Question about Kenwood IM200 116 Quart Ice Cream Maker
Freezes fine, but Paddle not turning on ice cream maker.
Does the paddle in the cuisinart Ice 21 ice cream maker suppose to move
yes, the paddle moves to stir the concoction and make it into iced cream.
Mar 31, 2013 | Cuisinart ICE-21 Ice Cream Maker
The paddle in my new 1.5 L ice cream maker is not turning - is this normal?
Hello Maryo803,
It is not normal for the paddle not to move in these units. First we have to determine weather the paddle is striped or the gear is stripped. At the bottom of the paddle there is a hole that attaches to the turning gear on the machine. Look and see if it still matches the sprocket in the bottom of the ice cream maker. If it does not still match I would suggest buying a new paddle. You can purchase a new paddle from Cuisinart for $8.00 and here is a link to the page. http://www.cuisinart.com/parts/ice_cream/ice-20.html
However, if it is not the paddle please post back to this thread and I will see if it is worth changing out the bottom gear.
Thank you for choosing FIxYa.com
Justin
Mar 11, 2011 | Cuisinart ICE-20 Automatic Frozen Yogurt...
Dose the paddle inside the pot turn? the pot is turnning but not the paddle.
The paddle is stationary while the pot turns the ice cream to mix the cream.
Jun 30, 2010 | Rival 8804-BL 4 Quart Ice Cream Maker
When plugged in& on cylinder turns but paddle
... as it should
When making ice cream,make sure your ice is crushed fine and you use enough rock salt.
Sep 27, 2009 | Maximatic Elite 4 Quart Ice Cream Maker
Is the paddle supposed to turn all the time?
This just popped up on my screen. Are we talking about a ide cream maker? IF yes ... generally, the can revolves around the paddle. The paddle doesn't move.
Hope this helps.
Sep 06, 2009 | Magimix 2200 Gelato Chef 1.03 Quart Ice...
Cuisinart ice cream-frozen yougurt maker& sorbet maker CIM 60 series
I have the same problem, but it seems that it has gotten worse with time. When I first bought this product 6 years ago it worked fine, now the bowl won't freeze entirely and it has been in the freezer for two days (at the lowest freezer setting). I am wondering if the freezer bowl has a life span.
Aug 03, 2008 | Cuisinart ICE-20 Automatic Frozen Yogurt...
I purchased a rival ice cream maker. I used it once and the ice cream came out great. The next time I used it the paddle didn't turn and the ice cream and paddle was frozen to the sides of the can. The...
The tub turns around the dasher(paddle). You live in a high humid area... to much ice and salt around outside. Plus you need to age the ice cream a few hours after mixing. See your book.
Jul 07, 2008 | Rival 8550-X 5 Quart Ice Cream Maker
Musso Ice cream maker freezes and then heats up during use
go to Http://www.catering-machines.com they have full list of spares or parts for Musso stella.
All parts for the musso ice cream machine including lid, motors, gear wheels, gearbox, musso paddle Musso serial numbers start L1 = Musso piccolo L2 = Musso stella L3 = Musso Club L4 = MUSSO CONSUL.
Jan 14, 2008 | Musso Stainless Steel Pola Ice Cream Maker
Deni blueberry 5201 Ice cream maker...
While I can't tell you where to buy a replacement paddle, I can tell you we just bought this model of ice cream maker through Heartland America for $30. If all else fails... Hope this helps!
Jan 12, 2008 | Deni / 5201 / 5202 / 5203 / 5205 Ice Cream...
Paddle not rotating
The paddle is supposed to scrape the frozen mix off the inside of the can as it turns. So yes, that sounds right.
Oct 18, 2007 | Rival 8420-TB 4 Quart Ice Cream Maker
Kenwood IM200 116 Quart Ice Cream Maker Logo
61 people viewed this question
Top Kenwood Ice Cream Makers Experts
ray gallant
Are you a Kenwood Ice Cream Maker Expert? Answer questions, earn points and help others
