Question about Dishwashers
E6 error code on teka dishwasher - Dishwashers
4 Suggested Answers
devdeep dhar
  • 375 Answers
SOURCE: error code E6 on my KDW12ST3A dishwasher
  • The solution is to reset it.The procedure is as follows.
  • Crack the Door open.
  • Within 3 Seconds enter the following sequence:- High Temp Scrub - Energy Saver Dry - High Temp Scrub - Energy Saver Dry.
  • Close and latch the door.
  • Press the cancel button ( The Circle with triangle in it ).
Thank you.
    Posted on Sep 17, 2009
    caroldon
    • 17130 Answers
    SOURCE: water leaking from bottom of
    It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there is gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
    Posted on May 28, 2011
    Daniel S
    • 4323 Answers
    SOURCE: Error code E6 caple Di607/15 dishwasher
    Hi
    Error E6 means flood switch activated, check the Inlet hose and whether the connections to the water inlet water valve is loose. Also make sure there is no inlet valve body leak. Check for damage to the fill or drain hoses. Try and reset the error code by following this procedure ? To Clear the current Fault press the Key lock button until a beep is sounded. This action moves the Current Fault into the Previous Fault while clearing the Current Fault. To Clear the Previous Fault press Key lock once more until the beep is sounded. Warning: Once a fault has been cleared, it is permanently removed from memory and cannot be recovered. Press Power to advance to the next level. Hope this helps...please post back for further assistance.
    Daniel
    Posted on Aug 29, 2011
    My Teka DW7 57 FI VRO2 dishwasher shows the error code E4.
    E4 means it is overfilled because of too much inlet water. Turn off the main supply. Remove excess water from the base pan and restart the dishwasher. DW7 57 FI Teka official website Bathroom Kitchen Professional Kitchen and...
    Apart from using the manual instructions, you can get technical help from the company directly too.
    Hope this helps!
    May 15, 2016 | Dishwashers
    Error code e6 what does that mean air conditioner will not start
    DeLonghi CF210 Portable Air Conditioner Error code e6 ...
    www.fixya.com > ... > DeLonghi CF210 Portable Air Conditioner
    DeLonghi CF210 Portable Air Conditioner, error code e6 related issues. Get free help, solutions & advice from top DeLonghi experts.
    Error e6 displaying on single split model one - Fixya
    www.fixya.com/.../t4492271-error_e6_displaying_single_split_model
    Apr 5, 2010 - Question about DeLonghi CF210 Portable Air Conditioner ... then the code error display E6 and the error code is Communication malfunction.
    DeLonghi fix e6 error Air Conditioners Questions & Answers ...
    www.fixya.com > Forum > Tags > fix e6 error > Air Conditioners
    DeLonghi air conditioners fix e6 error related questions and answers. ... DelonghiFX400eco error code I Have the above air con unit 18 months old the cooling ...
    DeLonghi CF210 Portable Air Conditioner Error code e6 split
    Jan 01, 2016 | DeLonghi Heating & Cooling
    E6 error code on fisher & pykel single door dishwasher
    1-Time Flash & E6 error troubleshooting, part 1 of 3 for ...
    ? 3:04
    https://www.youtube.com/watch?v=sYNN1Rvc7r0
    Dec 18, 2012 - Uploaded by MitsubishiHVAC
    1-Time Flash & E6 error troubleshooting, part 2 of 3 for Mitsubishi Electric Cooling & Heating - Duration: 2 ...
    LG Control Panel Overview
    www.lg.com > ... > Repair > Locate Repair Provider
    LG ElectronicsAn OE error code indicates the washing machine is draining slowly or not at all. This is usually ... When you see the E6 error icon, it means there is a clutch error.
    Nov 19, 2015 | Fisher and Paykel Dishwashers
    Error code E6
    Machine displays E6. Contact your local Hobart Service Office.
    Jan 11, 2012 | Baumatic Dishwashers
    Need an english manual for teka dishwasher dw6 59 f1 please
    By maggiegardne on Nov 20, 2010
    need an english manual for teka dishwasher dw6 59 f1 please
    Nov 20, 2010 | Dishwashers
    Bosch SHE44c getting a E6 code????Just finished E1 code by re-soldering the board and the first wash after fixing that error, I get an E6 code and it did not drain. During the repair of E1 code, I cleaned...
    Thanks, that perfectly nailed my problem. Bad / burnt solder joint on a SHX45P05UC/57 model. A little solder, and it may last a while. But next it fails that way I can order the motherboard without even opening it up.
    Aug 11, 2010 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
    How do u clean the pump and drain hose on a teka dishwasher? please help
    buy Finish dishwasher cleaning kit from the super market and follow the instructions on how to use it. The cleaning kit should be run with empty dishwasher.
    THis should help clean the pump and drain hose.
    It would help if you mention the model number of your dishwasher. It is hard to get an english manual for Teka.
    I tried this site
    http://instructionsmanuals.com/lista2-20-49-en-Dishwashers-Teka.htm
    but they all seem to be in European languages.
    May 25, 2010 | Dishwashers
    How to reset a dishwasher teka lp700
    i have a problem with teka lp 700, dial gets stuck and water starts to spill out, also the motor after awhile ceases up.
    Apr 19, 2010 | Dishwashers
    Dishwashers Logo
    963 people viewed this question
    Top Dishwashers Experts
