Question about Stoves 600SiDOm Gas Kitchen Range
The water has overflowed out of saucepan got into the thing under where the flame goes now there is a burnt mark how do l remove please?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 125 Answers
Kathy it all depends on where it is can you post a photo, some gas cook-tops are impossible to clean for the perfectionist.. I always mumble about mine... I cannot find a correct image of your appliance
Posted on Oct 13, 2013
2001 Dodge Dakota Sport What is the speciation for the fluids, how much too use?
water always goes in the radiator up to the radiator cap and the overflow bottle up to the full mark or about 1/2 way. The fluid capacities for your vehicle are in the owners hand book, workshop manual,(genuine or after market) or available on line under specifications for your make of cart.
Jun 20, 2014 | 2001 Isuzu Trooper
How do I remove burnt rice stain in saucepan ?
Metal wool scrubbers available from the local poundland will remove anything that is hard to remove on virtually any surface.
May 06, 2014 | Computers & Internet
Water under fridge sometimes
You may want to remove all the food, unplug your fridge, and the out the whole thing...melting the ice and cleaning out all the unwanted water. The drawer will be removable, and you can dry under it. Also check the overflow tray under the fridge, if there is one...it'll be full from all the melting.
Jan 24, 2014 | Whirlpool GX5FHTXVA Bottom Freezer French...
I have a power flex 50 gal power vent model number pvg625ot6onv.. Serial number, 0932t413742. I got a new lighting element, and installed just fine but the actual ignitor keeps dropping to vacation...
Sorry to hear about your wife.
Please copy following links for Intellivent troubleshoot resources:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://www.thetankatwaterheaterrescue.com/forums/forum3/
http://www.americanwaterheater.com/
Clean air intake located on bottom of heater using compressed air or feather duster. Use auto inspection mirror and flashlight to see under the unit.
Age of water heater appear on label on side of tank.
Look for serial number.
Powerflex is American water heater product (AO Smith)
First 2 digits of serial number is year of manufacturer, digits 3-4 are week during year.
Nov 26, 2012 | Water Heaters
Where to put water
under the hood on one of the fender wells there will be a tank, this is your coolant overflow tank, fill it to the line on the side, the other fill area is at the top of the radiator, NEVER OPEN THIS CAP WHEN YOUR ENGINE IS HOT!!! it is under pressure and severe burns can result. When cool remove cap and fill radiator to top replace cap and top off overflow to mark. have fun!
Feb 26, 2011 | 1998 Jeep Cherokee
How much water is to be dischage form overflow valve? My dip pan at the bottom of the hearter unit gets full of water and make the pilot light flame goes out. We figure about a gallon in 24 hr. ...
1) Water heaters do not have overflow valve.
That valve is called TP valve.
It releases hot water when tank is overheating or when TP valve is bad.
2) First thing to try is replace TP valve:
Follow instructions on link:
http://waterheatertimer.org/How-to-replace-TP-valve.html
3) If you suspect water heater might have more serious problem, read through troubleshoot steps on following link:
http://waterheatertimer.org/Leaking-water-heater.html
4) If your tank needs to be replaced you can do it yourself:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 23, 2011 | Rheem Water Heaters
No hot water coming from combi boiler ( vailliant)
I have a BAXI combi Instant 105 HE bolier. It has been very cold for the past week and the hot water is not working (though the heating is). I have cleared the overflow flu pipe of ice but this has not solved the problem. Any suggestions?
Sep 16, 2009 | Combi Centre DX - Mango
Hotpoint WD440 Drawer overflowing
Hi.
I would check the inlet hose from the bottom of the soap dispenser where it goes into the drum for a soap blockage.
undesolved powder can build up here and prevent the water entering the drum
You can access this hose by removing top cover.
the hose is on the left side front.
This should solve your problem.
Please leave feed back.
Thanks.
Nov 25, 2008 | Hotpoint Aquarius WD640 Front Load...
Had a new gas hob installed but two of the gas burners only have a very low flame even when turned to high. One of the others has yellow flame tips even on low and is leaving marks on the bottom of the...
propane or natural gas? if it was converted inproperly it will leave soot on your pans. also you will see flames when you bake with it or broil.
Nov 01, 2008 | Kitchen Ranges
Stoves 600SiDOm Gas Kitchen Range Logo
73 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Oloyede Monsuru
marley mcelhinney
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
