Question about Breville The Scraper Mixer - BEM410
My bem 410 makes a big and funny noise when I turn it on and I don't know why
When I turn the machine on it makes a buzzing noise, (not loud but it might be like an alarm).
If the mixer is still running and making the buzzing noise one of the electrical contactors is making the noise and should be replaced.
If the mixer is not running and just making a buzzing noise it can be because off single phasing, check the incoming supply to the mixer and make shore you get the right voltage to the motor (test on motor connection terminals)if the voltage to the motor is right the motor might be faulty
Jul 29, 2015 | Hobart 60 Qt. Mixer
Kg25h0x stand mixer
Sadly the only help we can give is SUGGESTING you contact Kitchenaide and have them assist you
Oct 17, 2017 | KitchenAid Professional Heavy Duty Series...
Mixer making a grinding noise when turned on
It sounds like it is the worm follower gear, it is the most common gear to wear out as it takes the most pressure but it could also be one of the three bearings that are in there also, or it could be the worm gear, you will just have to open it up to look for wear. there are several really good videos on you tube that will show you how. it really is an easy fix if you are a good handy person, hope that helps
Feb 13, 2013 | KitchenAid Professional Heavy Duty Series...
We have a K45SS mixer problem. When it is on the lowest setting it hums and the beaters barely turn. The next setting up has a noise but the higher speed settings work just fine. What is the problem?
the lower setting is for stirring. this is a high quality machine that is made to take a beating. you are just hearing the motor wind up. think of it like a jet engine starting, its made to run its smoothest at high rpm's, so it sounds funny at low rpm's but nothing is wrong with it.
Dec 20, 2011 | KitchenAid K45SS Classic Stand Mixer
My Kitchen Aid Pro5 squeals when it's running. I may have overheated it when mixing bread dough. It seems to be running okay. It just makes a very high-pitched noise now. What can I do to fix this?
Get a Copy of the Repair Part List of your model from Kitchenaid.com.
Most likely it is the Worm Gear (17) grinding at low speed the Worm Gear Follower.(19)
You don't have to replace it now, but it is best to open the Transmission Housing and
inspect all the gears conditions. Clear all the grease to expose them. The Bevel
Gear (21) sits right on top of the Worm Gear Follower. (See Repair Part List)
If its teeth look sharp and all metal shiny, then that is the source of your noises.
Eventually, all the teeth will be chewed away and the planetary assembly will stop turning.
Jul 01, 2011 | KitchenAid 450 Watts KM25G0XWH Stand Mixer
How do you remove the cutting blade on hobart model 410
The disc in the middle of the blade unscrews. A glancing blow with a rubber mallet will sometimes break it loose.
May 31, 2010 | Hobart Food Mixers
My classic k45ss leaks oil which drips from the verticle shaft, and my wife says it is making a "funny noise". Maybe it is low on oil, but I turned it on its side to find the model number, and it leaked...
Firstly I would take the head apart to find out what has failed. The oil you see should be a thick grease. Normally it is thick enough not to leak in this way. Has it been repaired and the wrong grease used? If it is making a funny noise it could be that one of the gears has failed. Most parts are easily available. Have a look at the parts list at:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212369.pdf
Jan 24, 2010 | KitchenAid K45SS Classic Stand Mixer
My epicurean mixer (5quart) stand mixer sounds loud but isn't overheating is that abnormal or if so what should I do
KAY – You don’t mention how long you’ve had your mixer or how intensely you use it, which would be helpful in assessing your question. Our first KA mixer we got in May 1989, seemed ‘whisper’ quiet compared to the replacement 6 qt Pro mixer our children got SWMBO for Christmas in 2006. The new mixer was so noisy that my wife called Kitchenaid to complain. The wonderful KA ‘Helpers’ explained that KA had changed to making all metal gears in their mixer transmissions as opposed to having one plastic gear (intended to fail instead of burning the motor out). That change from plastic to metal is then main reason your KA mixer seems to be much louder. You should be able to judge if your noise level has increased or stays the same during normal use. Since you stated that you don’t notice any overheating of the mixer I would say that the noise level is appropriate and wouldn’t be overly concerned at this point. That being said, if you hear a change in the noise level – usually louder, it could be indicative of mechanical issues in the transmission, which is what finally happened our mixer. One of the gear teeth broke and the agitator froze up. But that is another story…
I hope this helps. Good luck! Howard – Burke, VA
If this solution has helped you, please rate it, thanks!.hslincoln
Nov 27, 2009 | KitchenAid KT2651X Epicurean Stand Mixer
Washer turns on but dont spin also funny noise by the motor
hopefully you have a whirlpool direct-drive, you need to remove washer housing, remove mtr 2 clips hold it in there is a coupling that connects mtr to trans replace that and you should be all set dont forget to vote thanks, monomoy
Aug 03, 2009 | Kenmore KSM100 Stand Mixer
Breville The Scraper Mixer - BEM410 Logo
Top Breville Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Breville Food Mixer Expert? Answer questions, earn points and help others
