Question about NEC Versa SX Notebook
Displays wrong region - NEC Versa SX Notebook
    Problem Solver:
  • 14 Answers
Open Region and Language by clicking the Start button displays wrong region - 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, clicking Control Panel, clicking Clock, Language, and Region, and then clicking Region and Language.
  1. Click the Location tab, select your location from the list, and then click OK.
Posted on Dec 06, 2013
When i put in a dvd i get a message wrong region,is there a fix for this problem
You should be able to unlock all regions on your standalone DVD player using a series of keys on the remote this will unlock it to region 0
1. Switch on the DVD and open the tray.
2. From remote . Press four times zero : 0000 + (the digit for corresponding region , e.g 1 for region 1 , 2 for region 2 and similarly ----- 0 for region free
(This means if you want region free settings then u need to press 00000 or for region 1 : 00001)
3. Message will be displayed on screen saying region 0 which means the DVD is region free !!
You can check the region by open the tray and pressing the display button on the remote
I suggest you try THIS is the above doesn't work
Jan 04, 2010 | Philips DVD634 DVD Player
PHILIPS DVD player 616K, how to change region or get into right region. my player was working OK. Suddenly it stopped functioning and showed/diplayed '' wrong region'' on the TV screen.
Changing the region code for DVD616K :
1. Press OPEN/CLOSE, and wait for the tray to open.
2. Use the remote control to input digital key '1', '1', '1', '0' in that order
if that dont work go 1, 1 1, 1 in that
order.
Kindly leave a few seconds between each entry, the microprocessor is slow
with these entries.
3. Press number '7', '8' or '9' to display the current region code of the DVD
player.
OR
4. Press any number of '0' to '6' to set the required region code. The OSD
will display the new region code of the DVD player.
5. Region '0' will be the setting for multi region
6. The region setting will be saved in the FLASH memory.
7. Press OPEN/CLOSE again, the DVD player will return to normal operation.
note: you want to chose region 0 so u can use all regions
Nov 15, 2009 | Computers & Internet
Can i make it region free?
HELLO
Turn on your DVD Player
Press OPEN on remote
Press 1 3 7 9 and the number of the region you want to use between 0 and 6. Use 0 for region free. You may need to press these buttons slowly. You will see XXXX on the TV. When you press the last number, it will display at the top left of the screen.
Now insert a disc (other than your own region) into the player and close it. It should load and play. Other region discs should play as well. If you didn't do it correctly it will display "Wrong Region".
When you turn off the DVD player it will keep the settings.
HOPE THIS HELPS ENJOY (:-)
Oct 11, 2009 | Daewoo DVG-9100N
Wrong region when playing dvd
Well u r having a problem with Region Code issue.Either ur DVD is frm another Region or the DVD playeris frm another region.DVD players is blocked to a Specific region.
May 15, 2009 | NEC MultiSync LCD225WXM - Flat panel...
DVD Player D1816 shows Wrong Regional Disc message
Many DVD players are preset to one region and if you use a DVD destined for any other region, the player will refuse to play. Some players have the option to change this to universal mode. Check your player's manual if yours has this facility.
Yes. You can play VCD movies and and Audio CDs on most players.
Mar 18, 2009 | GPX D1816 DVD Player
Want to unlock Philips DVD player (DVP320)
Did you follow these instructions exactly? If you pressed 9990, as you mentioned, it will not work. You need to press 99990. Do you see region "0" on the display?
start the player without any DVD in it.
open the lid.
while the lid is open press 9,9,9,9,0
you should see region 0 displayed.
close the lid.
Your DVD player is now region free.
note:
replace 0 with 1 to 6 at to set the wanted region number if needed.
Mar 05, 2009 | Philips DVP320 DVD Player
Wrong Region message
This will make the player region free so it'll play anything. It worked on mine and i have the same player.
remote control :
- Press "System Menu" key to enter Set Up menu.
- Move to "Preference Page" using arrow keys to the left or to the right.
- Press the following sequence in the remote control: 135566
- A menu indicating "Region Code" will appear.
- Change region using arrow keys to top or down. Region Code = 0 will play all regions.
- Press "System Menu" key to exit Set Up menu.
Jul 14, 2008 | Philips DVP5982
DVD Wrong Region
Turn on unit
Select DVD
Open tray
Press 0520 then in sequence press arrow up, down, left and right
Enter desired Region Code ( 0 for multi region)
Press Enter to exit
Jul 04, 2008 | Sanyo DVW-5000 DVD Player/VCR
Wrong Region
I'm living in Brazil.
I have a Home Theather Systems Philips Model HTS3565D and when i put on a DVDs show me in display Wrong Region.
Here in Brazil the DVDs are 4 Region.
Can you help me to modify in Remote Control the Region for 4?
Thank you very mych!
Elaine
Nov 05, 2007 | Philips Audio Players & Recorders
Wrong disc displayed
try to find crack for region code and set it up to be region free. that should do the trick.
Aug 14, 2007 | Yahoo Diamond Vision DVDC803-04 DVD Player
NEC Versa SX Notebook Logo
55 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
