Question about HP LaserJet 1320 Printer
HP lasejet 1320 prints duplicate on front and back when in duplex
To clearify my problem, suppose I want to print a 4 page document using duplex. I would expect to have page 1 on the front, page 2 on the back, page three on the front of the second page and page 4 on the back of the second page. Instead I get page one printed on both the front and back of page 1, page 2 printed on both the front and back of page 2 and so on. If I print without using duplex, I get pages 1-4 printed on only the front as expected. I share the printer with 2 computers and am running Windows XP on one and Vista on the other. I have the same problem on both. I also have updated the driver to the latest version, but didn't have the problem until a couple of months after updating the driver. I have not tried going back to the previous driver yet.
Hi I had the same problem on a couple of machines I tried uninstalling and reinstalling but no luck.
Then I changed the Print Processor (printer Properties- Advanced Tab - Print Processor) it was set to HPZPP041 I changed it to Winprint and it worked
Posted on Jun 08, 2009
    Champion:
  • 214 Answers
This is a print dialogue box setting. Have a good look You need to set it to collate sheets with 2 sided printing on (duplex) Im on a Mac
Posted on Apr 24, 2009
Duplex printing in HP 2420dn on Mac OS X Lion 10.7.4
According to the specs, this printer does not have a duplex unit and therefore cannot print double sided prints.
DOUBLE SIDED PRINTING USING A SINGLE SIDED PRINTER
If your printer does not have a duplex unit then the printercannot print double sided pages automatically.
You can print double sided pages but you have to do it one page at a time.
First print Page 1 then place the page back into the paper tray, but turn thepage upside down and the print Page 2.
Then print page 3 on one side then page 4 on the other side and repeat for therest of the document.
I suggest you try a test page first, to get the printing the right way up onboth sides of the page so it reads correctly.
Jul 17, 2012 | HP LaserJet 2420 Printer
How to duplex print with 895cxi
This model printer does not have a duplex unit and cannot print double sided documents automatically.
Jul 08, 2012 | HP DeskJet 895cxi InkJet Printer
Hi there! Printer: HP Laserjet 4100 Problem: does not want to make both side printing. Used settings: Printer Properties->Finishing->Print on Both Sides (click) Thanks for your...
To automatically duplex, you need the optional duplexing mechanism.
If you don't have this, your only option is to print the odd pages first, put the papers back in the tray, then print the even pages.
When you put the pages back into the paper tray, make sure they are print side up.
Try with a 5 or 6 page document first to be sure you get the orientation right.
If you HAVE the optional duplexing unit (which sticks out the front just above the main paper tray) then post a reply here and I'll try to help you further.
99% of the people that own this unit do NOT have the optional duplexer!
Mar 12, 2011 | HP LaserJet 4100 Printer
I want my hp laserjet 1320 to print front and back
Make sure the manula paper feed slot is closed.
Access Printer Properties or Printing Preferences
Select the Finishing Tab
Select Print on Both Sides
Select OK
Then print the document(s)
Nov 10, 2009 | HP LaserJet 1320 Printer
Do pixma Mp610 support duplex printing
The MP610 does support duplex printing.
Duplex Printing
The duplex printing function allows you to print data on both sides of a sheet of paper.
The procedure for performing duplex printing is as follows:
Performing automatic duplex printing
You can perform the duplex printing without having to turn over the paper.
1. Open the printer driver setup window, check the Duplex Printing check box, and confirm that Automatic is checked.
2. Select Normal-size Printing (or Fit-to-Page Printing, Scaled Printing or Page Layout Printing) from the Page Layout list.
3. When printing a document that has small margins, click Print Area Setup... and set the print area.
When you perform duplex printing, the print area of the document becomes slightly narrower than usual and the document may not fit on one page.
sub.gifTo print without reducing the page:
Select Use normal-size printing.
sub.gifTo reduce the page slightly during printing:
Select Use reduced printing.
4. Specify Staple Side.
The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position. Check the Staple Side setting. If you want to change the setting, select another value from the list.
5. If necessary, click Specify Margin... and set the Margin width.
6. Click OK.
Duplex printing will be started.
Performing duplex printing manually
You can perform the duplex printing manually.
1. Check the Duplex Printing check box and uncheck the Automatic check box on the Page Setup tab.
3. Specify Staple Side.
4. If necessary, click Specify Margin... and set the Margin width.
5. Click OK.
sub.gifIf a media type other than Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed on one side of a sheet of paper. When printing is complete, reload paper according to the displayed message and then click OK. The document will be printed on the opposite side.
sub.gifIf Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed front and back alternately for one sheet at a time. Load the paper according to the displayed messages.
caution.gif Note sub.gifDuplex Printing is unavailable when:
- A media type other than Plain Paper, Photo Paper Plus Double Sided or Hagaki is selected from the Media Type list.
- Poster Printing is selected from the Page Layout list.
sub.gifWhen Booklet Printing is selected from the Page Layout list, Duplex Printing and Staple Side appear grayed out and are unavailable.
sub.gifAfter printing the front page, there is an ink drying wait time before starting to print the back page (Operation stops temporarily). Do not touch the paper during the time. You can change the Ink Drying Wait Time at Custom Settings on the Maintenance tab of the printer driver.
sub.gifWhen you perform the automatic duplex printing for Hagaki, print an address first and then print your message.
refer.gif Tip sub.gifIf you select Photo Paper Plus Double Sided for Media Type on the Main tab, the Duplex Printing check box on the Page Setup tab is not checked automatically. To perform duplex printing, check the Duplex Printing check box.
sub.gifIf the Media Type dialog box appears when performing borderless printing during duplex printing, select Plain Paper or Photo Paper Plus Double Sided.
sub.gifWhen performing the automatic duplex printing, do not use any plain paper smaller than A5. Also, do not select any type of paper other than Plain Paper, Photo Paper Plus Double Sided or Hagaki at Media Type.
sub.gifPhoto Paper Plus Double Sided is highly recommended for printing photographs on both sides of a page.
sub.gifIf the back side of the paper becomes smudged during duplex printing, perform Bottom Plate Cleaning in the Maintenance tab.
Aug 17, 2009 | Canon PIXMA MP610 InkJet Printer
HP 1320 duplex printing paper jam
Managed to solve this myself: I disassembled the printer and noticed there was a paper jammed in the duplex tray. Rolls were all ok, but the paper blocked the use of the duplex pathway. For disassembly help check the HP 1320 service manual, which you can find on the net as a PDF.
Jul 14, 2008 | HP LaserJet 1320 Printer
Hp 1320
I want the software of laser jet 1320 printer
May 19, 2008 | HP LaserJet 1320 Printer
Duplexer problem
First, the machine always prints the first page first. Make sure you have the right driver (4 plus and not 4)and check the settings in the device settings of your printer driver on the pc. Also make sure the duplex unit is for the 4 plus and not the 4.
May 17, 2007 | HP LaserJet 4 plus Printer
HP LaserJet 1320 Printer Logo
466 people viewed this question
Seeker5211
Seeker5211
