Question about OKI C9300 Led Printer
Error number 172
Printer just went bump after printing 30 pages and then on the Led window . . . Service Call . . . 172:Fatal Error. I have try nothing to resolve problem because I just had the mechanics replace the transfer belt. Can the thermistor (I think it is a thermostat) be replaced? My Fuser Unit has maybe 1,000 sheets through it & the life cycle is 80,000. Does any know what part is to be replaced? Thanks
  • sharkbait22 Apr 27, 2009
    Is there any repair that can be made to the fuser?
    I think it is a fuse or (fuseable link) that blows if paper is ever jammed at the fuser unit.
    The fuser unit it's self is in very good shape, barely used.
    What do they replace when a fuser unit is refurbished?
  • sharkbait22 Apr 28, 2009
    Can you please be more specific. Where do I locate the thermistor in the fuser.
    and where can I purchase a replacement part?
    Or maybe where do I fine an exploded view of the fuser unit?
    Thanks
  • OKI Master
  • 19,396 Answers
  • 483 Answers
The answer to the question you asked would be : When the fuser wears on any copier they replace certain parts some of which are, the upper heat roller, lower heat roller, bearings, picker fingers, thermistors & drive gears.
However, in your case its the thermistor on on the fuser unit is damaged.
If we get that replaced.. this should work for you.
Thanks
Fame !
Posted on Apr 27, 2009
  • Sid
    Sid Apr 28, 2009
    For that i need the model/make & the model number. that is the only way i can get those stats.
    My answer was specific to the technical question that you had asked, please get the other details for more support.
    Thanks
    Fame !
  • 854 Answers
This is the problem with the Thermal fuser unit. You need to replace it.
Posted on Apr 24, 2009
  • redhaze89
    redhaze89 Apr 27, 2009
    You can pull out the fuser assembly. To check if what specific part will be replaced. Specific parts on the fuser such as the "heating element", ( A bulb inside the fuser roller) might be busted, Gears that jump off ever turn on the fuser assembly, Teflon sheets or the tube might be rip off. This parts should be tested by a qualified technician to pin-point the specific part that is defective on the Fuser assembly.
    You can use refurbished Fuser Assembly as long as it fits your printer, but the only thing about refurbished is that you can't avail for warranty. I myself use refurbished parts,...so far so good....
    Hope this info helps
OKI C330dn Call Service fatal Error:980
That particular error indicates a fuser failure. Try turning off the printer and re-seating the fuser. If this does not clear the message then the fuser needs to be replaced. With such a low number of prints warranty should cover it.
Aug 29, 2014 | Oki Electric Industry C330dn Led Card...
The orange lights are flashing, is there something wrong?
Try:
1 Resolution may vary based on printer driver setting. Color ink droplets can be placed with a horizontal pitch of 1/4800 inch at minimum.
2 PPM print speeds are based on the highest speed printer driver mode. Photo print speeds are based on the default mode driver setting using Canon Photo Paper Plus Glossy paper. Print speeds will vary depending on system configuration, interface, software, document complexity, print mode, types of paper used and page coverage. CPM copy speeds based on fast mode setting using plain paper. Copy speeds may vary based on document complexity, copy mode, page coverage and number of copies.
3 USB 2.0 Hi-Speed requires Windows XP, 2000 or Mac OS X operating systems. For Windows 98, Me and Mac OS X v.10.2 to 10.2.6 operating systems, the printer will operate at USB 1.1 specifications.
Oct 22, 2010 | Canon PIXMA MP150 All-In-One InkJet...
I have an OKI 5650 printer and am getting a 172: Fatal Error - how do I fix this?
Abnormal temperature
detected by
fuser thermistor
(high-temp or low
temp.)
Turn power ON again.
Replace fuser unit.
Feb 12, 2010 | OKI C9300 Led Printer
Service Call 172 Fatal Error
Hi stuart34:
Here is your problem.
Service Call
172: Error
176: Error
High temperature
error detected at
Thermistor.
1) Is the error message displayed?
2) Does the error repeat?
Yes
Yes
Turn off/on the printer.
Replace the Thermistor and turn off the
1 Upper roller 2 Lower roller 1
b
Thermostat Thermostat
Heater Between pins a and b:
Between pins c and d: 231.4kω
Between pins e and f: 231.4kω (at 25°C)
Between pins c and d: 0ω or open
Fuser Unit
a
b
Heater
e
f
Thermistor
c
d
Fuse
e
f
Thermistor
c
d
printer. Leave it for 30 min.
The Thermistors are located in the fuser assembly.
Hope this helps
May 29, 2009 | OKI C9300hdn Led Printer
OKI C5600 printer is printing Blank pages
you looking at 3 posibles one is the scanner may need to be replace or the low voltage power supply or you looking at a posible drum problem
Nov 22, 2008 | Ricoh Aficio 250 Copier
Fatal Error
Did you try cleaning the led heads
Apr 02, 2008 | OKI C9600hdn Led Printer
Fatal error 172
From OKI error list:
Error 172 - Upper Heater Temp State: High
Heat Roller Thermistor indicates high temp
Solution:
Turn off printer, let cool down.
If problem still exists seek service
Mar 07, 2008 | OKI C5300n Led Printer
Service Call: 173: Fatal Error
That is a fuser erron code. Abnormal temperature. You will need to replace the fuser. Sometimes I have sen a buildup of toner on the thermistor. If you can get to it. You can try to clean the toner off. Be careful. Very hot.
Aug 10, 2007 | OKI C5150n Led Printer
Error number 172
the problem is on the fuser unit, ther thermistor on it is damaged.
Jun 02, 2006 | OKI C9300 Led Printer
OKI C9300 Led Printer Logo
121 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
