Question about Canon PIXMA MP160 All-In-One InkJet Printer
Canon PIXMA MP495 printer displays an E08 error
    Top Expert:
  • Canon Master
  • 1,144 Answers
SOURCE: canon printer displays error
CANON
PIXMA MP450
Discharge of the code of the error of the overcrowding of sump - "pampersa"
1. You will turn off printer.
2. retaining button Resume/Cancel (red triangle in the circle) press button POWER - indicator it will catch fire by green color.
3. you will let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which you will let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times!
6. you will turn off printer by button POWER.
Posted on Dec 06, 2007
  • 10406 Answers
SOURCE: how to install a canon pixma mp495 printer with no
CANON puts its device-drivers onto its web-site: http://www.canon.com
Click "Support" or "Downloads".
Enter your model-number.
Select your Operating System.
Download the device-driver.
Install it.
Print.
Posted on Feb 01, 2011
Testimonial: "You guys are awesome thanks"
  • 2340 Answers
SOURCE: Where can i find the serial mumber on my canon
PIXMA Printers and All-In-Ones
The serial number is located inside your PIXMA printer. To find it, open the printer lid as if you were to access the cartridges tray: the serial number is printed on a white sticker. Be careful to not confuse this number with the power supply serial number that can be found on the bottom of your printer.
Hope it helps.
Posted on Apr 26, 2011
SOURCE: Canon PIXMA MP495 Error Code
Hi Taco
I have the same problem. Did you find a solution?
Posted on May 28, 2011
  • 29 Answers
SOURCE: error 5200 or P08 on
The error indicates the following : Head overheating error.
Yes it is most likely the print head itself or at worst the logic board.
Replace head/logic board is the only answer.
Posted on Jul 20, 2011
How do I find ip address for canon pixma mp 495 printer?
Two links for you
Pixma MP495 Printer not detected - Canon Community
community.usa.canon.com/t5/Printer-Multifunction.../Pixma-MP495-Printer.../25583
  1. Cached
  2. Similar
May 26, 2013 - So I have a Canon Pixma 495 printer that worked great wirelessly ... Hi I have the Canon Pixma MP495 and I can't seem to find the IP address.
PIXMA MP495 Wireless Connection Setup Guide - Canon Europe
www.canon-europe.com/.../pixma_printer.../mp495_printer_wireless_connection_set...
  1. Cached
  2. Similar
This method is by far the easiest way of connecting your PIXMA MP495, so if your ... Press and hold the [Maintenance] button (A) on the printer for approximately 5 ... regarding pressing the WPS button, please refer to the access point manual.
ip address for canon pixma mp 495 printer Google Search
Oct 04, 2016 | Canon PIXMA MP495 InkJet Printer
My black ink button on my pixma mp495 printer is blinking. Why?
A B LED light denotes that the black ink cartridge is running low.
A C LED light denotes that the colour ink cartridge is running low.
If the alarm light is on (lightning bolt in a triangle) it should be accompanied by an error code.
Canon MP495 - Error Codes If the printer displays an error message, the following information should help to diagnose the problem.
The led screen on the printer will flash a letter E and will then be followed by two numbers:
Error Description More Info Error E02 The machine is out of paper or will not feed. Error E03 Paper jam or output tray is closed. More Info Error E04 The Cartridge cannot be recognised. More Info Error E05 The Cartridge cannot be recognised. More Info Error E07 Cartridge is not installed in the correct position. More Info Error E08 Ink absorber is almost full. More Info Error E13 The remaining ink level cannot be detected. More Info Error E14 The Cartridge cannot be recognised. More Info Error E15 The Cartridge cannot be recognised. More Info Error E16 The ink has run out. More Info Error P02 Carriage encoder error. More Info Error P03 Line feed error. More Info Error P07 The waste ink absorber is full. More Info Error P08 Print head fault. More Info Error P10 Print head fault. More Info Error 5100 Carriage Encoder error. More Info Error 5200 Print head fault. More Info Error 6000 Line feed error. More Info Error B200 Print head fault. More Info Error 5B00 The waste ink absorber is full.
Feb 24, 2015 | Canon PIXMA MP495 InkJet Printer
Canon mp495 e08
INK ABSORB MOSTLY FULL RESET COUNTER
Mar 29, 2014 | Canon PIXMA MP495 InkJet Printer
What ink will my canon mp495 take?
Quikshiptoner is a good site for ink and toner that I generally use. It has black and color ink for the MP495. I'd just go there and search for the printer you need and it should come up with the correct ink / toner that you need.
May 11, 2012 | Canon PIXMA MP495 InkJet Printer
Canon pixma mp495 error code E03
e03 is paperjam or out of paper error, make sure you have a decent amount of paper in the tray. open up all the doors on the printer and make sure there's nothing stuck inside the machine.
Apr 03, 2012 | Canon Office Equipment & Supplies
What does Error code P03 mean on Canon Pixma MP495
Download the manuel from this link below:http://www.manualowl.com/p/Canon/PIXMA-MP495/Manual/68096
It might have some trouble info for you. ;-)
Jan 29, 2012 | Canon PIXMA MP495 InkJet Printer
Canon pixma mp495 error E,1,6 .and light up at C
Hi there :The error E1.6 is :E, 1, 6 (LED display) The ink has run out. In your case that should be the Cyan cartdridge .I hope this helps you
Sep 03, 2011 | Canon PIXMA MP495 InkJet Printer
Canon PIXMA MP495 InkJet Printererror code 5200 problems
Here what I found for you. If it fixes your issue, don't forget to give me a good rate. Thanks
Print head temperature rise error or Error Code 5200
Condition: The print head temperature exceeded the specified value.
Problems and Solutions:
  • Turn off the printer and then turn on if error still persist replace Ink cartridge or print head thankyou for using
Aug 30, 2011 | Canon PIXMA MP495 InkJet Printer
Error 5200 or P08 on canon pixma mp495
Jul 11, 2011 | Canon PIXMA MP495 InkJet Printer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
915 people viewed this question
old marine
old marine
