Question about XRS 979 15 Band Ultra Performance Digital Radar/Laser Detector with Cool Blue ExtremeBright DataGrafix Display, XRS979
Need to know what the codes mean - XRS 979 15 Band Ultra Performance Digital Radar/Laser Detector with Cool Blue ExtremeBright DataGrafix Display, XRS979
Code U11OE
Google the code
OBD U110E
Open Can Bus & ambient temp sensor issue
Sep 01, 2013 | Chrysler Pacifica Cars & Trucks
I have a 88 Dodge caravan, I need to know what the code means when you turn the key on and off three times.1-2,2-55,55-55.I useto have a manual.
Well there are no single digit codes.
Code 12 means the battery power has been lost within the past 50 key starts.
Code 55 means you have reached the end of the code test.
Apr 12, 2013 | Cars & Trucks
I need to reset my code-what can I do?
WHAT DO YOU NEED TO DO RESET THE CODE OR TRYING TO FIND OUT WHAT IT MEANS LET ME KNOW WISH CODE IT IS AND ILL TELL YOU WHAT IT MEANS OK IFYOU JUST WHAT TO RESET IT JUST GO TO YOUR BATTERY AND DISCONECT THE GROUND FOR COUPLE OF MINUTES RECONECT IT BACK AND THAT WILL RESET THE CODES ON YOUR CAR OK
Nov 19, 2012 | 2001 Ford Explorer Sport
I got a p0303 code need to know what is it mean
This code means that there is/ was a misfire detected in the #3 cylinder, if you wish to trouble shoot the problem your self, I will need to know what kind of ignition system you have. ie. coil over plug or points.
Jul 05, 2011 | 2002 Daewoo Leganza
I need to know what error code "E1" means and what
Thank you for contacting Fixya.com.
The "E1" error code means the thermistor is open but it could be also a broken wire, loose connections at the teamster and/or the control board and a bad control board.
Please get back to us if you have any further query.
Have a nice day.
Dec 02, 2010 | Kenmore Dryers
IT IS SHOWING CODE FI AND F3 I NEED TO KNOW WHAT THE TWO CODES MEAN.
You need to provide make and model in order to know what the codes mean. Manufacturers use different codes
Oct 28, 2009 | Kitchen Ranges
The meaning of codes E00315-00B?Any bodies knows?
that is the code for a fualty resolution switching board chek all connections on the main controller
Oct 13, 2009 | Office Equipment & Supplies
I need to know what a code means for a 1996 ford
Transmission Mechanical Failure - First and Reverse
Mar 11, 2009 | 1996 Ford Windstar
Need to know what trouble codes 52 and 15 mean
15 -vehicle speed sensor 52 oxygen sensor- rich mixture.
Jan 11, 2009 | Dodge Ram 150 Cars & Trucks
XRS 979 15 Band Ultra Performance Digital Radar/Laser Detector with Cool Blue ExtremeBright DataGrafix Display, XRS979 Logo
27 people viewed this question
Top Cobra Vehicle Parts & Accessories Experts
Jason
Steve
Are you a Cobra Vehicle Part and Accessory Expert? Answer questions, earn points and help others
