Question about Insignia 42" LCD Flat-Panel HDTV
Digital audio output tv
What does this do?
    New Friend:
The digital audio output can be used with a surround sound system.
Posted on Nov 03, 2013
    Scholar:
    New Friend:
  • 118 Answers
Digital audio refers to technology that records, stores, and reproduces sound by encoding an audio signal in digital form instead of analog form. Sound is passed through an analog-to-digital converter (ADC), and pulse-code modulation is typically used to encode it as adigital signal. A digital-to-analog converter performs the reverse process, and converts the digital signal back into an audible sound. Digital audio systems may include compression, storage, processing and transmission components. Conversion to a digital format allows convenient manipulation, storage, transmission and retrieval of an audio signal.
Posted on Oct 16, 2013
I have a Sharp Aquos LC-60LE640X TV and I am trying to connect a Samsung HW-H751 Soundbar to it. I have hooked up the optical cable, adaptor and sub woofer, I have tested the Bluetooth function throug
If you are connecting the soundbar to your TV with the digital audio cable, make sure to select "D IN" using the source button on the soundbar. Bluetooth (BT) is a separate source from another device. (phone, etc.) The TV will need to be set to use the digital audio output and probably PCM format. (?) The subwoofer is preconfigured at the factory to mate up with your soundbar. (See below instructions - your soundbar includes the amplifier:)
Digital audio output setting:
After connecting an amplifier with digital audio input and
external speakers as shown, you should set an audio
output format compatible with the programme you are
watching or the device connected.
Go to "HOME" > "TV Menu" > "Setup" > "Option" >
"Terminal setting" > "Digital audio output" > select
"PCM" or "Bitstream".
NOTE
• When set to "Bitstream", Dolby Digital is output when the Dolby
Digital or Dolby Digital Plus audio formats are received. When
set to "PCM", PCM is output no matter what audio formats are
received.
• When set to "Bitstream", HE-AAC audio formats can be output
as Dolby Digital.
Jan 24, 2015 | Sharp Aquos Televison & Video
I just purchased a Coby TV Model number TFTV 3255. I am very happy with the set. However it has only ONE audio output. The manual, on page 7, "coaxial output" ,an optical audio cable is required....
If it is a single output and looks like an RCA type, then I would say that the cable you would need is a digital coaxial cable. The optical input/output will have a different shape and is not as big of an opening as a digital coaxial input/output.
Mar 01, 2011 | Televison & Video
I have a problem with hiss coming from the sound bar (ZBase 550 HSD) when using my digital cable box. It is not an issue with PS3 etc. I have the sound on the cable box turned to max, but I still hear a...
Hello ZVOX Owner,
The hiss you hear is generated by the analog audio output of the cable box. The best way to eliminate this hiss to use the digital output of the cable box. The preferred way to do this is to connect the digital audio output of both your cable box and your PS3 to the your TV (I presume your TV has two digital audio inputs.)
Your TV has a digital audio output. You should connect the digital audio output of your TV to the digital input of the ZVOX.
This should reduce or eliminate the hiss and provide convenient video source selection via the TV.
From Fred P. at www.zvoxaudio.com
fred@zvoxaudio.com
Jan 27, 2011 | ZVOX ZBase 550 HSD Lowprofile SoundBase...
I hava a insignia dvd receiver is-htib102731 and want to know what optical digital audio cord to buy for sound on my tv
gailsplaytim,
That really depends on what audio inputs you have on your tv. Your Insignia has composite audio outputs (Red and White) and digital coaxial and your tv most likely will have at least composite inputs.
The easiest way to connect your dvd to your tv is just to use the composite as you will not hear the difference in sound quality between the two through the speakers built into your tv.
If you want to run digital audio into your tv for a reason such as the tv's audio output is running to another device like a receiver and you want the digital audio to transfer, you need to look at what digital audio inputs you have on your tv. The only digital audio output on your dvd is a digital coaxial. You can buy digital coaxial converters online. If your tv for example has a toslink input, there are digital coaxial to toslink converters relativity cheap online
-Chris.
Feb 28, 2010 | Electronics - Others
How to connect my kenwood vr-606 digital audio to my tv... i tried to connect digital audio cable from my tv digital audio output to kenwood vr-606 receiver digital audio in and it's not working.. what did...
Your TV is NOT an audio source by itself. It's job is to make pretty visual stimulus for your eyes, not your ears. Everything IT hears comes from somewhere else like a DVD, BluRay, Cable Box, right?
Get the absolute best TV-related audio directly from the digital audio outputs of each source you're watching, not the TV.
Feb 19, 2010 | Kenwood VR-606 Receiver
My PS3 will not play sound on my Sony Bravia HDX275 surround sound system. I have the HDMI cable plugged from the PS3 to the TV. I have another HDMI cable from the receiver to the TV as well as a opitcal...
Adjust the system's audio output settings. These settings are mainly used when the system is connected to audio devices that support digital audio output, such as AV amplifiers (receivers) for home entertainment systems.
1.
Confirm the formats supported by your audio device.
Settings vary depending on supported formats. For details, refer to the instructions supplied with the audio device.
2.
Select in_soundset.gif (Sound Settings) under in_setting.gif (Settings) in the home menu.
3.
Select [Audio Output Settings].
4.
Select the input connector on the audio device. Channel numbers and audio formats that are supported vary depending on the connector in use.
soundoutput001.jpg Input connectors on the TV or AV amplifier (receiver) PS3™ system output connectors Channels that can be used for output 2 Ch. 5.1 Ch. 7.1 Ch. HDMI HDMI OUT connector in_maru.gif in_maru.gif in_maru.gif Digital Out (Optical) Digital Out (Optical) connector in_maru.gif in_maru.gif - Audio Input Connector / SCART / AV MULTI AV MULTI OUT connector in_maru.gif - - 5.
Select audio output formats.
Select all output formats that are supported by the audio device in use. If [Audio Input Connector / SCART / AV MULTI] is selected in step 4, the screen for selecting audio output formats will not be displayed. If [HDMI] is selected, you can also select to automatically set the audio output format. (In this case, the HDMI device must be turned on.)
soundoutput003.jpg 6.
Check your settings.
You can go back to the previous screen and revise the settings by pressing the in_left_key.gif button.
soundoutput002.jpg 7.
Save your settings.
The audio output settings are saved on the system.
Hints
  • [Linear PCM 2 Ch.] audio is set to be output from all output connectors by default. If you change the audio output settings, audio will be output only from the connectors that were set.
  • If you change the audio output settings, the system will no longer be able to output audio from multiple output connectors at the same time. For example, if your system is connected to a TV via an HDMI cable and to an audio device via a digital optical cable and you switch to [Digital Out (Optical)] under [Audio Output Settings], audio will no longer be output from the TV. To output audio from the TV, switch the setting to [HDMI], or select in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Multi-Output] and set the option to [On].
  • If you select [Linear PCM 2 Ch. 88.2 kHz] or [Linear PCM 2 Ch. 176.4 kHz] in step 5, sound may be intermittent or may not be emitted from some audio devices.
  • When using an HDMI cable, only [Linear PCM 2 Ch.] audio will be output from PlayStation®2 and PlayStation® format software. To output Dolby Digital or DTS audio, you must connect the PS3™ system and the audio device using a digital optical cable and switch to [Digital Out (Optical)] under [Audio Output Settings].
  • If a device that is not compatible with the HDCP (High-bandwidth Digital Content Protection) standard is connected to the system using an HDMI cable, video and/or audio cannot be output from the system.
(Information taken from here)
Hope it helped.
Nov 18, 2009 | Sony Playstation 3 (PS3) Console
Dvp5960 hdmi set up issues
You can disable the digital audio output in the audio tab at the setup menu.
Apr 11, 2008 | Philips DVP5960
TV upgrade in my Motor Home
You have to convert the coaxial digital output to non digital right left output! this is done with an adapter which you can get from EBay for $7.79 and free shipping! go to mEBay and search Toslink Digital coaxial signal to Analog converter audio adapter rca! good luck!
Jun 10, 2017 | Sony XR-CA330 Cassette Player
LCD HDTV digital audio output jack
The orange jack is a DIGITAL audio out and cannot be hooked to anything other than a digital input. You want to use the White/Red jacks at the bottom.
Sep 12, 2007 | Digital Audio 5-OUTPUT COMPONENT VIDEO...
Insignia 42" LCD Flat-Panel HDTV Logo
107 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
