Question about Dryers
Loud screeching. looks like drum bearing is broken
VERY LOUD SCREECHING. TOOK DOOR OFF AND NOTICED THIN PIECES OF PLASTIC WHICH WERE CHIPPING OFF WHAT LOOKS LIKE THE DRUM BEARING (FITS AROUND THE LIGHT BULB) THIS PIECE IS OBVIOSLY BROKEN. IS THIS THE CAUSE OF THE SCHREECHING? HOW DO i GET THAT PART OFF? CAN'T SEE ANY SCREWS. WHAT ELSE DO I NEED TO GET IN ORDER TO FIX THE PROBLEM? SLIDES OR GLIDES? GE DRYER, ADORA DHDSR48EF2WW
    Genius:
  • Dryers Master
  • 1,198 Answers
Welcome to the world of appliance repair. A dryer is a good place to start. Check Repairclinic.com for parts and help, it's a good site. You're going to have to take the dryer all apart. The trickiest part is the belt. Note how it goes, or you're doomed. While in there, vacuum all the lint, it's a fire hazard, and gets into places it doesn't belong. Use a high temp grease on the roller shafts, and replace the belt while you're at it, they are cheap. The glides and felt need to be in top shape, they keep the dryer from eating clothes. On some models you need to pop the top. Use a putty knife to push the spring catches at the front corners. Inspect all around for bearings and things that might wear out.
Posted on Apr 24, 2009
Why won't it agitate or move drum?
Screeching noise is typical to drum's broken bearing issue.
See some infor about issue:
How to Diagnose Drum Problems in Washing Machine
How to change drum bearings on washing machine
How to Change the Bearings in LG Washing Machine
How to replace washing machine bearings on Bosch Neff Siemens and some...
Some more video there... explore
Now, if you don't find it so easy to replace those bearings or you are not sure if this is your problem, call a repair service
Aug 18, 2015 | Washing Machines
Why is my whirlpool electric drying making a loud screeching sound
I know this is a late answer but you have bad bearings on the dryer. There is usually 1 on the back of the drum in the center. Its in 2 pieces, one is nickel coated and the other is hard plastic like material that holds the nickel piece. The other 2 are on the front of the drum on the top just out of sight. They attache to a lip on the front of the machine and the drum 'rides' on the bearings. These are usually about 3 inches long by 1/2 inch wide and 3/8 inch tall and are made of a hard plastic like material.
Aug 28, 2014 | Whirlpool Dryers
Kenmore elite washer troubleshooting
Sounds like your bearings are worn and need replacing... a horrible job. The frayed plastic may mean a new drum. To replace the bearings you must remove and separate the drum which requires removing the top, front, and back panels. Lots of clips, screws, hoses, wires.... I'd take it on if this were my unit; but for a client, I'd say get a new one. This is not uncommon for these units. Sorry.
Feb 16, 2014 | Washing Machines
WBVH6240FWW loud bang
that would be the bearing and housing gone on the drum, if you can lift the drum with your fingers at the bottom of the drum in the door hatch even by putting lifting inside then the bearing has gone. the plastic is the drum.housing usually were the bearing housing is. if there is a lot of movement then the bearing has gone. usually the front bearing but you will need to remove the drum and separated the drum to remove the drum then the bearing, rust on clothing is the bearing as its the only part in the drum that is metal.
Jun 27, 2017 | GE WBVH6240F Front Load Washer
My Tappan electric drier make a loud screeching sound like an axle with no grease. I can't figure out how to get the front panel off to locate the source. Model MDE336RES1
These are known for this. You will need to replace the rear drum bearing. Go to http://www.partselect.com/PartDetail.aspx?Inventory=459829&SourceCode=1 this is the part you will need. ($22.32 + shipping) It's located at the back of the drum. The round silver piece goes on the drum and the white plastic piece goes on the back panel of the dryer. (Notice the round silver ball. Make sure to not loose or forget to put it in when repairing) You get into this machine by going through the top and front. Not the rear. Good luck
Nov 16, 2009 | Dryers
Making a loud thump sound
Frigidaire 5.8s dont have roller to support the drum instead they use a machined ball in back sat down in a plastic hub that is cupped to hold it in and covered in grease. the front rides on wear strips on the front panel felt pads. take front off and check these for excessive wear, cracks, etc. then take drum out (remove plastic hook at top center to give clearance) lift up at rear to take out of bearing cup.
if by some chance this is a 7.0 then you should still have a warranty
Jul 11, 2009 | Dryers
Can't load the toner because the access point hasn't spun round far enough to accept the toner cartridge
Open the front cover and look at the L/H side. You will see a hole with what appears to be a circular plastic piece inside it. On the cover itself should be a piece of plastic that sticks out. Notice that as you close the cover this enters the hole and depresse the "circular" bit inside. This unlocks the cartridge carousel so that it can rotate. Simply use a pen or screwdriver to depress the circular bit inside the hole and rotate the cartridges by hand until the right cartridge is aligned for removal. (BTW If the plastic part on the door is broken off the printer will make a loud screeching noise when it is switched on and an error will occur).
Hope this helps & good luck.
Jul 09, 2009 | Epson Office Equipment & Supplies
Front loader making loud noise with spin cycle
It may be something that was in the wash and fell thru the holes in the inner drum. Check all the plastic agitators and make sure they are all secure and an attach bolt has not backed out of one and rubbing the outer tub. It will wear a hole in it fast if it is.
Usually when the bearings go bad, it gets very loud on the spin cycle, like a loud roar and sometimes clothes will have rust or grease stains on them.
I just replaced my tub bearings on my Frigidare and spent about $60. They are all pretty much the same. On mine they only list the complete rear outer tub assembly with bearings, but you can knock the old bearings and seal out and match them up at a bearing supply house or you can buy online. Online seems much cheaper. If you buy bearings, make sure you get ones with a -2rs on the end of the part number. ex. 6308-2rs. They are sealed and hold up much better in water environment.
I would give it a try, the junk man doesn't care if it comes in pieces or one big piece.
There are a couple online articles that can probably help you. Do a google search for 'washer rear tub bearings"
Jan 29, 2009 | GE WPXH214A Front Load Washer
Open Questions:
Dryers Logo
277 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
