Question about Belkin (F5D7230-4-SN) Router
I have been able to connect to this network in the past, but been having problems in the last few weeks. I have tried many things but nothing seems to work. What should I do?
My parents have a wireless network set up, in the past I have been able to connect to this wireless network when I have been home. But in the past couple weeks I have had trouble connecting and have tried numerous things. What should I do?
  • Anonymous Apr 26, 2009
    My problem is the same as molsen8's and the same belkin router
osborne382
  • 306 Answers
SOURCE: how to get a third computer to work on my wireless network
is the adapter connected to the router? are you using wep? is the firewall disabled?
Posted on Nov 11, 2007
  • 13 Answers
SOURCE: wireless connection works and then disconnects itself
look for a program on the web called Net Stumbler
It should be here http://www.stumbler.net/
That will show the signal level from your router.
I have seen this before and it could be several different problems
1. Someone else on your channel
2. Burned out ant or output section in the router
3. Broken Ant wire in laptop
Hope this helps
Posted on Jan 02, 2008
SOURCE: Can't connect wirelessly to Belkin Router
hi, I have tried all the different settings on the router and as far as I am aware there shouldn't be anything interfering with the signal as we have nothing else that is wireless. I just can't figure out what It may be lol!
Posted on Jun 21, 2008
  • 8 Answers
SOURCE: GotomyPC Intermittent connection
had same prob. 3 wired an 1 wireless . wireless would not conn. an others lose connection . after cable upgrade it was in router upgrade changed settings in router i had to call maker of comps an get them to reset ip adds took almost 3 hours to get them all working again they will do a remote access help by useing your ip threw your internet company hope this helps
Posted on Oct 11, 2008
compucure
  • 61 Answers
SOURCE: Belkin N1 wireless network not working
It might be an idea to upgrade the firmware which can be downloaded from manufacturers' website
Posted on Mar 20, 2009
I have a 98 Venture with 180K on it. The past few months it has been acting up. I'm constantly getting a check engine light (cylinder 3 misfire). Changed out all the plugs. Ran great for a few days and...
well it sounds like you have an electrical problem as in a ground wire or connection. as far as the misfire on three only,have the coil checked and check that intake gasket around that cylinder with carb cleaner for air leak
Feb 03, 2011 | 1998 Chevrolet Venture Cargo
My Brother MFC-5890CN Printer wont print.It does scan.I have tried re-installing the drives but when it gets to the last section the box just asks for the machine to be connected. I have also changed the...
I can't print nothing from my PC or trough network, but still I can Scan, Fax, etc. I'm using Windows 7 Home Basic, I already installed the driver ( "Connection via USB Cable" ) and I have plenty enough ink ... I checked the Settings, Test Page is OK, but nothing else want to be pinted. I had a problem with my MFC 5890 in the very begining ( nearly 2 weeks ago ) so I had to unplug and than plug in the USB Cable and in this situation the printing of my "pending documents" was successful, but from few days ago there is no such a thing that could make it print. Please help
Dec 31, 2010 | Brother MFC-5890CN All-In-One InkJet...
Advent 4213 netbook not connecting to wireless network
Have you entered the security details regarding your network connection into your new netbook.
Sounds like the problem.
Detect the network and enter the security key (WEP;WAP etc) and should work
Jul 11, 2009 | Computers & Internet
My laptop suddenly cannot connect to the router.
It comes down to a few things with routers and wireless connections:
1. If you have been dropping the signal over the past few weeks try doing a test on the wireless network connection via the diagnostic tool within the specific wireless connection.
2. You may have gotten a bad update to the wireless card. Try uninstalling it and then reinstalling it.
3. Try deleting the wireless connection for your router and then make 'a new' wireless connection.
Oct 15, 2008 | Belkin (F5D7230-4) Router (587009)
No wireless signal
Most home router has an IP address of 192.168.1.1 or 192.168.2.1. If you dad's laptop can connect to the router just fine, then it's a problem with your linux laptop. Can you see other wireless networks on your laptop?
Jul 23, 2008 | Belkin (F5D7231-4) Wireless Router
have you customized the wireless settings of you router (e.g. ssid, wireless channel, wireless security)? if not, try to change your router's ssid or the wireless channel. it could be that some wireless devices are interfering with your signal.
hope this'll help you.
ciao!
Jun 20, 2008 | Belkin (F5D5231-4) Router
Laptop WILL NOT BOOT
You seem to have two (2) problems:
1. wireless connection;
2. powering up.
On powering up, pls try:
a. charge the batteries at least overnight;
b. run the laptop with the AC adapter only and the battery removed;
c. do "b" but delay powering on the laptop for a couple of minutes.
On the wireless, pls try:
i. determine if a WEP or WPA security key is being used;
ii. check your router configurations;
iii. do a reset of your router (this would of course would set the router to default/factory values. This would be a last recourse since it is possible you will loose all Internet connectivity. Better to save your router configurations or copy them down somewhere.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 07, 2008 | Sony VAIO PCG-K35 Notebook
I can't get my new Vista computer to connect to my wireless network
I experienced a similar problem with a Vista laptop a few weeks ago. There were no apparent problems, so I uninstalled the wireless network adapter from the Windows "device manager" and then let it automatically reinstall the wireless adapter when it rebooted. The local wireless network appeared about 5 minutes after the reboot and has been working ever since.
If that doesn't help, try removing the Linksys software from your computer and try the network adapter remove/reinstall again.
Jan 10, 2008 | Linksys Wireless-G Broadband Router
Psp not recognising game discs
The operating system is in the flasho and flash1 you wud not see it by merely connecting usb. If its not a lens problem or board, den I believe u shud check the umds because they are very sensitive and get scratched easily
Dec 13, 2007 | Sony PlayStation Portable (PSP) Console
Sony
Check the disc is not damaged or got finger prints on...
connect the system to a wireless network to get the latest software updates.
Dec 12, 2007 | Sony PlayStation Portable (PSP) Console
Belkin (F5D7230-4-SN) Router Logo
63 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
