Magicolor 1690mf fax tx error 0088 - Office Equipment & Supplies
SmartAviator
  • 449 Answers
SOURCE: Manual for koniccca minolta magicolor 1690mf
Try searching yoyr required manual at the manufecturer's website or http://www.devicemanuals.com . They have a large databse of manuals. (ehteshamhusain@gmail.com)
Posted on Jul 23, 2009
SOURCE: how do i fix the error message MACHINE TROUBLE
1. Main switch is tuned ON.
2. Press the following keys in this order
2 -> 6 -> 2 -> 7 ->3
3. Main switch is tuned OFF/ON
Posted on May 11, 2010
SOURCE: I have a magicolor 1690mf
Default password for Konica Minolta Magicolor 1690MF is sysAdmin. Useful page: http://www.phenoelit-us.org/dpl/index.php?page=25&svendor=&smodel=&sversion=&perpage=50
Posted on Apr 22, 2011
  • 1739 Answers
SOURCE: please i want to know if konica minolta magicolor
The Konica Magicolor 1690MF Printer/Copier/Scanner is connected with an Ethernet Cable or USB Cable. It is not equipped to operate as a wirleless printer. It has a 10Base-T/100Base-TX Ethernet interface port and a USB Revision 2.0 High-Speed compliant port.
To do two-sided printing you must have the duplex (double-sided) option installed. This also requires either Tray 2 or the Attachment to be installed underneath your machine. Tray 2 is the optional lower feeder unit which increases capcity of your machine to 500 pages. The Attachment comes with the Duplex Unit.
Only Letter and A4 plain paper (16-20 lb bond) can be autoduplexed. With the duplex accessory installed you can do duplex or double-sided printing automatically.
From within Printer Preferences select Two-side Printing > Automatic. Shoud have choices of Off, Manual or Automatic. Within the Layout Tab for your work you may also be able to specify duplex (double-sided).
Should you have continued difficulty, please reply and advi e if the duplex option is installed and with which software and operating sysytem you are using.
Thank you for using FixYa!
Posted on Sep 20, 2011
nonontech
  • 4737 Answers
SOURCE: I have no driver and can't load a driver for My
Open this LINK, scroll down the page to the section called "Mac OSX 10.6.X - Drivers" and download your drivers. Hope this helps. Good Luck.
Thanks for using FixYa.
Posted on Sep 21, 2011
Ow do i fix the error message MACHINE TROUBLE SERVICE CALL (0310) on my konica...
replace the print head. That's the part that houses the LASER. try this site for the part
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
if not try local Konica Minolta dealer
Sep 28, 2014 | Konica Minolta magicolor 1690MF All-In-One...
Error code 133C
Modem option is not working. Have a tech look at it. The FAX board might be bad, check you phone line also call ATT.
Jun 12, 2014 | Konica Minolta magicolor 1690MF All-In-One...
Konica Minolta Magicolor 7450 II laser error Y
replace the printhead which house the LASER for the yellow image unit
Feb 17, 2014 | Konica Minolta magicolor 1690MF All-In-One...
0092 error
CAUSE: The transfer belt is not rotating correctly inside of the Image Unit.
SOLUTION: Check the PRCB connector for proper connection and correct as necessary. Also, check Belt Positioning Sensor (PS6). Replace Image Unit (p/n A0VU011). The PRCB may also need to be replaced. (p/n A034 H001 06 for magicolor 1650EN or p/n A034 H009 07 for magicolor 1680MF/1690MF)
SPECIAL NOTE: Solution contribution by SSD Printer Support
ID No.
TABP1000085EN
FROM KMBS SSD
Jun 20, 2013 | Konica Minolta magicolor 1690MF All-In-One...
I have a konica minolta 1690mf. paper feed problem error 094
Transfer roller issue. the sponge looking roller across from the transfer belt.
Jun 26, 2012 | Konica Minolta magicolor 1690MF All-In-One...
Konica minolta 1690mf process error belt clear by cover
KONICA MINOLTA 1690MF ERROR:
process error - belt (clear by cover)
SOLUTION: Open and close the scanner unit. Reseat the Image Unit and cycle the power to the machine. If the error persists and the machine is covered by warranty, a printer exchange is recommended.
KONICA MINOLTA SUPPORT PAGE:
https://kb.mykonicaminolta.com/selfservice_bus_anon/microsites/search.do?cmd=displayKC&docType=kc&externalId=TAD-doctad227704html0&sliceId=&docTypeID=DT_TAD_1_1&dialogID=10562139&stateId=1%200%2010556672
Feb 27, 2012 | Konica Minolta magicolor 1690MF All-In-One...
jasbo
jasbo
