrolet Lumina Cars & Trucks
The freezer in my mini fridge started making a hissing sound today something stabbed the bottom of it whats going on is it safe to use ?
From what you are saying the evaporator got punctured. The hissing was the freon coming out of the unit. The unit will not cool even if it was plugged in.
Apr 22, 2011 | Refrigerators
Makes hissing sound, then immediately clicks to "clean"
you need to turn it off and remove plates,put in kitchen sink and spray with windex and dry with paper towels, now clean the bottom of the three plates too.
before you reinstall the plates look down inside you will see three thin lines of metal,make sure there is no lint or dust on them,reinstall and let set for five min. to allow any windex that might still be wet then turn on low for a couple of min.then go to medium
Dec 28, 2009 | Ionic Pro TURBO Air Purifier
Intermittent hissing approx. every five minutes.
Sounds like the wires inside have collected some dirt. You should unplug it and tip the base unit upside down a couple times to see if you can dislodge it.
Dec 01, 2009 | Sharper Image Ionic Breeze 3.0 Air...
I own an Ionic Breeze Quadra unit. It has been working fine and I really like it because it removes bad odors from the house. Mine has just started making a hissing noise. Any suggestions? Thanks
hi,
Sparking, popping, hissing or crackling sounds coming from your Ionic Breeze air cleaner are all signals that it's time to clean your machine. Once you've cleaned the collection grids inside the Quadra, the disruptive sounds will disappear
how to clean
Turn off and unplug your Ionic Breeze Quadra.Grasp the horizontal handle on top of the air cleaning grids--this is in the very center top of your Ionic Breeze Quadra--and pull the grids straight up out of the casingWipe the metal grids down, inside and out along the entire length, with a clean damp cloth. You may need to use more than one cloth if the grids are very dirty.Go back over the grids with a clean dry cloth to remove any water and remaining dirtPut the grids aside on a clean, dry surface and grasp the body of the main Ionic Breeze casing unit in both hands.Flip the casing unit upside down, then right side up, five or six times. You should hear a small bead sliding back and forth as you do this. The bead is cleaning interior elements concealed in the casing; if you don't hear it, your unit may be in need of repair.Place the casing unit back on its base, orient the grids so that the handle slopes in the same direction as the top of the air purifier, then carefully slide them back down into the machine.
thank you for using fixya,rate my answer
vijay
Oct 01, 2009 | Sharper Image Air Purifiers
Goodman unit pressures are ok but the compressor starts making a hissing noise sfter running for sbout five minutes then cut out
check for;
defective condenser fan motor. brush and wash condenser coil it may be partially plugged.
Jun 10, 2009 | Heating & Cooling
GE Stainless Steel Profile refrigerator/freezer
It is more likely to be something getting caught in the fan. try pressing on the area at the back of the freezer behind the ice bucket and just below the auger motor housing . This is where the evap fan is and i have had cases of fan blades moving up the shaft a small amount but enough to just come into contact with the housing.
Jul 17, 2008 | GE Profile PSW26P Stainless Steel Side by...
Intertherm P3RA-048K Air Conditioner Logo
56 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
