Question about JVC LT-42X579 42 in. LCD TV
Jvc d.i.s.t. lc 32636-001b try to turn on from remote but all I get is a black screen which should be blue,there is sound but no picture.tried un plugging no change but kept switching on & off with remote lots of times &eventualy it comes back on .any idears
SOURCE: JVC 42 INCH PLASMA POWER LIGHT BLINKING ONLY NO PICTURE
no kidding? what is the problem so prevelant in this unit? obvious design flaw.
Posted on Jul 26, 2008
  • 1779 Answers
SOURCE: JVC LCD TV LT-42X688-powers on, blank screen. no picture,no sound
You most definately have bad capacitors in the power supply. try and get it repaired as soon as possible, not an expensive repair that iv'e seen.
Posted on Feb 04, 2009
SOURCE: JVC 42 inch LCD HD TV has no picture or sound
utencilio posted this fix. It worked for my JVC LT-42X579.
Okay, I found a fix! Called JVC, spoke to somebody there, here it is:
1)unplug the TV completely, no wall no power strips, completely
2)wait 10 sec
3)plug TV back in and Turn it on, the light will still be doing the same thing
4)wait 30 sec
5)ON THE TV, not the remote, locate the menu, volume (-) and power button.
6)while simultaneously holding down the menu and volume (-) button, pressed the power button ONCE and continue to hold the other 2 for 10 sec.
7)on the remote control, go to menu>settings>system info
*** now this I know as a FACT will work on systems that display: JVC - ver.5.32FO001, but I don't know of any other versions***
8)press the mute button on the remote twice
9)unplugg TV again and wait 10 sec.
10) plug TV in and turn on
It SHOULD be working normally now... Thanx to the guys a JVC support for this one, I know it seems like an obvious first place to look, but sometimes it isn't. I for one checked online forums first
Posted on Mar 08, 2009
  • 105 Answers
SOURCE: JVC LT 42x688 no picture just sound
Sorry, this has no easy fix. The good news is you do not need an LCD Panel. The bad news is the Video Processor has a problem.
This TV has x3 Boards. The one you should replace first is the one in the middle. If this doesn't fix it, try the one on the right. The Part #s are on the Boards if you wanna try ebay.
Posted on May 06, 2009
Hi , I have the same problem with my LT-42X688,so i called the service of my extended warranty provider . the TV technician just left and told me the motherboard is the problem. he said its the third one this week he has seen with the same symptoms. he ordered the motherboard and i've got to wait 5 to 7 work days before the part will be in . I will keep you posted when the guy will return.
Posted on Jul 21, 2009
My tv jvc av 27530 has ablue screen and un able to operate by remote or manually so could you help me please?
many of the late model tvs with a crt (picture tube) would go to a blue screen when there is not signal from the cable or antenna so you don't get the irritating white noise and black and white dots running all over the screen, (called the raster), so probably you aren't getting a signal to the tuner. check your connection from the cable/antenna.
Sep 25, 2014 | JVC AV-27530 27" TV
The television turns on but the screen remains black. i can get it to change channel, lower or raise volume, and i dont have the remote for it. please help.
Tv now turn on?Ur tv have a picture flashes a few sec.before it died.Than tv have sound left only?Yes.Than ur tv the long board that call the LCD inverter board is dead.The long LCD inverter board only job are to provide a tv LCD screen panel a backlight to produce a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish long LCD inverter board for the replacement.Try website like Remotes.com to buy the tv original remote.
Apr 22, 2011 | Sharp LC-19SB25U 19 in. LCD HDTV
Sharp model lc19sb25u sound and no picture screen
Part called main unit failed and require replacement. part number duntke352fm02.
Oct 08, 2009 | Sharp LC-19SB25U 19 in. LCD HDTV
Need Help with tv problem
tiene que revisar la tarjeta de comvergencia
Aug 26, 2009 | JVC AV-48P575 48" Rear Projection...
A black rectangle is displayed on the screen
the black rectangle appears as soon as the channel indicator goes off. someone has turned on the closed captioning in the menu of the set. it is in the "text" mode. go into the menu and turn off the closed caption feature.
Mar 20, 2009 | JVC AV-32320 32" TV
Dog steps on remote and a black screen pops up in the middle of screen but you can see the picture on te outside of the black box. Jvc 32' d-series tv the remote is a jvc rm-c252
Sounds like a closed caption box or a pip box, if not try all the buttons on the remote one by one and lastly try to reset to factory settings if the option is present in menu settings.
Dec 21, 2008 | JVC AV-32S33 32" TV
JVC AV 32120
Sounds like your "CC" (closed captioning) is turned on and it is set to text mode.Go into the menu and turn the closed captioning "off". The default v-chip unlock code is "0000"
Sep 27, 2007 | JVC AV-32120 32" TV
Monitor goes black and both blue lamp blinks
have a tech check your tv there is a fault in tv horizontal circuit.good luck my friend.
Jun 15, 2007 | JVC PD-42V475 42 in. HD-Ready Plasma...
JVC LT-42X579 42 in. LCD TV Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
