Question about Apple iPod nano 3rd Generation
I just got this new ipod nano 3 gen and the sound is messed up..
When i try to listen to it then one head phone is louder than the other one and the sound is like crazy low...and staticy..
  • 469 Answers
Try a different set of ear buds, if it is the same, Try going to the main menu, settings, reset all settings. After doing the reset is it still the same? if yes return it to the vendor as it may have a bad amplifier.
Posted on Apr 24, 2009
  • 342 Answers
I would try another set of headphones first off to ensure that it is actually an apple issue. If with a different set of headphones it still has the same issue; try resetting it. Below are the instructions on how to reset an ipod.
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time are preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
If after a new set of headphones and a reset your issue still persists I would go ahead and restore the ipod. As before i will include the instructions below...
How to restore iPod (ARTICLE NUMBER HT1339) Ensure that you have an active Internet connection as new versions of iTunes and iPod Software may need to be downloaded to your computer. Download and install the latest version of iTunes if you do not already have it installed. Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod. After a few moments, your iPod will appear in the Source panel in iTunes. Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software. The 4 possible restore options are: Restore Option 1: Restore - Restores with same iPod Software version already on iPod. Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available. Restore Option 3: Use Newest Version - Restores with the latest iPod Software available. Restore Option 4: Restore and Update - Restores with the latest iPod Software available. If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring. Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models). Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models). During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
If after a new set of headphones, a reset, and a restore you still have the same issue you will want to either contact your choice of repair service providers or get a new one. Hope this was helpful to your issue. CHEERS :)
  • 3 Answers
Justinluu you rock ipod nano wow stanky legg ok so i think you should go to free.driverscan.org sound will be back in no time
The Ipod Nano 5th connects to my headphones through the D650 but no with sound. Only play/pause next track last track are controllable. The motorola S305 head phone does play sound from the phone so they...
i have the same problem with 5th gen nano and the D650. It pairs and i can use the controls but no sound comes to the headphones. I tried the headphones with the onboard bluetooth on my ipod touch and i had no problems. The problem only happens with the d650 and my nano. Someone has made this work im sure.
Jun 30, 2010 | Motorola Mobility MOTOROKR S9 + Bluetooth...
Volume control does not change the volume when using earphones
Most often, the ear phone might be the problem.try getting a new ear phone preferable, one from another manufacturer,if it does the same way, the problem will be from the earphone port.
May 28, 2010 | Apple iPod Nano Video 8GB Purple (5th Gen)...
A folder shows up on startup and notice to contact apple support. 20gb 4th gen
Ipod is not ABLE TO FIND THE OS ON YOUR HDD.
try to bring it close to your ear an try to hear. See if you can listen to clicking sound. if it does click, your in trouble as your hdd is messed up..
nothing much you can do about it, just when its trying to start and it starts clicking bang your ipod ( on ur palm ) as this would help the hdd needle to skip and bad sectors and might work again !
good luck.
May 21, 2010 | Apple iPOD 20GB Toshiba Harddrive for Gen...
My ipod nano 2nd gen has no sound. How to fix it? Thanks
the pod has become people's life line. its a way of saying who you are and what you listen to. believe it or not, the freezer trick WORKS!!! i have a 5th gen video ipod that quit playing sound one day. it showed it was playing but i heard no sound. i read tons of threads and feeds with much concern. just when i was gonna give up, i said what the "h" and tried it with a slight variation. instead of putting it the freezer with the possiblity of forgeting it, i use a flexible gel ice pack and wrapped the ipod in it for about 5 minutes. to my suprise, the ipod PLAYS WITH SOUND again!!! if you've lost hope and all else has failed, give this method a try. what do you have to lose other than your temper. try it, it saved me money and heartache!
the principle behind this is expansion and contraction of the metal surfaces in the bearings of the ipods hdd, if the bearings have seized up freezing could help free up the bearings and let the hdd platters spin again, plus this is only a temporary fix or so i've been told.
Sep 25, 2009 | Apple Ipod Nano Second Gen. Green (4 GB)...
Ipod Nano gen 3. Won't work unless into charger or dock
Hi! Try uninstalling the itunes and reinstall it after restarting your PC. If it doesn't help then try to install a diffrent version of itunes.
Dec 26, 2008 | Apple iPod nano 3rd Generation
Gen 3 nano and bose docking station
Have you tried another iPod on it?? I suspect that if you do, that one won't work either. If it's a Bose SoundDock then they are well known for having problems with the iPod connector getting loose. Try with another iPod. If results are the same, take your SoundDock back. Bose should exchange it straight away.
Aug 06, 2008 | Apple iPod nano 3rd Generation
Apple iPod nano 3rd Generation Logo
80 people viewed this question
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
