Question about Motorola Mobility Miniblue H9 Wireless Headset
Motorola H9 Bluetooth headset
I have a recently gotten a motorola H9 bluetooth headset. I was thrilled with the ease of set up and use. I have it paired with the new motorola q9m from verizon. They have paired great and work together as they should. The problem is I am getting static in the earpiece when having a conversation. I have not had any complaints from the people I am talking to so I am assuming it is only on my end. at a range of about 3 feet is where the static is the least noticable but any closer or any further away and the static gets worse. Any ideas? I have tried re-pairing the two with no improvement.
  • Anonymous Nov 27, 2008
    My stepmom recently got this ear piece for her phone and she gave it to me beacause it would autmatically turn off after about ten seconds but now the static will be constant and it is on both ends and it is actually worse on the other end
  • Anonymous Jan 16, 2009
    I have the same issue with mine. It automatically turn off after about ten seconds! And when it does manage to stay on, you can't neither party can hear anything. Very frustrating!
H9 want come on
Posted on May 09, 2009
SOURCE:
Motorola h9 bluetooth
when using bluetooth, the volume adjustment is affected by both the phone and the bluetooth ear piece. Try turning up the volume on both when using it.
Jun 27, 2008 | Motorola Mobility RAZR V3
Need to hard reset motorola mini bluetooth h9
try removing the pairing to your phone and pair again. If this does not work try pairing your headset to another phone and if it does it on that phone then something is wrong with the earpiece return for repairs if under warranty or if you are willing to pay for the repairs if out of warranty or replace ear piece all together as they are reasonably priced these days. If the ear piece works fine the other phone something has gone wrong with the bluetooth side of your phone return for repairs or replace depending on what you can afford to do. I hope this helps.
Aug 26, 2012 | Motorola Mobility H9 Mini Bluetooth...
How do i connect my Motorola Bluetooth to my Nokia 6350
Hi
Please follow the Instruction and set your motorola bluetooth in Nokia Phone
    • 1 Press the Menu button on your Nokia phone and select "Settings" from the available options.
    • 2 Select "Connectivity" from the Settings menu and then "Bluetooth" from the menu that appears.
    • 3 Ensure that the first line on the Bluetooth menu says "Bluetooth On." If the line reads "Bluetooth Off," select the line and change the setting to have the Bluetooth powered on.
    • 4 Power on your Motorola headset and put it in discovery mode. Discovery mode is indicated by a solid (non-blinking) blue light on the back of the headset. You can put your headset in discoverable mode by pressing and holding down the "On" button for eight seconds. In the case of a headset with a sliding on/off switch, simply slide the button to the "On" position and hold it there for eight seconds.
    • 5 Select "Search for audio enhanc" from the available options on your Bluetooth menu.
    • 6 Select your Motorola headset from the list of items that appear. Your Nokia phone will list all of the Bluetooth-enabled devices powered on nearby.
    • 7 Enter the passkey for your Motorola headset when prompted. The default passkey for all Motorola headsets is 0000.
    • 8 Start using your headset with your Nokia phone. The two will be permanently connected, with no need to repeat the pairing process in the future.
Read more: How to Connect a Nokia Cell Phone to Motorola Bluetooth ' eHow.com
Jun 07, 2011 | Nokia Cell Phones
Motorola H710 setup
try video instructions on www.HandBookLive.com under Electronics category. There are video chapters on turning on Bluetooth features and pairing for Nokai and Motorola phones for H710 headset, also chapters on using Bluetooth itself.
Feb 14, 2009 | Motorola Mobility H710 Bluetooth Headset
I recently purchased a new phone that is bluetooth compatible, but I haven't been able to transfer my Motorola H3 hands free ear piece to my new phone without a pass code. Is there anyway you could...
The passcode for the motorola h3 bluetooth headset is set to 0000 by default. I don't think there is a way to change it so your code should still be 0000.
Nov 13, 2008 | Motorola Mobility H3 Bluetooth Headset,...
Broken Earhook for Bluetooth
Hello Retta317,
If it's in warranty? Then contact Motorola and tell them it must have fallen of, or it's just missing and they'll send you out another one (this worked for me recently on a different model BT Head set).
Good luck.
Mar 07, 2008 | Motorola Mobility H350 Wireless Headset
Motorola H550 Bluetooth Headset
Here is the user manual for the bluetooth headset.
User Manual
Pairing with the LG will be similar, your bluetooth settings will be under settings and tools, and either under "bluetooth" or "connections".
Dec 22, 2007 | Motorola Mobility H550 - Bluetooth Headset...
Motorola Mobility Miniblue H9 Wireless Headset Logo
561 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis Webber
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
