I have black shadows in samsung lcd this problem appears new after i input av because of xbox 360
SOURCE: one for all urs-3021 input code for a samsunge tv with vcr
how to program aone for all remote control
Posted on Dec 13, 2007
  • 5 Answers
SOURCE: xbox 360 flickers green and black on the screen
i had the same thing on my hitachi tv and it was my mobo in my 360. just got it back, working fine now.
Posted on May 19, 2008
SOURCE: My Xbox 360 keeps showing a black screen
1. Get 3 towels then switch your Xbox 360 on.
2. Wrap the Xbox 360 in the towels [Note - You must cover the WHOLE Xbox otherwise it won't work].
3. Leave your xbox for 25 mins in the towels.
4. When the 25 mins is over take off the towels of and let your Xbox 360 to cool for 20 minutes, enjoy fixed gaming for the next 4-7 days. Once you get a blank screen repeat this process.
[Why Overheat it?]
When overheating it you attempt to solder the dis-connected wires back to the motherboard.
I recommend getting it fixed instead.
[What does it Fix?]
This fixed the Red Ring of Death, and the Blank Screen of Death
[DANGER]
I do not take responsibility for this. This is mainly for those without warranty or money to repair.
The premise is to wrap the towel around the 360 and to let it heat up. This will weaken solder points and hopefully re-join broken connections. The problem with this method is that you have no control over what solder points are weakened and there is no way to prevent further damages caused by the heat. It is better to send a 360 in for repair with the three year warranty that MS put on the 360s, because if you try the towel method and then send it in for repairs, they will know by the solder points being misshapen and it will void your warranty forcing you to pay for the repairs.
Posted on Nov 28, 2008
SOURCE: XBOX 360 no video after playing HALO 3
Yeah, mine did the same thing.
I looked around and it turns out that this problem is pretty close to same thing as the red ring of death, so in theory, to fix this problem you can do the samething as you would do for any RROD.
Last night I did the towel trick and fortunatley it worked for about an hour, than the tv screen went fuzzy and then black. I tried towel trick again for the ful 20 minutes and it seems to be working.
Hope this helps anyone, and wish me luck that my xbox holds out untill I get enough money to buy a new one or a PS3.
Posted on Dec 04, 2008
SOURCE: I bougth a lcd samsung 40 inch tv. I cannot connect my gamecube
You need to get a special scart lead which you can connect your red, white and yellow leads to then connect the scart lead to your tv it should work then
Posted on Feb 01, 2009
No input signal VGA/Xbox
You are doing nothing wrong. The best thing to do, which you are doing, is to eliminate possible problems. Try a different cable, monitor etc until you narrow the problem down to a single component.
Aug 05, 2012 | Microsoft Xbox 360 Console
I have just bought an xbox 360 conected it to my tv allcables connected picture great but no sound
Hi Douglas
I imagine you have bought the new slim Xbox 360? Did you use a HDMI cable to connect it to your TV or did you use the standard cable? If you used a standard AV cable ensure that you connected the red and white cables into the same AV input as the yellow video cable.
Mar 05, 2011 | Microsoft Xbox 360 Console
No picture or sound with brand new xbox friend's xboxs worked ok
Look like ur Xbox 360 AV RCA cables is not making contact to the input board very well.Take some rubing achahol cleans the all those input holes,take the RCA AV connections make couples twises to the red,yellow and white,will help.Make contact with ur input board it should work.
Apr 28, 2010 | Zenith SY2551S TV
Xbox 360 plays sound but no the video
try another tv to ensure its your xbox and not tv input. also look on your av cord there is a small switch on it make sure it is in the proper position hd or tv.
May 01, 2009 | Microsoft Xbox 360 Console
E74 system failure... AV cables?
Here are some steps that you can use to try to resolve the issue. 1. Turn off the console, disconnect all the cables, and then reconnect all the cables. Turn the console back on. 2. Turn off the console, and then disconnect any accessories that are connected. For example, disconnect any Xbox 360 controllers, Xbox 360 Memory Units, and the Xbox 360 Hard Drive. With the accessories disconnected, restart the console to see whether the problem still occurs. This can help you determine whether the console or an accessory is experiencing the problem.
If this doesn't work, call MS and explain all this to them. If they do not offer to fix it for free then you can try repairing it yourself or selling it and getting a new one. If you opt to repair it yourself, let me know and I will give you some advice and resources. Good luck!!
Aug 15, 2008 | Microsoft Xbox 360 Console
Hi! name's wesley. anyways, here's the problem. i just bought a new samsung 32' lcd tv and everything is great except for one thing: when i connect my ps2 to the "av 2" input, the sound comes out...
There is a problem with the AV2 input. Since this is a new set, return it for repair or exchange. DO NOT open it up as that would void the warranty.
Dan
Jun 05, 2008 | Samsung Televison & Video
System error E74
im having this problem at the moment its something to do with the av port and graphics chip but microsoft wont fix mine for me which im anoyed about hope this helps
regards grant
Nov 17, 2007 | Microsoft Xbox 360 Console
Xbox 360 Elite compatible with 62' Mitsubishi HDTV?
I have it and it works great! For all TVs, the TV have to be on fixed settings on standard, dot-by-dot mapping, noise reduction off. The camera's exposure the same for both side-by-side shots. Just set it on standard and it should work...
Jun 05, 2007 | Microsoft Xbox 360 Console
Black and white picture
do u have your 360 display settings at 60hz if so the tv might not be compatiable with a 60hz signel go to display setting and drop back to 50 hz and colour may show it self but remember some games wont play in 50hz if this is the case try find a ntsc to pal converter
May 07, 2007 | Microsoft Xbox 360 Console
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
