Question about Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum
The brushes won't turn. I want to fix it myself but can't figure out how to get to the drive mechanism, by taking the top cover off. I have all the screws out but it seems to have some snap fits holdi
The brushes won't turn no matter what. I'm trying to fix it myself, any instructions available how to get to the gear box or whatever drives the brushes?
  • Trelectronic May 22, 2009
    How do you get to the belt that turns the brush
    President:
  • 710 Answers
If you turn the vacuum over and are able to turn the brush by hand and it won't turn while its running, then your belt has broken.
Posted on Apr 24, 2009
The motorized brush on my DC35 no longer turns. I cleaned the debris from the brush but it still won't turn. The belt is in great shape but the gear is physically hard to turn. How do I fix it?
After removing the screw in the centre of the brush bar drive gear, gently lever the gear away which will reveal a possible build up of hair behind.
Jun 22, 2015 | Dyson DC35 Multi-Floor Cordless Vacuum...
Need to replace belt and cannot figure how to take it apart to get at the belt --- Took Screws off on the bottom but could not get to the belt
You have already removed the screws so lift the brush cover off. Then grasp rotating floor brush at both ends and lift. Clean strings,hair and other debris from rotating brush, paying close attention to the brush ends. Clean the debris from motor pulley and drive belt areas.Grasp old drive belt and remove from motor pulley. Place new drive belt over motor pulley and stretch other end over rotating floor brush in the space between the bristles. Place the ends of the rotating floor brush down into slots on the sides. Turn the rotating floor brush by hand several times in the direction of motor pulley. If installed properly, drive belt will center itself on rotating brush. Reposition brush cover and screw back into place. I hope that this helps you!
May 26, 2011 | Bissell 3591 CleanView Bagless Upright...
My hoover carpet scrubber the brushes won
(1) Remove the brush block and assure the presence of the square drive pin on top of one brush. It should be about 1/4 inch square, two inches long to connect o the drive mechanism.
(2) Remove and clean the filter screen from the base, behind the brushes. Squeeze the two red tabs together, and pull down from the base. Clean the hiar/debris from the screen.
(3) Assure the Brush Speed knob on the hood is NOT set to the OFF position.
Aug 30, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Brushes won't turn on a Hoover F7426-900
there should be a rubber belt that drives the brushes on either side. hope this helps. please rate this.........thanks
Aug 30, 2008 | Hoover SteamVac V2 6-Brush Widepath...
Hoover Steam Vav & Spin Scrub #F5899-100
Sorry it is not belt driven. There is a turbine that drives the brush. You have to remove the top cover to get to it. But if the motor smells hot, then you may have a problem with it also.
Apr 18, 2008 | Hoover F7431-900 SteamVac Vacuum
Bissell Proheat 2x Series 8920 - Brush Belt Metal Shaft Sprocket won't turn
Most likely the brush motor is bad and not turning, part #2036757, would sell for around $23. To get to it, start taking out screws on the top cover, that motor is under the that top access cover.
Jan 22, 2008 | Bissell 8910 ProHeat Clear View Upright...
Brushes stopped working
go to thehooverstore online. search for your machine and click on your diagram. it will show you how the belt goes on the drive.
Sep 11, 2007 | Hoover SteamVac F5914-900 SpinScrub...
U6446-900
from the underside: 1. remove 4 screws holding agitator cover in place 2. remove 2 screws (black screws) holding hose retainer in place, pull hose out through top 3. remove three screws, 2 long, 1 short holding top cover: short screw is at center of inside of brush housing, long screws are inboard of wheel axles, and slightly forward (all of these screws are aluminum colored) 4. from inside surface of each side, at approx the center, locate and push down on ledge inside right and left inside with a screwdriver to slightly displace the plastic ledge that holds the cover on; this ledge-lock-detent can be released with your fingers. You'll have to support the drive mechanism to allow the top housing to drop free. 5. remove housing, turn vacuum over, then go find the torx driver you need to disconnect the cable. Good Luck MB http://in4m8ion.com
Aug 19, 2007 | Hoover U6630-900 WindTunnel Bagless...
No spinning.
Most common problem when the brushes stop spinning on this model or any "SpinScub" model is that screen filter is clogged as suggested above. If that isn't your problem then likely the turbine has gone bad. Some genius at Hoover designed a metal gear to drive a Nylon gear (Inside the black part that says "Assembled in Mexico". If the brushes jam hard and sudden, the metal gear just shaves the nylon right off. Solution: You will need a new turbine unit. Cost for the part is about $36, installation takes about 15 minutes (about 6 screws and two tubes).
I refurbish and repair vacuums and steam cleaners for a living and see this all the time.
Jun 23, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum Logo
315 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
