Question about Phonic Powerpod 740 Plus S715 PA System
Phonic 740 amp shut down - Phonic Powerpod 740 Plus S715 PA System
How to connect speakers to phonic mr3243 mixer
You would connect the xlr left and right outputs to a power amplifier and then the speakers to the power amp. The mixer will not drive a set of speakers by itself.
Jan 19, 2015 | Phonic Music
Asio driver download
I use a 16 bit 44.1/48k phonic interface with ASIO4ALL, just search this on the net and down load.
Oct 27, 2013 | Phonic Music
I am needing to replace my piezo drivers for the S715 cabinets and they are 8 ohm 15 watt drivers. Will these cabinets only safely handle 15 watts, or can I replace them with higher wattage drivers? I am...
No worries here, in fact you can attach a non-piezo hf driver, coupled with a 2.2uf/3.3uf MKT filter and that should do the job with ease, even better than with piezoelectric devices, hope this helps...
Sep 14, 2013 | Phonic Powerpod 740 Plus S715 PA System
Sound keeps turning off after ten muients
I've had this problem with other sound equipment. For me, it was a heat issue and there was an auto shut off feature to save the unit from over heating. I would especially think this is the case if it turns back on without problem after another 10 minutes of being off.
You could try turning off phantom power if it isn't needed to run your mics. Or making sure it is in a spot that allows maximum air flow through the head.
Hope this helps! Don't forget to rate!
Jun 26, 2012 | Phonic Powerpod 740 Plus S715 PA System
Phonic 865 amp completely dead
Check the bridge rectifier diodes for an open condition. Also check to see if the filter capacitor is heating up- if it is, replace the cap as it is shorted and the reason for no power. It may show signs of leakage already.
Jan 27, 2012 | Phonic Music
Trying to get my phonic helixboard 12 mk II to link up too my vista laptop via firewire
Here is the system requirements cut and pasted from manual:
• Microsoft�������������������������®Windows®XP������������SP1 and SP2
• Available FireWire port
• Intel Pentium������������������������������������������������®4 processor or equivalent AMD Athlon processor
• Motherboard with Intel or VIA chipset 5400 RPM or faster hard disk drive (7200 RPM or faster with 8 MB cache recommended)
• 256 MB or more of RAM (512 MB recommended)
You will note that Vista is NOT listed. Best thing is to backstep your laptop to XP operating system.
Jul 31, 2010 | Phonic Helix18fw 18 Channel Mixer with...
Phonic Helix Board sound problems
You don't specify which model Phonic mixer in question.
Is it a powered mixer ? And are you plugging your speakers into the speaker outputs ? If it's not a powered mixer and you're plugging speakers into the Line Outputs, you're not using a power amplifier between the line outputs and your speakers - this won't work.
If it is a powered mixer and you are plugging speakers into the speaker output connectors and still getting little or no sound, check your speaker cables and the speakers themselves by plugging them into known good amps.
Jul 03, 2009 | Phonic Helix18fw 18 Channel Mixer with...
Phonic Powerpod 740 Plus S715 PA System Logo
53 people viewed this question
Top Phonic Music Experts
Ben Armstrong
NOEL
NOEL
Are you a Phonic Music Expert? Answer questions, earn points and help others
