Question about Little Giant Water Heaters
Water is not heating no heat
What is best temperature setting for water heate
120°-125F is safest temperature.
Typical bath-shower is 104-110°F but rarely higher.
130°F can burn the skin in about 1 minute
Serious burns occur in seconds with 140°F and higher.
Use a cooking thermometer to check temperature coming out of tap ... if hot is slow to arrive and never seems to arrive, make sure all single handle faucet cartridges are up to date.
Following link has additional safety tips:
http://waterheatertimer.org/Water-heater-safety-precautions.html
Oct 20, 2017 | Water Water Heaters
Water heater
Most instant-on tankless water heaters require at least 10 psi of water pressure to start the heating process. The flow of water determines how hot the water will be, within the heating range. An electric 110 volts heater will increase the water temperature about 25 degrees F. A gas water heater will increase the water temperature about 45 degrees F.
Too much flow will not allow the water time to heat. Too little flow will not allow the heating system to work. Each heater must have the outflow water flow adjusted for the best heating outcomes. The best way to find the ideal flow is to turn the hot water facet on and adjust it (open or close) until the water reaches the balance of producing hot water.
Apr 25, 2016 | Water Water Heaters
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
Want to shut off my hotwater heater and still run my boilerhave base board heat
Turn off water but leave heat on - Possible? - Handyman WIRE ...
handymanwire.com > ... > Heating and Air Conditioning
Jan 14, 2003 - 10 posts
My hot water baseboard heating system is a closed system. ... Could I shut off the main water and leave the boiler and heat going for ... If one is not installed, install one and rely on that to save the boiler from the damage of running out of ... I do not wantto have city water push my antifreeze out of the system ...
What's the best temperature to set my hot water baseboard ...
greenhomeguide.com/.../whats-the-best-temperature-to-set-my-hot-water...
Nov 21, 2010 - With hot water baseboard heating, is it better to keep the heat at 60+ degrees ... a hot water heating system where water is heated in a hot water boiler and then ... by setting the thermostat to lower the heat when you don't need it on. ... Not only do I turn my heat down when I leave for work in the am but also ...
Jan 17, 2016 | Water Heaters
Need to separate heating and hot water - just have hot water on
You need a heating engineer to come in and do this.
Sep 09, 2017 | Water Water Heaters
Will well water cause a problem on the heat pump water heater
I would say yes.
Because element may not be easy to replace, or easy to reset unit after replacement
I would also suggest not buying heat pump... must be in at least 10'x10' room with 7" space around entire heater
http://waterheatertimer.org/Review-GE-Heat-Pump-water-heater.html
Gene
Oct 15, 2014 | GEH50DEEDSC GeoSpring Hybrid Water...
Heat Trap Nipple which side into the tank
Don't install heat trap nipples if house has pressure issues, or pipes get clogged with hard water.
Heat traps will clog, and whistle, hum, buzz, and reduce household pressure.
Make your own heat traps by configuring pipes differently.
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html#heat-trap
http://waterheatertimer.org/Low-hot-water-pressure.html#trap
Buy regular di-electric nipples at local box store plumbing department instead of heat trap nipples.
http://waterheatertimer.org/images/IMG_1879-di-electric-nipple-300.jpg
If you go ahead and install the heat-trap nipples, look inside the nipple.
Look past the plastic bar that divides down middle.
Notice that one end has insert inside the pipe. While other end does not have insert.
End with insert goes into water heater first.
Notice also if you blow into the heat trap nipple that air flow is constricted.
If air flow is constricted, then water will also be constricted.
This is why heat trap nipples are not recommended.
Why do they have heat trap nipples??
So manufacturers can report higher EF energy efficiency rating for product.
Do heat traps save money. Yes, but make your own by reconfiguring pipes. Save $9.20 per year electric heater, $4.00 per year gas heater.
You can save more money by maintaining water heater, which pays about 10$ per month in future replacement costs.
Or fix leaks, and install dual-handle faucets so lifting single handle faucet in middle does not continually run cold water into tank. This saves $2-$8 per month.
Nov 27, 2012 | Richmond Heat Trap Nipple Kit - RP20003
Every time we put on the central heating our water runs cold
What kind of water heater do you have?
In any case, it sound like a plumber should check out system.
Do you have indirect heater that gets heat from central heating boiler?
Most indirect/boiler combo heaters have control that is set to heat the water first.
If water is not getting heated, then the control needs repair.
Do you have gas water heater with gas central heating?
The central heater may be drawing so much gas from meter, that other gas appliances are unable to function. larger gas meter or gas line may be needed.
Or if furnace and water heater vent on same chimney, the backflow from central heat could be affecting burner on water heater especially if water heater has electronic sensor that stop combustion if air quality is bad. Venting problems can lead to CO poisoning, and are a serious matter.
Nov 18, 2010 | Water Heaters
Central heating and hot water have suddenly stopped working
not an engineer but maybe a heating compant,, it sounds like you have a relay that has gone bad, you have what we call a winter summer system your domestic water comes from a tank inside the boiler, you might want to think about splitting the system to save you some money in the long run, seperate the water heater from the boiler so you only heat up in the winter, right now you are heating the system that heats your house to get 30 or 40 gals of domestic hot water, it would cost you less by seperating them
May 17, 2009 | Water Heaters
Water Heaters Logo
23 people viewed this question
Top Little Giant Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Little Giant Water Heater Expert? Answer questions, earn points and help others
