Question about LG DLG5988 Gas Dryer
I have a lg dryer model dlg2532w gas dryer it does get warm
I set the clothes in and they come out as wet as they went in the dryer still tumbles through its entire cycle before it stops the repair man came in about a month ago and just reset it can you let me know what this process is thanks rosajt
  • 2 more comments
  • Anonymous Dec 24, 2007
    where is the reset button on lg gas front load dryer
  • Anonymous Oct 07, 2008
    I have the same problem with my same model dryer. I had a guy come out and he did something to get the heat back on but of course he didn't tell me what he did. Now 1 year later it's happened again. The dryer is only 3 yrs. old. Please help !!! Got Wet Clothes !!!
  • jdemas Dec 02, 2008
    I spoke to a service tech and there are two thermal sensors located on the side of the combustion chamber. One is on the top right and the other on the lower left. If either of these sensors fails the dryer will run but no gas will flow and the dryer won't get warm. The sensor on the lower left has a reset button on top. If it overheats and trips you can simply push the button and reset it. However, I was told that once it opens it will probably happen again and it should be replaced. It is recommended that both sensors be replaced as a set. The part numbers are 6931EL300CC and 6931EL3003F. The parts cost about $15 each.
  • ahammering Feb 02, 2009
    My LG dryer in not warming? How do I reset the dryer? DLG2532w
I have had this same model for about 3 years. Finally, I have solved the problem. Venting. My dryer is in the basement and must push the air out about 8' thru two elbows. My vent was a 4" metal vent.
This dryer works by drawing the flame through a flame tube. The flame tube has two sensors at the gas valve end for protection. If the draw on the flame is insufficient, the flame is too short and too wide in the tube. Wide enough to activate the safety sensors. 4" vent pipe gives too much resistence to air flow and therefore reduces the suction or draw on the flame.
If this dryer was installed on an outside wall on a main floor and the vent pipe was a short run that went directly outside, there would not be an issue. I am willing to bet most of you on this site have an installation in the basement with 4" vent or on the main floor with a long run of 4" vent.
Basically, the heat in my dryer was being controlled by the safety switches on the flame tube. This provided a 10 second blast of heat and then about a 4-5 minute reset time before it would try again. My clothes were being air dryed!
I installed 6" metal pipe.
I am not a technician or qualified to answer this question. Good luck.
Posted on Mar 22, 2009
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 77 Answers
If the cloths are warm and wet the problem is not with the dryer but in the venting. check the air flow at the end of the line (where the exhaust leaves the building) if the air baffels are not fully opening when the drier is on there is probably an issue with the venting. remember to tape up the venting joints after inspecting it because it is also the exhaust for the gas. hope this helps.
Posted on Sep 25, 2007
Kenmore Gas Dryer does not dry clothes.
If this is the electric version then after 15 years you probably need a new heating element, they are not difficult to install and are not terribly expensive as a DIY project.
Jan 12, 2013 | Dryers
Tumbles but does not dry
When you put your wet cloths in the dryer close the door. You should then turn on the dry cycle you wish, not the fluff option as there will be only air and gas dryer will not heat the cloths. Wait 30 ~ seconds after the dryer is turned on and listen for the gas to ignite and begin warming and drying the cloths. If you hear no bump sound like the ignition of the gas, then you have an ignition issue. It will require replacing the ignitor. All the best and good luck. Hope this helped.
Oct 02, 2012 | Maytag Neptune MDG5500AW Gas Dryer
Put the cloths in the dryer like usuall and waited for peep to let me know its dry. but when i heard the peep assumed the cloths will be dry, the cloths were just like i got out of the washer, wet. it is...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
Feb 02, 2011 | LG DLGX8388 Gas Dryer
My Kenmore Elite Gas Dryer in Refresh mode the cloth comes out wet.
I think the refresh mode is a no heat tumble only setting... just to fluff your clothing...
if they were wet they will not dry on that setting...
Aug 27, 2010 | Kenmore Elite Oasis 7808 Gas Dryer
Dryer is not drying clothes.
well im not going to look up the model # to see if its gas or electric,but check the exhaust tube for blockages
Apr 21, 2009 | GE DBSR453EBWW Electric Dryer
Dryer puts out heat, but clothes are still wet
There may be a clog underneath the lint trap or the exhaust vent may be clogged, if either fails try changing temperature knob to a different setting.
Mar 09, 2009 | LG DLE8377 Dryer
DLG2532W - LG Gas Dryer - Not spinning/working
Feb 22, 2008 | Dryers
LG DLG2532W Gas dryer problem
dryer working and heating properly, when cycle complete all my clothes smell like gas though. Any suggestion
Nov 11, 2007 | LG DLE2532W Electric Dryer
Connect Gas Supply Pipe
(Gas Dryer ONLY)
For further assistance, refer to section on Gas
1. Make certain your dryer is equipped for use with the
type of gas in your laundry room. Dryer is equipped at
the factory for Natural Gas with a 3/8” N.P.T. gas
2. Remove the shipping cap from the gas connection at
the rear of the dryer. Make sure you do not damage the
pipe thread when removing the cap.
3. Connect to gas supply pipe using a new flexible
stainless steel connector.
4. Tighten all connections securely. Turn on gas and
check all pipe connections (internal & external) for
gas leaks with a non-corrosive leak detection fluid.
5. For L.P. (Liquefied Petroleum) gas connection, refer
to section on Gas Requirements.
Oct 15, 2007 | Kenmore 63932 Electric Dryer
LG DLG5988 Gas Dryer Logo
935 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Dryer Expert? Answer questions, earn points and help others
