Konica Minolta PagePro 1390MF Laser Printer Logo
v
vishal sharma Posted on Oct 13, 2013
My machine give error service call -80 - Konica Minolta PagePro 1390MF Laser Printer
With my WT965A comes an error code F08. Any idea? I guess it is the heating element?
Check your machine heater relay, 80% heater relay problem, it's not easy to solve this problem by your self,thank you
Hi My Hoover dynamic next washer model no DXC A48AW3/1-80 has an issue the machine starts to fill then appears to over fill then stops and gives an error code E02, any thoughts please
Hoover suggests that the water fill valve(s) may be turned off. Error 2 means It cannot fill correctly according to their owners manual.
Brother SQ9000 Why is my needle striking the race?
Try a different brand new needle. Make sure it is facing the correct direction when installed. If it is still hitting, you need to take the machine for service.
Hp designjet t1200 error code 80
80 ......... there is more to error code than just 80 please give full error code details for a useable solution .
eg 86:01 ( carriage motor transport error)
or 0c00340a is also a fault code
if you can supplye either full error code then I will attempt to help you resolve it thanks
Bosch logixx 8 error code 80
Unplug the unit from the wall for 5 minutes and see if it clears, if not call service.
IBM T42 gives Fan Error message and stops
The fan may be faulty or clogged with dust.
Check the fan to see f it spins freely and remove dust from the heatsink fins and fan assembly.
The specification in the manual for the T40 series shows the largest hard drive is 80 Gb.
It may be possible to install a larger hard drive, but check with Lenevo first.
1helpful
Brother Innovis 4000 D stopped sewing
These machines are known to freeze up in the needle bar crank, even when only a couple of hours old. If it is less than a year old, a Brother certified service center will fix it under warranty.
1helpful
E6 and F5 error message
Are you using the right size needle? Try using an 80. Also try taking it to a service center. To find one near you go here: http://www.brother-usa.com/service/
1helpful
2answers
DISPLAY READS: 80 SERVICE (01E4)
If you keep getting 80 service, first recycle the power to the printer (try a few times if the error doesn't go). If that doesn't work replace the MIO card (the bit the network cable goes in)
Unable to clean error
purge station defective. if you have the machine for 5 month give ti back to dealer . its in warranty!
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
