Question about ASUS A7V600 Motherboard
I have an ASU A7V600 board and I can't remember where in the BIOS I can enable the onboard sound
  • 84 Answers
You should remove the CMOS battery and re insert again for resetting the BIOS....
Posted on Apr 24, 2009
Audio does not work
You aren't saying what type of PC desktop you have. However, motherboard audio chips are a common failure item on desktop computers. The first thing you should do is reboot and go into the BIOS. Check to ensure that the audio is enabled. If not, re-enable it and try again. If that isn't the problem, try reinstalling the audio driver to ensure it hasn't become corrupted. If that doesn't work, you may need to purchase an aftermarket audio card to install int the desktop to recover from the failure of the onboard audio. If you do this, remember to disable the onboard audio in the BIOS before installing the new board and driver to avoid conflicts.
Dec 24, 2014 | Computers & Internet
No sound
First we need to know what motherboard and if your trying to use and onboard system or a external card system.Going blind here first go into bios and make sure the onboard sound is ENABLED.If you are using a EXTERNAL card then be sure the on board sound is DISABLED.Hope this helps
Apr 27, 2011 | Computers & Internet
Mainboard asus a7v600-f
have a look at this guide first:
http://support.asus.com/technicaldocuments/technicaldocuments.aspx?root=198&SLanguage=en-us
then have a look at this support page:
http://support.asus.com/download/download.aspx?SLanguage=en-us
You'll need to fill in the information in the drop down boxes though:
Select product: Motherboard
Select series: Socket A
Select Model: A7V600
You will then go to a screen where you need to select your operating system, once you've selected the correct one you will have a list of downloads appear which will include Updated Bios files.
Hope the info helps
Mike
Jul 06, 2009 | ASUS A7V600-F (A7V600F201FSCSI)...
Onboard video died, how do i enable the agp card
if you can't see bios on start up, after pessing F8 on xp, try with F2 and F4 .. if nither of that work, try to unplug pover cable , reset bios by pulling out little battery on mother board, that how you will reset cmos, and out bios on default state. And maybe than it will enable you your agp port.. try and let me know..
Jun 28, 2009 | E-Machines T3085 PC Desktop
Sound Card
Hi izhet19,
click on this link from Asus for the sound driver for the
A7V600-X motherboard;
http://support.asus.com.cn/download/download.aspx?modelname=A7V600-X&SLanguage=en-us
You'll need to click the drop-down menu & click on your operating system from the list. Than click Search Button.
Click the + sign next to Audio.
Create a folder on your desktop & name it Audio.
Download the audio driver, " SoundMax Audio Driver version 5.12.01.3663 WHQL driver for Windows 98SE,ME,2000,XP ", file name, WDM_3663.zip " Save the file WDM_3663.zip ", into the Audio folder you created .
You'll need Winzip to uncompress the file: WDM_3663.zip.
Download Winzip 12 trial version at this next link;
http://download.cnet.com/WinZip/3000-2250_4-10003164.html
Once uncompressed you can run the driver software.
Make sure you have the Audio enables or set to Auto in your bios.
Have more question, post here.
mike
Mar 29, 2009 | VIA ASUS A7V600X MOTHERBOARD...
No sound
Pl check through BIOS in the integrated peripherals whether onboard Audio is enabled if it is your board for onboard, check specific driver for the card.
Mar 22, 2009 | Toshiba (K000002020) Motherboard
Sound drivre
Do you have onboard audio or a sound-card?
If you are using onboard audio try checking the motherboard's BIOS to ensure that the audio was not disabled. To enter the BIOS watch the screen VERY closely during the startup procedure. Typically the computer will mention something to the effect of, "Press F1 to enter Setup." You are looking for a similar message listing the key to press to enter, "setup." You will have to repeatedly press that key until you enter the BIOS screen. As a hint, if you see the Windows loading screen, you missed the screen notifying you of the key associated with entering setup.
Once you manage to enter the system BIOS, use your keyboard's arrow keys to select different menu options. Using the ENTER button on your keyboard enter some of the menus looking for options on onboard audio or integrated sound. Once you do find such an option check to see if it is disabled or enabled. If you're using onboard audio, you will want to ensure that it is enabled in the BIOS. Once you changed the settings exit the BIOS saving changes.
WARNING: Only change this particular setting! If you do not know what you're doing with the other settings you could potenitally damage or destroy your computer!
If the audio was never disabled in the BIOS and assuming you're using Windows, check your audio controls. To check these settings go to the control panel and open the Sounds and Multimedia (or Sounds, Speech, and Audio Devices. Then Sounds and Audio Devices) application. Afterward click on the, "Volume" (Or Audio) tab at the top. Now click on the, "volume" button associated with the, "Sound Playback" section. Now make sure your main audio mix is turned up to your desired level.
If your audio is still not playing try changing the, "Default (Playback) Device" for the, "Sound Playback" section. If you have more than one sound source, you could be using the wrong one. Changing the default playback device might send sound to the audio ports you are currently using thus enabling your sound.
If it's still not working post a comment telling us what methods you tried which failed. I'm sure we can get your sound working. :-)
Feb 03, 2009 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
I HAVE INSTALLED A TC/CARD ON MY MS 6786 MOBO
You mean your Video Card?
To disable the your MS6786 ONBOARD GRAPHICS on your PC.
- If you know ho to proceed the BIOS System of your PC? they have choices to change you settings
Disable or Enable.
Sep 22, 2008 | Computers & Internet
ASUS A7V600 Motherboard Logo
101 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
