Moretti error p2 air conditioner - Heating & Cooling
hvac1960
  • 2133 Answers
SOURCE: Hi, Our Moretti Elite Portable Air
It's based on error code of E-2.It's problem with indoor coil sensor.Replace. Helpful?
Posted on Jan 05, 2011
hvac1960
  • 2133 Answers
SOURCE: I have the flashing P2
P2- cut off when coil temp is high due to short of gas. Please find leak testing and rectify.
Thanks.
Posted on Jun 29, 2011
  • 4736 Answers
SOURCE: I have a P2 error
I think what you're seeing is actually a E2 error code. Which is "Sensor protection, to avoid occurrence of unit damage, auto-stop protection." In simple terms, one of the senors in the unit is failing or has failed and it has shut the unit OFF. If it was warning you that the bucket was full, it would show FL.
To find out more about the Sensor Protection, call LG Customer Support (800) 243-0000.
Posted on Jul 08, 2011
kevin_getz
  • 1031 Answers
SOURCE: How do I drain the water from my LG portable air conditioner (LP1010SNR)
Lift up the window securing the AC, and CAREFULLY tilt back the unit. The water lays towards the back of the A/C under the fan.
Posted on Apr 18, 2012
sodeep
  • 3267 Answers
SOURCE: how do you drain water from a LP1010snr air conditioner?
P2 means the water collection tank is full and needs to be drained. You have to pull the drain plug at the bottom of the unit and drain the water.
Drain the water (small amount actually) in the shower. Note: There is a cap towards the bottom of the unit that you will need to unscrew, then pull out the rubber plug. Fired up the unit after the water drain ... it worked fine.
Testimonial: "I did that and let it run for a few minutes and it did work. It's been cool out ever since so when I give a full days worth I'll let you know how it works out. Thanks. :)"
Download 5.2 kw moretti cooling only air conditioner manua
Tough One
Couldn't find it here
http://homeappliance.manualsonline.com/manuals/device/air_conditioner.html?page=5
I think I saw the Manual HERE
http://homeappliance.manualsonline.com/support/other/air-conditioner/air-conditioner-5415960
Mar 02, 2015 | Heating & Cooling
I have a moretti elite portable air con and it's not blowing cold air it's second hand and a red light is on saying water full
Air conditioners remove humidity or water first, look for the bucket inside and drain it. or it is plugged and not draining.
Nov 16, 2014 | Heating & Cooling
LG LP0910WNR portable Air Conditioner error code P2 and shut down
P2 is a water tray full error. I had error once, and it had me puzzled because I have a tube from the back, and unit elevated. It was producing water out the back, so it was clearly draining.
Called LG (very prompt service, no wait times at all).
The girl said that error was water tray, I still didn't believe her.
So I pulled unit from location, and tipped at a good angle.
Sure enough, less that a cup of water drained, and now it works fine.
Jul 07, 2011 | Heating & Cooling
P2 err on mpk-10cr it starts for about 5 seconds then p2 displays and it stops can you gide me to were the problem is
P2 error indicates that the spill reservoir in the base of the unit is full.<br /> <br /> Solution:<br />Move the unit to a location that is suitable for draining water from the unit. Remove the plug in the lower center of the back of the unit and allow the water to completely drain <br />(Remember to replace plug.)
May 25, 2010 | Danby DPAC8020 Air Conditioner
Everstar Model MPK-10CR, What does flashing P2 mean?
p2 means the bottom pan is full, you need to drain the bottom, small valve on the back bottom in the middle
Aug 13, 2009 | Danby DPAC8020 Air Conditioner
Heating & Cooling Logo
142 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
