What is the fluid capacity of the gear oil in a 1997 nissan 5 speed 2 wd truck
CAPACITIES
Engine, 2WDwithout filter..........3.5 quarts[1]
Engine, 4WDwithout filter..........4.0 quarts[1]
Cooling System, Initial Fill..........8.5 quarts
AMSOIL Antifreeze and Engine Coolant
Automatic Transmission, Total Fill..........7.4 quarts
Manual Transmission, 2WD..........4.2 pints
Manual Transmission, 4WD..........8.4 pints
Differential, 2WD Rear..........3.2 pints
Differential, 4WD Rear..........2.7 pints
Differential, Front..........2.7 pints
Transfer Case,..........4.6 pints
1. Add extra oil when replacing filter.
refill check oil level.
TORQUES
Oil Drain Plug.....22-29 ft-lbs
Transfer case
Fill Plug.....18-25 ft-lbs
Drain Plug.....18-25 ft-lbs
Manual Transmission
