Question about Kitchen Ranges
Cannot get oven to work
I have just purchased a house with a st george supermatic oven (model U81F.O) and cannot get oven to operate. Elements work fine and have been told stove was working. Seems to need a combination of switches to start and the instruction book is difficult to understand.Please help!
Could have something to do with the auto timer or the stop knob. If you play with this you should be able to get the oven to go.
Posted on Dec 11, 2009
St George wall oven wdl370 no power to the oven, yet the upper & lower grills work. I have checked the fuses and all okay. Thanks
check the elements and the oven safety valve? and check for separate fuse to oven?
Mar 08, 2015 | Ovens
Hi the temp on our st george oven, model ueo-8 has become unreilable?
if digital the replace the oven control / if dial then the dial is at fault . mm
Jul 12, 2010 | Ovens
My St George Grillmaster oven is not working, I suspect it is something to do with the automatic timer switch, could that be correct
It could be, but the oven would still work when it's NOT in timer mode. Does it work in broiler mode? Top element should get hot. Check the elements if you can. A visual inspection, for burned areas. If nothing there, could just be burned wire(s). Wiring/ elements need to be ohmed out.
Apr 06, 2010 | Kitchen Ranges
I have a wall oven, a St George single oven. The
Depending on model-
Put the door at an opening of about 100mm. You should feel an indent for thecorect position.
You will probably need 2 people, 1 each side,
Slide the door upward at an angle same as hinge, It will slide off the hinge.
If the hinge is broken, and they usually break inside the wall of the oven, it will be very difficult to slide it off the broken hinge.
Hinges are available from EDIS SPARES 1800 125 039
Sep 12, 2009 | Ovens
St George DEO 7 oven temperature not going past 170
Merrillie,
we have this problem too on the top oven. I used to work at StGeorge and I'm an engineer, so if I find a fix, I'll let you know.
Simon
Sep 06, 2009 | Ovens
Kitchen Ranges Logo
298 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
