I have a 1994 RCA projector TV model# p52731wk. The picture is all blue. How do I change the bulbs?
    President:
  • 1,779 Answers
Unless you have a source for the tubes then I can help, however, those tubes have not been available for over 4 years now. I recommend start looking into a new one or see if you can locate a refurbished projection set from your local Television Repair Center.
Posted on Apr 24, 2009
I have a RCA Model R52WH74. It hs a double view to it liek the colors has seperated. It also has a wavy red line across the top. It looks like the projector bulbs are out of line. All three bulbs are...
The tv have a problems known as a convergence problems,it is dead.Tv have any colors lines R,G,B mis alignments,have any colors shadows pictures or 3D pictures look alike?Yes,than the tv convergence board it is dead,convergence board must require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to fixed the tv convergence picture problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 01, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
The picture went blank on my tv but I can still hear the sound. How can I get the picture to come back? All plug ins are tight. Thanks
When was the last time you changed the bulb for the projector? has this gone bad? If the bulb needs changed, consult your manual for instructions and if the bulb is good let us know.
Mar 24, 2011 | RCA HDLP50W151 50" Rear Projection HDTV
I got sound but no picture on my 52 inch rca floor model tv i sure its the bulbs but not sure how can i find the prices or the rite bulb for it
That set is a 1994 model set. You have 3 picture tubes in that set of which are no longer available or made anymore.
Nov 27, 2010 | RCA P56830BL 56" Rear Projection...
MY RCA M50W74S HAS NO PICTURE BUT SOUND AND BEEPING NOISE
You need a new projector bulb. Google up your model and buy the best warranteed one you can find. Buy a "caged assembly" and not just a bare bulb.
Then unplug your tv and get a screwdriver. Follow your model's instructions and just snug down the electrical screws. Do not overtighten them.
Then consult your manual on how to reset the lamp timer so it knows you put a new bulb in and fires up from the first try.
Treat yourself because you've just saved yourself a trip from a repairman!!
Aug 13, 2010 | RCA Televison & Video
I had gotten a RCA P52731WK chassis PTK169PGB. my uncle had given me the tv, when i plugged it in there is a loud electrical snapping sound and then shuts off. he told me 4 years ago he had same problem...
This set does not have a bulb. It has three picture tubes which can be mistaken for a bulb. It is possible that one of the three tubes can be leaking high voltage or you could have a bad high voltage transformer. Either way this is a dangerous area to be working and you would probably want to get some professional help. Thanks
Oct 29, 2009 | Televison & Video
My picture is not fitted to the screen.
go into the menu find convergence
some models have auto convergence
if you have the option to manual adjust convergence adjust red and blue DO NOT move green
Sep 02, 2009 | RCA HD52W59 HDTV Projection Television
RCA P52731WK REAR PROJECTION NO RED ON SCREEN
The RCA model is a 3 CRT projection TV. Most probably you need a new RED CRT, or there is a problem with the R(ed) channel (the picture is made up of 3 component colors: Red, Green and Blue). No way of telling without testing of the projector. Sorry!
Jul 11, 2009 | RCA P52926 52" Rear Projection Television
Rca 60'' p60928
The set does not have a blue lamp. The set has a blue picture tube. I have found that the best RCA parts distributor is Union Electronics at 1-800-648-6657. The picture tubes in projection sets are very fragile and dangerous to handle. The new picture tube will come dry, so the lens assembly and seal will have to be assembled onto the new tube and then filled with fresh coolant. The set will then need a complete realignment, everything from screen and focus voltages, bias and drive, yoke and ring position to convergence circuits. If you have no experience in any of the above, do not attempt to replace a picture tube. Allow a qualified tech to handle it for you.
Aug 28, 2007 | RCA P52926 52" Rear Projection Television
RCA Home Theatre Wide Screen TV Model# P52731WK
This sounds to me like the parameters are off, I recomend only a service tech adjust this for you because the parameters can only be accessed by a service man, and they are critical, if done wrong the whole set can go out of wack.
Aug 15, 2007 | RCA 32V420T 32" TV
Televison & Video Logo
206 people viewed this question
Top Televison & Video Experts
