My UC-280 speakers worked well for last 5 years. But now wire connection to the left side speaker has broken. Now I need to open the speaker to fix the broken wire connection. I could not find any screws to open the panel. Please help me to open the panel.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 81 Answers
First,i never seen uc 280 speakers & dont know if it is a wood or a plastic speaker enclousure. 1. try looking 4 screws again, you might have missed them 2. if you sure there are no screws,you may have a plastic speaker box that was put together with crazy glue. in that case you will have to look for seams to crack or pry with two large flat bladed screwdriver or two very stiff puddy knifes. if you cant find a seam good enough to get a screwdriver into to start the pry job, you will have to take a stiff thin bladed knife that you dont mind ruining the looks of and heat the blade
red with a propsine tourch $12.00athome depot or a gas stove
burner will do & saves you $12.00. even an electric stove burner might work if you put the knife blade on the burner & a heavy black cast iron fry pan in the top of the knife blade.
anyway,one you get the knife blade or flat screwdriver tip hot,you can ment a slot through the plastic enough to get a pry started.
by now you realize that we are going to make somewhat of a mess of your speaker box, but if it is crazy glued together,this is all that can be done about getting it apart.right now,you dont have a working speaker. you may end up with a working speaker that looks like it survived world war 3 in bad shape, but best I can do,so sorry.if you can pry it appart enough to get inside and reconnect the wire, the test to make sure speaker does work,we ate ready to glue it back together. A hot melt glue gun from you local dollar tree or dollar store will do the trick or a tube of crazy glue.alternately,you can use the engineering llc solution
which is ,if its susposed to move and dont, use wd40 but if its not susposed to move but does,use duct tape.
so you can use a good grade of duct tape to hold your speaker box together with,if need be.
in the past,we have used hot melt glue gun to reattach the plastic front of a vw passat so it would be flush with the front fenders when a sheet metal screw didnt work good. used the hot melt to keep the sheet metal screw from coming out and to hold the edge of the plastic in flush to the fender edge. god help who ever takes that apart again. hope he is a good problem solver because that vw solution was from mickey mouse enginenering, llc
Posted on Oct 13, 2013
Testimonial: "Thank you very much Lawrence for the detailed explanation. It is a plastic speaker. I will try it out your solution."
osborne382
  • 306 Answers
SOURCE: Durabrand uc-280 don't work!
go to device manager locate the speakers, right click and update drivers, if that fails search google for that sound card driver.
Posted on Nov 12, 2007
  • 56 Answers
SOURCE: durabrand UC-280
do windows updates and choose to download the driver for your soundcard. if they're not on the windows update, then try to go to the manufacturer's website to download the soundcard driver.
Posted on Jan 09, 2008
trugreenguy
  • 10 Answers
SOURCE: Computer Speakers
Try turning the volume on the computer volume control up and turn the volume control on the speakers down, or try the other way, turn the volume control on your speakers up, and the volume control on the computer down. I've had this problem before and this was the way I found a resolution.
Posted on Jan 10, 2008
SOURCE: Broken right speaker
Dear Bethann240
It is very difficult to rewire the right speaker( the one with the controls). The black cable contains an orange and black pair which drive the "big" speaker in the base. The white wire has the wires for the controls. That white wire is .090 in in dia. Peel back the white pvc insulation and you will find a layer of aluminum foil which is intended to shield the control wires.Then there is another layer of insulation. Peel that insulation back and you find SIX color coded lacquer insulated wires. Each wire is .010 in in dia. If you attempt to solder the severed wires together you will doubtlessly melt the lacquer and short the cable out. Twisting the wires together without removing the lacquer won't work. The satellite speakers were intended to be non-repairable, thats why the case is glued together.
The best bet is throw the right speaker in the trash and try to purchase a replacement from Altec or find a replacement in a flea market etc.
Sorry
Elder1943
Posted on Jun 01, 2008
SOURCE: can't get my durabrand uc-280 computer spreakers to work
Do you have the proper audio drivers, if not, try downloading them from internet, install driver.
Posted on Feb 13, 2009
How do I open a UC-280 2.0CH USB Powered speaker system to reconnect the broken cable.
Once you open the speaker it will destroy the acoustic properties and make the speaker useless. The speakers are assembled with takp and glue and have to be pried apart.
Mar 14, 2015 | Audio Players & Recorders
Right speaker went out.. Opened fairing and tested speaker by hooking up to left wires... Speaker works so I'm hoping that the wires don't need to be replaced... Any suggestions?
If the RH speaker works when you conected to the LH side, I would suggest a wiring problem to the RH side... You may have to ferret out where the wires go to find a bad or broken connection. It may sound stupid, but make sure you havent got the "balance" control on the stereo set to left only.. Make sure its in the middle so both speakers are supposed to be working... Hope you find out what it is... Cheers
May 29, 2011 | 2007 Harley Davidson FLHX Street Glide
Surround sound speaker outlets are not working
Might be a loose connection problem. A contact cleaner is handy in cleaning the terminals. Try to swap the speaker connections if you don't have a multi-tester to check the resistance of the speakers. If the right front speaker will sound after connecting it to the left front speaker output, then it is a speaker coil problem. If not, might be an amplifier channel problem.
Jan 12, 2009 | Durabrand 5.1 Surround Sound Computer...
I lost sound on one side of bose stereo system., Seems its the power ouput on the right side speaker, i changed speakers and the right one works when plugged into the left output. How do I open the bose...
first lets check
no need to open any thing
1) just trace the wire of working channel and plug out that and connect to opposite side of that channel
for example: if front left is not working, remove pin of front right and plug it into front left
after that listen the sound if front left is working then no need to open amplifier just check the wires of satellite speaker which is not working
how to check broken wire:
1) just observe your speaker nearly if you found any screw holes open it, if u can not find any screw holes remove front net which is fitted by press lock or any stepped groove, you can remove that and if you are removing front net you have to open speaker from casing then after you can find speaker's wire shouldered or bolted to it just check wire and go on after that u'll be sure that weather your speaker is failed or wire!!!
enjoy!!!!!!!!!!!!!!!
(don't forget to rate)
Jan 04, 2009 | Bose Acoustimass 15 System
Uc-280 speakers make noise
check connections and cables.
May 03, 2008 | Computers & Internet
Can't get my durabrand uc-280 computer spreakers to work
Check the volume on the systems itself. The difference of hardware won't matter has long as you have the correct driver for each hardware. Just check the volume & still doesn't work GET BAC @ME.
KJ
Apr 22, 2008 | Audio Players & Recorders
Speakers
I uninstalled realteck and then reinstalled it.
Mar 20, 2008 | Audio Players & Recorders
Durabrand UC-280
Jan 07, 2008 | Audio Players & Recorders
Nov 12, 2007 | Audio Players & Recorders
222 people viewed this question
 Grubhead
Grubhead
