Question about Baumatic Kitchen Ranges
My bt9.3gl/bt9.3bgl glass chimney hood has become very noise
Fl3 code. heater working fine when i closed last year. will not start this year. showing fl 3- does not ignite , does not do anything ..help please
3.
Spillage at A.Cold chimney A.Allow heater to operate 5 minutes to create draft action.
draft hood B. Vent pipe pitches down to chimney B. Reinstall vent pipe to pitch up from heater to chimney.
C. Blocked chimney C. Remove blockage.
D. Draft hood altered D. Install factory-provided draft hood.
E. Prefabricated chimney with incorrect cap E. Install a Nationally Recognized Testing Lab (NRTL) listed vent
http://www.jandy-downloads.com/pdfs/Lite2_LJ_IO_H0248900F.pdf
I tried to copy the FL3 write up from the chart but it screwed it up a little. Look at Page 35 of the manual for a clear copy
Jun 10, 2011 | Jandy Lite 2 Natural Gas Pilot Light...
Our DLX series dishwasher leaves dishes and glasses diffusely cloudy. Not spots and not streaks. A repairman found some blockage in the drain hoses and thinks he cleared the obstruction. We have tried...
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Jan 15, 2010 | Bosch 36 Inch Pyramid Chimney Hood - Black
Screen over chimney?
Screen is not the correct product to use to bird or squirrel proof the chimney. Your local hardware will have what is known as hardware cloth. It's actually a heavy wire mesh with 1/4" or 1/2" square pattern. you should be able to purchase it, by the foot, off a roll.
Jan 06, 2010 | Bosch 36 Inch Pyramid Chimney Hood - Black
What is the height of britannia omaggio 90 cooker hood?
Here are the dimensions that relate to your cooker hood. The measurements are in mm.
Width 980 front 578 rear
Depth 480
Minimum height 1015
Maximum height 1170
Main canopy height 750
(excl chimney)
Chimney section width 436 main body/340 sliding section
Chimney section depth 170
Mounting height 650 - 750
Regards
Alan Hood
ami-man
Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750
Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750 Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750 Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750
Jun 16, 2009 | Kitchen Ranges
Install the chimney cover
there should be 2 or 3 peices of alum off the hood predrill hole's then rivet or steel screws
Feb 12, 2009 | Bosch DKE 9365 Stainless Steel Kitchen...
CDA CPX9 COOKER HOOD - how to remove chimney/disconnect power
remove filters, inside there will be mounting screws, support the unit prior to removing screws. there might be ducting inside clamped on, and a power plug(hopefully) to disconnect.
Jan 26, 2009 | CDA Kitchen Ranges
Colour of the CDA CHIMNEY HOOD CPX7ss
the greyinsh blue color sounds like it still has the protective film on it that needs to be peeled off
Nov 26, 2008 | CDA CPK9 Stainless Steel Kitchen Hood
Kitchen Ranges Logo
48 people viewed this question
Top Baumatic Kitchen Ranges Experts
Greg Cann
Greg Cann
Treefrog15
Treefrog15
ray gallant
Are you a Baumatic Kitchen Range Expert? Answer questions, earn points and help others
