Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
My Epson WF-7520 3-1 printer starts to load paper, emits a gear grinding type of noise for a few seconds and then stops showing "paper jam" or "no paper warning.
Inky
  • 691 Answers
SOURCE: Epson stylus photo 830
Yes it can probably be fixed. I hope you poked your friend in the eye for giving you such a headache though. You will need to dismantle the machine and remove the Auto Sheet Feeder (ASF) Once removed, check there is no bits of paper stuck inside. Then turn the pick up mechanisme by hand through a couple of revolutions to re synch everything. Also check the paper sensor is still intact - if not you can construct a new one from a piece of plastic or if the old one is still present, just glue it back together. You can download a service manual to hep you out with the dismantling from either: http://www.TheServiceManualShop.com http://mikeburton.tradebit.com/
Posted on Apr 12, 2007
doc_delphi
  • 11 Answers
SOURCE: Epson AcuLaser CX11N ADF Paper Jam
I had a very similar problem with the ADF, it resulted in ADF paper jam - message and then in Req Code 2011.
I checked sensors and everything else, then called a epson service professional.
After telling him the Req Code, he knew the problem and said that the problem is the board, which needs to be exchanged, mentioning that this spare part is expensive.
I then checked the whole ADF again, now opening the long grey cover on the backside, I disonnected the connector cable from both sides and - using a multimeter - checked this connector cable for breaks.
Result: the violet cable was broken, so I soldered in a new wire, using the last cm of (old) wire on each side - and now the ADF works fine.
This cable is easy to change if you get the spare part, there is a connector plug on each side, on the ADF side is an additional ground wire (green) fixed with a single screw. Thats it !
For the electronic experts: the configuration of the connector:
sourrounding metal cover = ground, thick green Wire on the ADF side
If you turn the plug that way, that the two single contacts are on top, these are the colours:
1st row: brown - black
2nd row: green - yellow - orange - red
3rd row: grey - violet - blue
Hope this helps
Posted on Sep 17, 2008
doc_delphi
  • 11 Answers
SOURCE: CX11NF "Paper Jam" and Noise
Had the same problem, too. The grinding noise came from the gear of the loading mechanism, located (if looked on printer from behind) on the right side next to paper tray.
I had a problem with the paper loading, too.
That problem was due to a broken wire for the magnetic release of the loading mechanism, located on the right side, too.
My experience with this epson is, that most problems with it come from broken wires, e.g. the problems with the ADF I had, the problem with the magnetic release I had.....
If I hadn´t invested so much time and money in this printer, I´d rather scrap it immediately.
SOURCE: Epson Workforce 500 paper out...still thinks it's jammed
Couldn't fix the problem, but the Epson people have agreed to send us a new unit when the tech supprt people couldn't provide a solution. We are to send the old one back. I'm glad this happened while the printer was still under warranty. Hope this doesn't happen to someone else, but we're pleased with Epson's reponse.
Posted on Apr 10, 2009
SOURCE: EPSON R300 PRINTER NOT FEEDING PAPER INTO MACHINE.
my epson r300 makes all the right noises when feeding paper but will not draw the paper through can you help
adrian
Posted on Apr 30, 2009
Epson wf 3540 paper jam in adf and the mechanical system keeps on grinding in there. Is there a video somewhere on how to open the ADF and align parts in there
The ADF just pops open from the left side of the printer. There's some finger holes and just lift up the lid. As for grinding, it may be busted unless it got a sheet of paper in the gears.
Jan 17, 2015 | Epson WorkForce WF-3540 All-in-One InkJet...
Correct setting for Epson Workforce 7520 printing on gloss paper
You need to start with photo glossy paper that's designed for an Epson printer. HP paper may not work well, and some other papers don't work either. Try some Epson paper, and that should work fine.
You can also try other paper settings, such as "transparency" or "matte paper", as the paper setting governs how much ink is laid down. I think getting the right paper is really what you need, though. Ink "puddling" is a common Epson complaint, and it's almost always the paper.
Nov 02, 2014 | Epson WorkForce WF-7520 Wide Format...
Epson wf 7525 paper not loading
Because this printer is new, the problem is not likely to be due to a worn pickup mechanism but the mechanism may not be working correctly as you have noted. Referring the problem to the printer manufacturer may get results
Jan 22, 2013 | Epson WorkForce WF-7525 colour inkjet...
I guess the pickup roller is stuck because I can't spin the green part of it. the printer has been noisy lately, with grinding noise and jamming paper often but today really got stuck completely. Can...
sorry bout the delay :(
the "grinding noise" only means that some parts/gears that is unfortunately inaccessible to users are either not lining-up or worst have loose teethes and ultimately causing the paper jams.
do you have any error from the LCD panel display? what number or code does it show?
refer to this guide:ftp://download.epson-europe.com/pub/download/289/epson28944eu.pdf#
if the issue is (obviously based on your description how the printer is performing) beyond what is shown in the guide above, go to the repair services section on this page:http://www.epson.co.uk/Printers-and-All-In-Ones/Laser/Epson-EPL-N2550/Drivers-Support#
that is one sturdy printer but sometimes paper jams initiates rollers and paper feeders mis-alignment that causes more paper jams and worsening the issue.
Jan 19, 2012 | Epson Epl-N2550dt Mono Laser Printer
I have a epson artisan 800 I'm tring to fax from the automatic feeder but it keeps making a grinding sound and then it says paper jam but paper never even went through
I took apart my artison 800 with 'paper jam' error and grinding noise. Sadly enough, it is the plastic gear attached to the stepper motor which is slipping and making the grinding noise. I tried to glue it and it worked once or twice and failed again. It is a design flaw and Epson should repair this for free if they are honest about this problem. Ir is not a user-caused problem.
Jan 02, 2010 | Epson Artisan 800 All-In-One InkJet...
Paper Jam...grinding noise
The print head lock is probably not retracting. Look for the white plastic block that pokes through from the paper feed side just in front of the head. Push it in with your finger and move the head to the middle by hand. Now turn the machine on. Then turn it off using the correct method. Then turn it on once more. If it starts grinding again, you screwed the feed mechanism when tugged out the jammed paper (probably pulled it backward through the feed instead of making it go forward and out the correct exit). If this is the case, you may as well bin it. If it in warranty, you can try to get a claim for repair.
Jun 15, 2008 | Epson Stylus CX3200 All-In-One InkJet...
There is two sensor one paper in and paper out any one or both
Sensor not working find sensor and check it for physically working or not
Feb 25, 2008 | Epson ACULASER CX11NF All-In-One Printer
Paper transport does not work; terrible grinding noise
I took mine apart from the back and put it back together and it worked. It is probably due to moving it and the bottom paper tray alignment gets out of whack. I inspected all of the gear train and didn't find any worn or missing teeth. I suspect a paper jam started it and the user turned the printer around to open the back door. Since the handles are on the printer the tray doesn't move with it which allows it to separate and possibly jam a pickup drive gear.
Nov 08, 2007 | Dell 3000cn Color Laser Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
432 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
