Question about Cell Phones
I have a galaxy s 3 that will not charge from any charger. Is there a way to slice a charger and hook it straight to the battery for now?
    Master:
  • 193 Answers
Alot of the low end tablets such and older galaxy mach g2 etc suffer from cheap assembly issues. Even newer right out of box tablets and the mass number of android tablets that are cheap knockoffs made in china and remarket by fly by night by what seems to be a good deal at the time but then turns out to cost not only money but also time frusteration and dead end resolve when something pops up. The main prob with power issues is that the battery that takes up most of the system is not secure attach so it doesnt creap loose from the tape or adhevise and seperate from the ribbon connection on the board. it can also result in the tablet going into endless rebooting or screen hazing etc.. there are some really good youtube vids on step by step help in taking it apart and checking the ribbon and reseating the battery.. i have several my self if all else fails.
good luck chadman
Posted on Oct 13, 2013
4 Suggested Answers
  • 4102 Answers
SOURCE: 2 year old UTStarcom Slice cell phone not charging.
hi, this is a good indication the battery is no good but it could also mean the charger is faulty so getting the charger tested would be a good idea.
You could take your phone into a phone shop and just ask them to check if the battery will charge using one of their chargers they wont charge for this.
Let me know how you get on or if you need further assistance ok
Posted on Jan 09, 2010
mobil master
  • 14641 Answers
SOURCE: wont charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Posted on Sep 10, 2012
mobil master
  • 14641 Answers
SOURCE: wont charge
First Option:
Second Option:
Posted on Sep 16, 2012
Why wont my Samsung Galaxy tab 3 notcharge past 60%
The battery may be unable to charge to more than the 60% level.
Oct 07, 2016 | Samsung Galaxy Tab on 3 Mobile Tablet PC
Why is my galaxy note 3 not charging as before ?
This is usually a symptom of water damage. If not there may be an issue with the charger or your battery.
Aug 15, 2014 | Samsung Cell Phones
Why wont my Samsung Galaxy Tab on 3 Mobile Tablet PC charge
either your battery is shot as in dead or your charger is faulty
you could try to charge it using a usb lead in your computer or another usb port to see if that works , or try another charger to eliminate your lead /charger you are using
Aug 01, 2014 | Samsung Galaxy Tab on 3 Mobile Tablet PC
My Samsung s5 is not charging their is nothing wrong with my charger
check this
1. First of all make sure that you are using an approved wall charger of Samsung Company. Because charging accessories of other brands may have different voltage parameters and may cause Samsung Galaxy S5 not charging issue.
2. Plugged in your Samsung Galaxy S5 with an original Samsung Mobile charger, but do not turn on your phone. Sometimes it may take little longer to charge the phone. After you phone starts charging, a charging icon should appear on screen. But if you see nothing is appearing on screen, then Samsung Galaxy S5 not charging issue is occurring either for damaged charging cable or there is some problem on your phone such as the charging port is damaged or bent, or the charging contacts on your phone is not cleaned.
3. To check the charger, charge another Samsung phone using the same charger and see if it is charging. If the other phone is charging well, then the charger is fine. Now you should check your phone.
3. Check the charging port on your Galaxy S5. To check the charging port, take a light, magnifying glass and a pointed wooden toothpick. Then see if the charging port is in the center and not bent. If you find the port is bent, then straight it using the wooden toothpick carefully.
3. Also verify the charging contacts are clean. Sometimes dirt gets stored into the charging port and occurs Samsung Galaxy S5 not charging issue. So Insert a small needle in the charging port and clean carefully so that the port does not get bent or damaged.
4 Download Galaxy Charging Current, to see if your phone is charging at it's maximum potential
How to fix Samsung Galaxy S5 not charging issue
Summary
  • Try a different charger with Samsung mobile origin.
  • Try a different USB Cable and charge by Kies.
  • Try charging it off via PC/Laptop.
  • Try removing the battery for 3 minutes, let it cool down and then charging again.
  • Blow inside the USB port and fix the contacts if it's bent.
  • Reboot your phone several times.
  • Download the battery charging electrical current app to monitor charging
(Note:Samsung Logo/images/Pictures has a respective copyright. I used it for demonstration purpose only.
If something in your mind to comment or suggest, please let us know. In our efforts to provide detailed information, there is possibility of inaccurate contents. If you see any mistake or incomplete in our information, please don't hesitate to tell us. We will fix it immediately as soon as possible.
goodluck
Jul 04, 2014 | Cell Phones
Why is my Samsung Galaxy Note 10.1" charging very slow.
There are a several reasons why the Galaxy Note 10.1 is not charging as much.
1. Too many application are turned on (check the task manager)
2. Too many notifications icon are turned on ( bluetooth, gps, wifi, etc.)
3. Plugging your charger using a computer
Are you using the original charger and plugging it into a wall charger?
How long did you use the Note 10.1 previous to noticing the damage? and was it extremely hot at the back?
If so, then maybe the battery isn't picking up from the charger. I've watched back to back movies while still using the charger but this can prove very devastating on the charger's outlet which became extremely hot after 4-5 hours or so of charging continuously. It turns out, the galaxy note 10.1 can withstand 8+ hours of ongoing movies but the charger outlet cannot. *If I didn't unplug it after 4-5 hours, the plug what have fried.
In this case, i believe the charger is more likely damaged than the Galaxy Note 10.1, which is more of a better scenario. Especially, since you charged it for over 24 hours, meaning it's charging something, but very slowly. Operating Galaxy Note while charging can prove detrimental in the charger's outlet and can in fact burn out.
I hope this info is helful,
Jason Chan
Jul 01, 2014 | Samsung Galaxy Note 10.1"
My galaxy 3 phone will not charge properly how do i fix it
Charging issues is a process of elimination. First the charger....many chargers will fit but not all that fit will work. A bluetooth charger will fit but would never charge your battery completely. Make sure you are using a proper charger. 2nd is the charging port on the phone. If the charger is loose it could be a bad port or the prongs on the charger are not holding....is it loose? Or if there is corrosion on the port. If corrosion, clean with alcohol and tooth brush. 3rd is the battery. If its swollen, then it's toast. A li-on battery will start to decrease after 400 to 500 charges.
Jun 18, 2014 | Samsung Galaxy S 4G Cell Phone
Why will my samsung galaxy s4 not connect to the charger - the socket seems to have dropped
REASONS OF SAMSUNG GALAXY S4 NOT CHARGING- GREY BATTERY PROBLEM
The main reason of Samsung Galaxy S4 not charging- grey battery problem is a shorted charging port. There may be several reasons for it such as sometimes dust entered into the charging port and causes this problem. Sometimes the bar across the center of the charging port gets bent.
SOLUTIONS TO FIX SAMSUNG GALAXY S4 NOT CHARGING- GREY BATTERY PROBLEM
Method 1
If your Galaxy S4 falls and you start to face Samsung Galaxy S4 not charging- grey battery problem, then take a pointed wooden toothpick, a magnifying glass and a strong light and see carefully if any bar across the center of the charging port is in the center and not bent to touch one of the sides of the shell. If you find that it is bent then straight it using the toothpick point carefully.
Method 2
Look for the dirt into the charging port that it may pick up from anywhere. Take a thin needle and gently insert it in the charging port to take out the large piece of dirt from it. But you have to be very careful so that you do not make any damages of the charging port. You can do this by using a can of compressed air or dust/hair blower that will blow out the small dust particles from your phone's charging port.
Method 3
Some users reported that they have found solution of the Samsung Galaxy S4 not charging- grey battery problem by taking out the battery from the phone , insert it into another Samsung Galaxy S4 ,and then again put it in back.
So follow these steps to get rid of Samsung Galaxy S4 not charging- grey battery issue.
Apr 25, 2014 | Samsung Cell Phones
Instructions for Samsung galaxy s3 charger
It should show green light. Its nice phone and I have used this and never had any issue like this. You can also check at Samsung India site in support option. May be you can get some help from there.
Samsung Galaxy S3 Price India Buy 3 Smartphone Features Reviews Specs
Dec 27, 2012 | Samsung Galaxy S3 S III Spare Battery...
Why is there a red cross on the battery icon of galaxy tab though its fully charged?
I studied my galaxy note 10.1. when i use the original wall charger it charges well, fast an no red cross appears. when i hook it to the usb of my laptop then the red cross apears and the tab reports that it is not on battery ( look at the time on battery it does not change) the battery also remains at the same charge level that it was when i hooked it up. when i use the car charger it does the same as with the laptop. my conclusion is that when hooked to the car and/or laptop the battery does not charge, but the tablet is running of the power from the external source and not the battery. this seems to be a very clever move from samsung to preserve the battery when it cannot be charged by the device it is hooked up to.
Nov 12, 2011 | Samsung Galaxy Tab (GTP1010CWAXAR)
Jan 09, 2010 | Cell Phones
Cell Phones Logo
37 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
