Question about HP Vs17 17" LCD Flat Panel Monitor
HP vs17 monitor power button flashes blue
No menu screen but there is sound.
  • Anonymous Apr 26, 2009
    blank moniter. can the fuse be bad if the power lite is on steady blue?
2 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: HP vs17 monitor will go off while in use and the
Does it do the same when attached to another PC? Video cable is good?
If it is monitor problem, you will have to open it up, but please read below first.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Posted on Jan 13, 2011
HP vs17 (PK657AA) problem: the image is displayed for 3 seconds
first try entering VGA mode in the startup menu. u can get the startup menu by pressing the F8 key immediately after the POST screen. if the screen stabilizes try changing the resolution to 1024 by 768 which should work in normal mode. if that doesnt work then the monitors internal bulbs may be burnt. an electrician may fix this problem for you.
Nov 18, 2011 | HP Vs17 17" LCD Flat Panel Monitor
I have a HP vs17 LCD monitor 17" I relaced the screen and don't remember how the wires go to the back lights. They are the pink and blue wires on the side of the power board. Can you help?
Pink and Blue wires should be for the lamp assemblies, you should have four connectors for the lamps, each pair will be plug into the socket top set and bottom set.
See example here:
http://s807.photobucket.com/albums/yy352/budm/HP%20L1740/?action=view&current=DSCF1597.jpg
Post pictures if you are not sure.
Mar 23, 2011 | HP vs17
If i turn my computer off for whatever reason, when i try to turn it back on, the monitor remains black, the blue power light flashes and the monitor emits this horrible hissing sound. I can eventually get...
Try this, no guarantees but it may need to be reset. Make sure PC is turned off. Disconnect the monitor from the PC and unplug it from the wall. Hold in the Power button for at least sixty seconds, then replug it in PC and wall. If it is reset it should start normally. If not it needs further diagnosis.
Jun 10, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Power light on flashing but no screen
Hello.
There is either a problem with your monitor, VGA cable or PC's video connector. Try another PC or another monitor to narrow down your problem.
If another monitor works, swap the VGA cable on your old monitor.
If another monitor doesn't work, your video connector is faulty.
Hope this helps.
May 08, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Vs19d monitor has power but screen is not coming on
You will need to open it and inspect the capacitors in the power supply first, hopefully it does not have bad lamps assembly like the one in my pictures here: http://s807.photobucket.com/albums/yy352/budm/HP%20VS19D/
Post back what you see inside so we can guide you further.
Apr 07, 2010 | HP Vs17 17" LCD Flat Panel Monitor
HP vs17 monitor shimmering, blurring for first time - had to shut down unresponsive video-to-DVD program while VCR was hooked up PC. Program running was VHStoDVD 4 by honestech. The program had a video...
I have reviewed your problem and have the fallowing for you to aces.
First, power off all devices and monitor.
Second. disconnect all devices from the PC and Monitor.
Please make sure the monitor is disconnected from it power source.
Next, hook up monitor to PC and start PC, along with monitor.
Next, enter menu on HP vs17 and reset.
Allow to run for ten or 15 minutes, watching the video on screen for imperfections.
If all looks OK, hook up your other devices and enjoy.
I hope this has helped you. Please let me know how things work out for you.
Please rate.... Thank you.
Nov 05, 2009 | HP Vs17 17" LCD Flat Panel Monitor
Monitor flashes blue light and takes a long time to come on
Disconnect monitor cable from back of the computer and see if u have a error msg on the screen > if u find a error msg like " NO VIDEO SIGNAL"> then ur monitor is fine or else ur monitor is BAD
Oct 20, 2009 | HP Vs17 17" LCD Flat Panel Monitor
Black screen, flashing blue power light
Chek the RAM of your system. Clean the slot and re-fix the ram. If the problem not solved replace the Ram
Jun 17, 2009 | HP Vs17 17" LCD Flat Panel Monitor
HP vs17 monitor power button flashes blue but screen stays black.
Try put off Monitor uplug power cord and the VGA cord for 1min and reinsert and restart your PC.
Nov 25, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Not working.
Did you install the software for the monitor? If you do not have the disc, You can download the driver here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=447382&lc=en&cc=us&dlc=en&submit.y=7&submit.x=8&lang=en&cc=us
If you have any further problems,let me know. Thank You for using Fix ya!
Aug 23, 2008 | HP Vs17 17" LCD Flat Panel Monitor
HP Vs17 17" LCD Flat Panel Monitor Logo
466 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
