Question about Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac
I replaced both broked fuel lines and it still doesn't start.
My Poulan TE 450 CXL shut off one day with leaking fuel at broken line so I replaced both lines and it still doesn't start, sometimes it starts for few seconds but it shuts off again.
  • aevasica Apr 24, 2009
    This is a weedeater it has a small hose from tank with fuel filter in bottom of tank and a larger hose from carb to tahk.
    Problem Solver:
  • 15 Answers
Make sure the line is connected to the fuel cap if it has a pump ball.
Posted on Apr 24, 2009
1950 poulan
Open fuel tank, pour out fuel on clean flat area (away from any flames or spark sources) then check the 2 plastic hoses inside. One should have a fuel filter on it's end. The plastic these lines are made seams to disintegrate so, filter may not be attached and lines may be broken off. Replace them.
Mar 05, 2013 | Poulan 14" Chainsaw
How to replace flexible drive shaft on Poulan Twist n Edge, TE 450 CXL LE string trimmer. I have removed the lower string assembly - can't remove shaft.
Shaft needs to come out the top, will have to split the case or remove motor from shaft to pull cable out
Aug 29, 2011 | Poulan Garden
Poulan Twist N Edge TE 450 CXL - has ran great for 10 years. It still runs great and fires right up every time - except now it will run for about 8-10 minutes, then it will just abruptly die. It then...
Hello, W/D here.
Check the pinhole vent in the fuel filler cap. As fuel is removed when the engine is running, air is pulled into the tank. If the vent is blocked, a vacuum is formed, and fuel cannot flow. After a period of down time, air infiltrates back into the tank, and the engine can be re-started. You can test this out just by cracking the cap open after starting the engine, just enough to allow air to get into the tank.
Best regards, --W/D--
May 02, 2011 | Poulan 17" T&E Gas Trimmer
Both lines came off of the posts on a te 450 trimmer. which line goes where?
I presume you mean fuel lines. The return (without fiilter) line goes nearest the primer bulb. The supply (which has the filter attached inside the tank) goes on the further nozzle from the primer bulb.
Nov 28, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Replace string on trimmer
Hi
check in you tube .
The video is talking about trimmer strings in general , but my experience is that all trimmers are more or less the same.
hope it helps
http://www.youtube.com/watch?v=WFu66Q6J62Q
Jul 16, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Need instructions on how to put line in Poulan Twist N Edge TE 450 CXL weed eater.
Dear FixYa Fan, Friday 2-20-2009 10:37pm EST (USA)
RE: Poulan Lawn Trimmers
Poulan Lawn Trimmer FAQ @
http://www.ordertree.com/cms/Poulan+Trimmer%2c+Blower+%26+Edger+FAQ/241.html
Dear jebkillion: You will find instructions for putting line on your trimmer at this link http://www.ordertree.com/cms/Poulan+Trimmer%2c+Blower+%26+Edger+FAQ/241.html#changeline click on the http line preceding but please rate me 1st or come back and rate me before you close this or the Poulan Site!
Thank You,
jackiaria
Feb 21, 2009 | Garden
Fuel filter nipple broke
get some proof in writing from the retailer noting the issue for future ref.
Feb 03, 2009 | 2008 Husqvarna TE 450
Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac Logo
751 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
