Daewoo DWD-M8021 water cannot enter the washing machine
Master_Tech
  • 770 Answers
SOURCE: Daewoo Washing machine Problem
If it is new then it is under warrty plz call the dealer you bought iy from for service
Posted on Aug 02, 2008
ginko
  • 19396 Answers
SOURCE: Daewoo Washer Error E8
Hi.
E8 is fault connection from CCU (Control board) to balancing sensor.
When you get E8, this is often because of a faulty control board.
Try first disconnecting power for a couple of minutes, to reset the appliance.
If you still get E8, then you need to call a technician. Testing is done jumping the two wires to the sensor to bypass the sensor, then replacing either sensor or control board.
If you want to arrange a repair, then you can call the phone number listed on the machine owners manual.
Regards.
Posted on Nov 08, 2009
jmeredith
  • 417 Answers
SOURCE: My washing machine (dwd-wd32ws) only uses hot water to wash!
hi,
try and switch your hot and cold water hoses around the other way. it should start the cycle with hot and rinse cold.. If it still does it you may have to have it serviced..
jm
Posted on Nov 27, 2009
  • 6277 Answers
SOURCE: i have a daewoo 7kg
'LE' stands for Lock Error. There is likely to be a problem with either the lid/door solenoid/lock or the 'lid/door closed' sensor requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Posted on Jul 09, 2011
SOURCE: Daewoo DWD G1243S washing machine
When you hear that macinhe is beeping and giving 1E code, turn it off and make sure that water feeder is turned on and that it can feed water into the machine, turn it back on and start your program, it should be fine :) .... Good Luck....
Posted on Aug 30, 2011
Daewoo washer DWD-F1011, WATER OVERFLOWING, HOW TO SOLVE THIS PROBLEM???
replace the water shutoff solenoid valve assembly
in the mean time when the machine is full turn the tap off
change the hot water hose over to the cold water tap and use the hot water solenoid button
Sep 05, 2016 | Daewoo Washing Machines
Daewoo DWD-F1011 1E error code I have a daewoo washing machine model DWD-F1011 and it start working the wash before no working spin and gives error code 1E. Any idea what that might be?
I do not believe that is a 1E I think it's an IE error code which would be water inlet wiring or something like that. Here is the code list, scroll down until you find IE, Daewoo errors start at E2, hope this helps.
http://removeandreplace.com/2015/11/02/daewoo-washing-machine-error-fault-codes/
Aug 30, 2016 | Daewoo Washing Machines
My Daewoo does not want to spin, any suggestions?
first does all of the water pump out when wash cycle is done? if not then check your drain lines and see if pump is coming on. if it is not then it wont let the washer spin,
Jun 03, 2014 | Daewoo Washing Machines
E9 message and machine stops
Jayshree, E9 error, pressure sensor error/water sensor error.
Replace water level sensor. The error display disappears if power button is turned off and on.This is what the service manual states.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Daewoo DWD M103 Service Manual Page 15 of 16
Daewoo CV701PC Service Manual Page 26 of 52
Daewoo Washing Machine Error Fault Codes
Washing Machine pressure switch
Apr 20, 2014 | Daewoo DWD M1031
I believe the EO code means the pump is blocked, and you will have to clear the pump for it to work again.
Oct 12, 2013 | Daewoo Washing Machines
Daewoo DWD G1243S washing machine not filling properly. 'ie' coming up on display & bleeping. What can i do to solve it?
Dec 27, 2010 | Daewoo Washing Machines
Where is daewoo's company in cairo, egypt? I have any problem with my washing machine.
I have DAEWOO Washing machine DWD F1011. Whithin few years water started leaking through the drive shaft and ball bearing damaged. I need service manual for how to change the ball bearing or is there any repairer in Heliopolis, Cairo area?
How many year the machine is guaranteed??
Thanks lot.
Panchal
Aug 19, 2010 | Washing Machines
hi,
jm
Nov 27, 2009 | Daewoo Washing Machines
Daewoo DWD-F1011 PFE error code
I hd zs problem before,no problems in z water outlet,z pump
Nov 16, 2009 | Daewoo Washing Machines
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
