The fan blows but condensor not ruuning. service people have changed cappasitor,circut board,replaced evapor coil(leak),pressures just fine. the unit will work poperly for about an hour then only fan
The fan blows,but condesor not running
  • sunray1958 Apr 24, 2009
    this has been going in since nov. i have a home warranty and the service man came out and changed run cappasitor,voltage board,compressor start assist. then found leak in evaporator and changed evapator. the problem still persisted. he changed the voltage board again. when i turn the unit on it works properly for about an hour then inside fan continues to blow but ouside unit doesn't run. after about 4 or 5 hours i can start unit again and sme cycle. the service guy is baffled
  • Ken Bledsoe May 11, 2010
    Do you have volt ohm meter?
  • 24 Answers
Could be the run cap for the condensor is bad. If you got a multimeter you can test it.
Posted on Apr 24, 2009
GE bottom freezer stopped cooling
The unit needs two fans running and good airflow, one fan outside cools the condensor coil and the other inside the unit blowing across the evaporator. The compressor must start up. The defrost timer stops everything and switches on a heating element to defrost the evaporator for several minutes. Please verify these conditions.
Jan 24, 2015 | GE Profile PGCS1NFZSS 20.7 cu. ft....
Tip
Freezer not working, things to check
The unit needs two fans running and good airflow, one fan outside cools the condensor coil and the other inside the unit blowing across the evaporator coil, warming it. The compressor must start up. The defrost timer stops everything and switches on a heating element to defrost the evaporator for several minutes. Please verify these conditions. The condensor coil may get clogged with dirt and lint, the evaporator may get clogged with ice build up, or the fan may quit working due to bad bearings, need for lubrication, or burn out. The defrost timer has an internal motor and contacts which may quit working, some have a way to manualy turn it to switch its mode in case it quits working.
on Feb 11, 2015 | Freezers
Sub zero 642 refrigerator not cooling
Being a sub zero tech and actually fixing that exact model earlier today I would recommend you call a qualified service tech to come take a look. If not, I'll tell you the steps I would take to isolate the problem. 1) check to see if the refrigerator fan, also called the evaporator fan, is running. Just open the door, hold in the switch next to the light switch and listen. You'll hear it easily if it is. 2) If fan is running remove the grate up top, the one you took off to put the condensor fan motor, and see if the right side compressor is running. Don't always go with if its vibrating its running because the freezer compressor or the condensor fan can cause it to happen. Find the high side, or condensor line which is the smaller that comes out of the compressor in the back and runs up front to the condensor, and feel if its hot. Hot = good, cold = bad. Note that all this can be avoided if you have a set of freon guages because that model has access taps already on them. They are wrapped in yellow. If you have guages unscrew the cap and connect the guages. On the outside numbers the needle should be around the 25-30 on the positive side. If its in the green area, the negative, around the 10 you need some freon, and possibly have a micro-leak that needs repairing. If its down in the -20 to -30 area you have a serious leak, more than likely in the evaporator inside the fridge, and you should relay call a tech. Now if the needle jumps way up to 70 or 80 and the compressor is hot, really bad, call tech. and if it does that and is cold, the compressor is just off. Now if your still with me and stuck through this far i'll give you the cliff notes.
If the temp is 55 that mean the fan inside is running, and that more than likely the compressor. Now here are some questions to ask yourself. Are the condensor coils clean? That would raise the temperature. You just changed the condensor fan motor, did you put the blade back on right? If the air flow is blowing across the compressor in the direction of the freezedr compressor, your blowing really hot air from the condensor across the compressor and your temperature will raise badly. Fan draws air across the compressor and through the condensor. Worse case scenario you jacked the control board up inside, which I dont think is the case either. ** check that fan blade **
Apr 29, 2012 | Sub-Zero 642
For my thesis: 5 condenser problems and 5 solutions
Problem number one.
condenser fan won't come on. solution check the capacitor if good ohm out the fan to see if it is bad. If bad replace fan motor with new one.
2. compressor will not come on. solution check the contactor to see if engaging this applies to problem 1 also. If engages check the capacitor on the herm side if it is bad replace. If good check compressor to see if the compressor is bad. Should it be bad replace compressor.
3. High head pressure not cooling properly dirty condenser coils. Clean coils. With hose and water.
4. Low head pressure frosting accruing on suction line. Check freon levels. Also check inside air filter for being dirty.
5. Condenser unit is failing to come on. solution check the power source check the contactor should the main power be bad check main breaker and replace any slow blow fuses that are bad. Should the contactor be bad check transformer to ensure 24 volts going to secondary side on contactor. Inspect the two wire going to outside unit condenser. replace any broken wire any bad transformer or bad contactor.
Feb 21, 2010 | Carrier 38CKC042 Air Conditioner
2 year old Coleman Mach III tapping and not blowing cold air:
Make sure the condensor fan is blowing through the condensor on the roof. It sounds like the compressor is fighting high head pressures after running a bit.. After so many attepts, or if it suceeds in operating the load trips the circuit breaker.. Make sure the condensor is clean and air is passes through it from the fan. Just for clarifiication the condensor is the coil that gets hot and the evaporator is the coil yat create the cold air. Good Luck, and if you will, let me know how it turns out. Good Luck. Ned
Sep 19, 2009 | Dometic Rooftop RV Air Conditioner
Unit seems to work fine, but NO COLD!!!
If the compressor kicks on and runs fine, this usually indicates that the freon in the system is good. Is there anything else that can obstruct the air into the unit or into the cabin? I believe that this refrigerant will be R-22, and may be difficult or impossible to purchase without a license. I also think R-22 is sold in cylinders larger than you'd want. Check in your unit, though. If, by some slim chance, it is R134a, you CAN buy and install this yourself, but, again, I doubt it is. Your best bet would be to have a local technician put the gauges on it and recharge it. Be sure to check for leaks. If you're losing refrigerant, you need to get the leak stopped, or you are going to just throw your money away.
Best regards, --W/D--
Jul 31, 2009 | Dometic Rooftop RV Air Conditioner
Ge tpx21pr side by side refig/freezer Freezer is not cold enough
If your unit is NOT a static condensor, (the type with cooling fins and tubes on the outside of the back of the unit) If the door seals are okay and sealing properly, you might need to service the forced air condensor components located at the rear lower area, usually behind a fiber board cover. Remove the cover and look for dust on the condensor fins and fan blades. If clogged, carefully brush, vacuum, or blow the dust out, opposite the direction of the fans natural air flow direction. (You don't want to lodge the debris further into the condensor fins.)..Be sure to unplug the unit first.
Jul 31, 2009 | Refrigerators
Tube running from AC unit to the house is completely encased in ice. Does this mean the unit is bad ? Or, does this mean there is a freon leak in the tubing ? And, is it cheaper to replace to unit or try...
You either have a refrigerant leak or a dirty inside coil or a slow running inside blower motor.
Set the thermostat for heat and run it until all the ice is thawed. Then check the incoming air side of the coil for lint and dirt. Check the fan motor for proper speed. If you have service gauges your low side pressure should be approximately 68 psi. If lower you have a leak.
Jul 07, 2009 | Carrier 38CKC030 Air Conditioner
Fan runs but condesor not running
1. First refill the gas. Gas seems to be overcharged than the recommended value. If the gas is OK
Than,
2. There is an overload in the compressor, when it takes more then recommended amperes of current overload shuts the compressor.
Than need to change the compressor.
Apr 24, 2009 | Bryant 462AJC021BA Air Conditioner
Teco split system freezing up.
When you reversed it the fan stop because it went into defrost mode,Change the filter,clean the coil,let it thaw,and if it happens again,it may have a clogged cap tube or a leak in the system.
Please rate this solution.
Jan 20, 2009 | Samsung AW1203B Air Conditioner
Heating & Cooling Logo
77 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
