Question about Yamaha PSR-E333 - 61 Key Portable Keyboard
How to fix dead keys in yamaha PSR E333 - Yamaha PSR-E333 - 61 Key Portable Keyboard
  • 1121 Answers
SOURCE: 3 keys don't work on my Yamaha PSR-150 keyboard.
yes. you must change keyboard pad, below the keys, and check for dirt and deteriorated board.
Posted on Oct 30, 2009
  • 88 Answers
SOURCE: 3 keys non function on Yamaha PSR 3000 sometimes
rubber contact strip requires replacement
Posted on Feb 05, 2010
SOURCE: Do you have yamaha keyboard psr 2000 spare parts?
My keyboard yamaha psr2000,so I want parts silicone rubber keypad 61 and including electronic board,thank you.
Posted on Feb 14, 2010
jyvibar
  • 148 Answers
SOURCE: Yamaha PSR 275, some of the keys are not working
try to re start your computer to reset keyboard
Posted on Mar 26, 2010
SOURCE: yamaha psr s900 screen/display gone bad
MR SATISH IF YOU WANT TO SOLVE THIS PROBLEM CONTACT:9887070565,94136768(ANAND NARWAL)FROM RAJPUTANA ENTERPRISES
Posted on Aug 07, 2010
Yamaha psr-e333. Can switch on but cannot play even the grandpiano func. Its just "yamaha" written on the display..
To start with try a master reset, whilst the instrument is off press and hold the top (highest) sounding key whilst turning on.
When the screen displays Yamaha release the top key.
If this doesn't solve the issue then it could be a number of things as the keyboard does a self check on startup and will hang if a fault is found. Check each rubber switch is not stuck down or even missing this can cause this issue. Please report back either way.
Dan
Becketts Music Ltd
Apr 28, 2017 | Yamaha Music
Install PSR E413DRIVER
What driver do you want to install?
Jan 14, 2014 | Yamaha PSR-E413 Portable Keyboard
Battery problem. When using batteries, the keyboard shuts off without warning several seconds after it has been turned on or when the keys or buttons are touched. The keyboard works fine when plugged into...
Sounds like the connections may be oxidised. With a long, sharp knife scratch at the metal contacts at each end of the battery compartment until they are shiny,and make sure your batteries have good life in them. If that does not work there may be a broken wire connection inside, or, less likely, a short circuit has occurred that is draining the batteries (I doubt that though)
Sep 27, 2013 | Yamaha PSR-E333 Portable Keyboard
How to fix Yamaha PSR 400 dead keys?
Normally this would be from dirty or broken key contacts.
Apr 19, 2013 | Yamaha YPT400 61 Key Portable Keyboard...
Dead keys yamaha psr e413 keyboard
Dead keys on Yamaha PSR e413 keyboard: Flip keyboard upside down, remove cover screws (use marked cardboard template to remember where they came out), spray suspect key-contacts with fast-drying contact cleaner, (usually a PCB with a matrix of contacts under keys), re-assemble base cover, wiggle faulty keys as far as possible to 'scrub' any dirt or oxidization. If this cleaning trick doesn't work, get a pro to check it.
Dec 08, 2012 | Yamaha PSRE413 Keyboard
Yamaha psr-280 flashing display no key response or sound. Is it dead??
Your adapter should be a 12 volt DC delivering 2 amps (2000 ma). If the adapter is too small, you will have the symptoms you are seeing. Make sure the polarity is correct. DO NOT use the so called "universal adapters".
Apr 13, 2011 | HQRP AC Adapter / Power Supply for Yamaha...
Feb 12, 2010 | Yamaha Full-Size Keyboard
Yamaha PSR-E333 - 61 Key Portable Keyboard Logo
70 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
