How to open UC 280 speaker. I need to connect the broken wire.
4 Suggested Answers
osborne382
  • 306 Answers
SOURCE: Durabrand uc-280 don't work!
go to device manager locate the speakers, right click and update drivers, if that fails search google for that sound card driver.
Posted on Nov 12, 2007
  • 56 Answers
SOURCE: durabrand UC-280
do windows updates and choose to download the driver for your soundcard. if they're not on the windows update, then try to go to the manufacturer's website to download the soundcard driver.
Posted on Jan 09, 2008
trugreenguy
  • 10 Answers
SOURCE: Computer Speakers
Try turning the volume on the computer volume control up and turn the volume control on the speakers down, or try the other way, turn the volume control on your speakers up, and the volume control on the computer down. I've had this problem before and this was the way I found a resolution.
Posted on Jan 10, 2008
How do I open a UC-280 2.0CH USB Powered speaker system to reconnect the broken cable.
Once you open the speaker it will destroy the acoustic properties and make the speaker useless. The speakers are assembled with takp and glue and have to be pried apart.
Mar 14, 2015 | Audio Players & Recorders
My UC-280 speakers worked well for last 5 years. But now wire connection to the left side speaker has broken. Now I need to open the speaker to fix the broken wire connection. I could not find any screws...
first,i never seen uc 280 speakers & dont know if it is a wood or a plastic speaker enclousure. 1. try looking 4 screws again, you might have missed them 2. if you sure there are no screws,you may have a plastic speaker box that was put together with crazy glue. in that case you will have to look for seams to crack or pry with two large flat bladed screwdriver or two very stiff puddy knifes. if you cant find a seam good enough to get a screwdriver into to start the pry job, you will have to take a stiff thin bladed knife that you dont mind ruining the looks of and heat the blade
red with a propsine tourch $12.00athome depot or a gas stove
burner will do & saves you $12.00. even an electric stove burner might work if you put the knife blade on the burner & a heavy black cast iron fry pan in the top of the knife blade.
anyway,one you get the knife blade or flat screwdriver tip hot,you can ment a slot through the plastic enough to get a pry started.
by now you realize that we are going to make somewhat of a mess of your speaker box, but if it is crazy glued together,this is all that can be done about getting it apart.right now,you dont have a working speaker. you may end up with a working speaker that looks like it survived world war 3 in bad shape, but best I can do,so sorry.if you can pry it appart enough to get inside and reconnect the wire, the test to make sure speaker does work,we ate ready to glue it back together. A hot melt glue gun from you local dollar tree or dollar store will do the trick or a tube of crazy glue.alternately,you can use the engineering llc solution
which is ,if its susposed to move and dont, use wd40 but if its not susposed to move but does,use duct tape.
so you can use a good grade of duct tape to hold your speaker box together with,if need be.
in the past,we have used hot melt glue gun to reattach the plastic front of a vw passat so it would be flush with the front fenders when a sheet metal screw didnt work good. used the hot melt to keep the sheet metal screw from coming out and to hold the edge of the plastic in flush to the fender edge. god help who ever takes that apart again. hope he is a good problem solver because that vw solution was from mickey mouse enginenering, llc
Oct 13, 2013 | Audio Players & Recorders
UC-280 speakers volume control not working
I purchased my new PC at Walmart. They did not know that the moniter had builtin speakers. My problem is solved. Thank you
Jan 26, 2009 | Creative Labs SoundWorks SW320 Computer...
Durabrand UC-280 Speakers not working. I think it is a spec in my PC (which is operating on Windows XP) that I cannot find.
Did you try reinstalling the sound driver for the speakers? That should work.
Let me know how it goes bro.
Jul 24, 2008 | Computers & Internet
Uc-280 speakers make noise
check connections and cables.
May 03, 2008 | Computers & Internet
Can't get my durabrand uc-280 computer spreakers to work
Check the volume on the systems itself. The difference of hardware won't matter has long as you have the correct driver for each hardware. Just check the volume & still doesn't work GET BAC @ME.
KJ
Apr 22, 2008 | Audio Players & Recorders
Speakers
I uninstalled realteck and then reinstalled it.
Mar 20, 2008 | Audio Players & Recorders
Returned the durabrand uc-280 to Walmart! Plugged the existing speaker into the correct hole in my new sound card. Problem solved!
Feb 16, 2008 | Audio Players & Recorders
Durabrand UC-280
Jan 07, 2008 | Audio Players & Recorders
Nov 12, 2007 | Audio Players & Recorders
 Grubhead
Grubhead
