Question about AT&T 1480 Phone
Need the telephone power supply for the 1480
One of my critters (rabbit or kittens) nibbled the cord and now it is toast - can't find the exact one on ebay or on the web. Help!
  • BainesBC Sep 26, 2007
    Went to Walley World and found the universal, under $15 - and it worked! Thanks!
    Problem Solver:
  • 10 Answers
Go to wall mart they hav universal adapters with a bunch of different plug ends and a switch to set the right voltage to your unit.When you get it you have to find the voltage of the phone,it would probabally be on the bottum of the phone base probabally between 7 and 14 volts.This adapter is probabally cheaper then the original and you can use it after you get a new phone for future pet problems.good luck Ps you can also get them at radio shack if you dont like walmart and please leave feed back
Posted on Sep 25, 2007
SOURCE:
I NEED TO FINALIZE DISK BUT MY DAUGHTER'S PET RABBIT CHEWED THRU THE POWER CORD, I HAVE 2 FULLY CHARGED BATTERIES FOR THE CAMERA BUT I DON'T THINK I CAN DO IT WITHOUT THE POWER CORD, SOMEONE HELP.
You´re just right: Finallizing is a delicate procedure because you never know exactly how long it takes. If there is any interruption, the whole data is lost forever. That´s why finalizing should always be done with the AC-plug. Get it repaired and put this rabbit to court (smile).
Best wishes
Norbert
Aug 21, 2011 | Canon DC210 DVD Camcorder
I need a manual for Uniden 1480-5A cordless phoneset with answering machine, how can I obtain one?.
You can download manuals from Uniden's site. Here's the 1480-4A manual, which is the same base with 4 handsets.
Jun 23, 2011 | Uniden DECT 6.0 Cordless Telephone...
Whistler 1480 does not power up.
Does the lighter socket power other devices? If so, did you check the fuse in the units power cord? Its in the plug part that goes into the lighter socket. Its a 2 amp fuse.
Jul 10, 2010 | 1480 Radar Detector
My rabbit chewed through my power supply cord to my dlink router and I need to replace it. Where can I purchase just the power cord?
For the power cord replacement you can go get one of those from any electronic or computer store near you and just provide them the model of your router so they can provide you the correct power cord.....
Nov 25, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Looking for power cord and printer cable for my HP psc 1610v rabbit chewed it!!
parallel printer cable OR USB printer cable available at Office Supply store. Power supply ... is it a detachable cord like on your PC? Same place. If it is not detachable, get a original replacement from www.hp.com
Watch the rabbit with all your electric cords. By the time we found out what was going on with our rabbit, we had no table lamps and no telephone. I dont know how she stayed alive!
Nov 02, 2009 | HP PSC 1610v All-in-One Printer
Simply does not respond
Check connections at both the appliance and the thermostat. Also check the wire. A critter may have started to nibble or something may of creased the wire breaking the wires inside the plastic casing causing it to short out.
Apr 16, 2009 | Heating & Cooling
Had a power outage, a day later i noticed fax would not copy or print out internal reports. Faxes received are unreadable. When I try to make 8 or so copies, it scans them but memory stays at 00% and it...
It seems that your fax machine has been damaged by a power "spike" You may or may not be able to get it to work again. You can try to re sequence the machine, by switching off, then removing both the power cord and the telephone cord from the wall. Wait 30 secs or so, then plug in the power cord and switch on. After the machine shows the "ready" mode in the display, then plug in the telephone cord. If this does not work, your machine is toast. Make sure in future to use a line conditioner for both the power and the telephone lines.
Jun 09, 2008 | Brother IntelliFAX 2800 Laser Fax
Date/time stamp on answering machine
Set the correct date and time by pressing "time/set." Then, follow the voice prompts. Press "time/set" again. Use "change" button to advance day. Press "time/set" again to adjust hour. Use "change" button to advance hour. Press "Time/set" again to adjust minutes. Press "change" button to advance the minutes. Press "time/set" when finished.
Aug 14, 2007 | AT&T 1480 Phone
AT&T 1480 Phone Logo
82 people viewed this question
Top AT&T Lands Phones Experts
Ekse
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
