Question about Garden
No power to starter. Acts like neutral switch. John Deere 6220. Pto keeps blowing fuses.
  • 246 Answers
SOURCE: My fuse keeps blowing on my neutral safty switch
Hello williamhowar:
>>As I am Sure you are Aware, Most Backhoes do a Lot of Bouncing and Jarring. LOL.
>>If you can Trace the Harness, then Check of a Bare Wire that is May be Touching the Unit.
>>If the Harness is Good, then I will Require some More Information about this Unit in Order to Assist you Further.
>>Send me the Model Numbers Off the Unit, Please. With these I can Locate the Proper Manual and Better Assist you.
Thanks.
Respectfully
jbridger (John)
Posted on May 14, 2009
pic498
  • 32 Answers
SOURCE: 1987 john deere 750 compact tractor 4 wheel drive, wont start
percussive maintenance my friend. Try banging on the solenoid and starter with a hammer while in the start position. Also, if you have a voltmeter, you can see where voltage is getting to and that will help you as well.
Posted on Jun 13, 2009
rwvanlue
  • 486 Answers
SOURCE: John Deere 2010 utility tractor, lights come on
1) Battery condition and clean cable connections
2) Check the voltage & connections at the solenoid
*Is full battery voltage found at the solenoid?
3) Does the small wire that activates the solenoid from the ignition switch/safety switches have voltage when the key is in the start position
a) voltage yes, but it does not start; suspect solenoid
b) voltage no, inspect and check all safety switches for voltage to and from each switch
c) safety switches do NOT have voltage to them: inspect connections on ignition switch and check for voltage coming into the switch from the battery.
Posted on Nov 10, 2009
nova2nv
  • 197 Answers
SOURCE: John Deere 445 pto will not start Smoke from
If smoke is coming from solenoid on rear top side of trans then internal windings are bad but usually it will blow the fuse.Remove plastic nut from solenoid,slide solenoid off shaft then engage PTO.If solenoid does not smoke slide screwdriver or something like it into solenoid and see if there is any Magnetic force.If smoke comes from deck check idlers and spindles for movement.Be sure to ckeck gearcase oil level on the deck.
Posted on Nov 13, 2009
nova2nv
  • 197 Answers
SOURCE: Engine dies when engaging PTO switch on a John
Check and adjust your RIO switch{reverse implement option}near the trans if so equipped.What happens when you press forward pedal then engage blades?Would also check the lower bearing on your pto clutch to see if its seized up.
Posted on Nov 14, 2009
I have a John Deere GT275 that keeps blowing the F3 15A fuse. Any suggestions why?
Get a wiring diagrams and trace down each component the fuse powers and its wiring and find the short, no other way to fix it.
Jul 12, 2017 | John Deere Garden
Tractor won't start new battery John Deere 4400 does not even turn over
The tractor has a neutral safety switch ,be sure you are in neutral or park , be sure pto is disengaged has a safety switch on pto . Has a operator present switch under seat cushion that is activated when setting in the seat. All these work together to complete circuit to engage starter. Check it out
Jan 10, 2017 | John Deere Garden
John deere pdf manuals
Low hydraulic fluid will not prevent starting. The fuel filter shouldn't necessarily be full of fuel but if its empty my indicate lack of fuel flow. Look for debris in the fuel tank. A long skinny screw driver with a dab of grease on the end can be used to retrieve debris from bottom of tank. Remove the fuel line from the tank side of the filter and check for fuel flow. Blow into the line back into the tank then check for fuel flow. If it starts flowing then you will likely find a piece of debris in the tank. Reconnect the fuel line to the filter and remove from carb and be sure fuel is getting to carb.
If unit wont turn over. Check battery voltage: 12.6 volts or better. Be sure pto is off, unit is in neutral, and brake pedal is depressed. Check the fuse. Then with a test light check for 12 volts on the yellow or white wire on the small post of the starter solenoid with key in start position. If you have voltage to the solenoid but not to the starter then either the solenoid has a bad ground or is faulty and should be replaced. If no voltage to solenoid then you have a bad wire or switch between the fuse and solenoid. Voltage travels from fuse to ignition switch to pto switch to brake switch (to seat switch if it has four wire plug) to starter solenoid. You can use a test light to chase down where voltage stops.
Aug 24, 2014 | John Deere Tractor Starter 285 345 2243...
John deere stx 30 pto wont engage
Check your fuse or for a broken wire( or shorted)
Jul 19, 2014 | John Deere Pto Clutch For Stx38 And Stx46...
PTO Issues
replace the pto solenoid as it has an internal short causing the fuses to blow.
Jun 02, 2013 | John Deere Garden
X595 john deere pto wont kick in
These John Deere Garden Tractors have a RIO (Reverse Implement Option) on the PTO. If your PTO is engaged and you back up, the PTO will automatically stop. To reset it, depress your PTO engagement switch to the OFF position. Take your foot off the reverse pedal. Pull up on the PTO engagement switch. The PTO should restart. To use the RIO feature, pull up on the PTO switch for a second or two just before you step on the reverse hydrostatic pedal. The yellow RIO indicator light should come on your dashboard and you can now back up with the PTO still running. Works great for snow blowing when I don't want to keep resetting my electric PTO clutch to keep restarting my snow blower.
If your PTO will not restart, you may have a PTO switch starting to fail, or a likely logic problem in your electric PTO control module, or one of your forward/reverse indicator switches, which is linked to your PTO control module along with the overtemp circuit, is stuck/faulty.
Feb 20, 2013 | John Deere 26HP Hydrostatic 54" Riding...
Aug 09, 2009 | Garden
Jun 09, 2009 | Diesel Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
