Question about E-Machines Computers & Internet
D50SH-12C - E-Machines Computers & Internet
How to fix my hp calculator 12c numbers display is faint?
There is no contrast adjustment possible with the 12c. Most of the time, faint displays are due to weak batteries or poor contact with the battery or batteries.
Jun 26, 2014 | HP 12c Calculator
How do you clear RNP for an HP 12C
I take it you mean a 12C Platinum.
Press f ALG. ALG is the f-shifted function of the EEX key, just above the double-size ENTER key. This will switch the 12C Platinum from RPN mode to Algebraic mode, and ALG indicator will light up instead of the RPN indicator.
To switch back to RPN, press f RPN. RPN is the f-shifted function of the CHS key just above the EEX key.
Apr 23, 2014 | HP 12c Calculator
Get out of rpn mode on hp 12c
On a 12C Platinum, press f [ALG]
On a non-Platinum you're stuck. It has only the RPN mode.
Jan 15, 2013 | HP 12c Calculator
How do i convert a a decimal to fraction in HP 12C
Sorry, but the 12C doesn't have a fraction mode.
Aug 17, 2012 | HP 12c Calculator
Do you have advice in calculator choice between HP 12 c and the TI BA II Plus Professional Financial Calculator? Assuming that I get proficient with RPN (which I'm learning now); is one faster than the...
The 12C is more expensive and more powerful than the BAII+Pro. The HP is also programmable, which the TI isn't. Starting from scratch (assuming you've never used a calculator before---a somewhat unreasonable assumption) the TI might be easier to learn, at least initially. But after a certain point, the HP will leave the TI behind. The HP is faster and more capable.
There are at least three different versions of the 12C available. There's the original 12C, the 12C Platinum, and the current 12C. The only way to tell the difference between the two non-Platinums is to look at the battery compartment---the original uses three button cells while the newer uses two coin cells. The newer one is MUCH faster. The Platinum, however, can use RPN or algebraic.
Unless your choice is limited to the 12C or the BAII (by the requirement of an exam, perhaps), you might want to look at the HP 20B and the HP 30B. Programmability aside, they're even more powerful and easier to use and faster than the 12C, and the 30B is also programmable.
There are other considerations, of course. Factors such as the feel of the keyboard, the 12C's landscape orientation as opposed to the others' portrait orientation, etc, are all matters of personal preference.
Disclaimer: I own multiple HP and multiple TI calculators. I tend to use HP calculators for calculating, while I use TI calculators to answer questions here at FixYa.
Mar 23, 2011 | HP 12c Calculator
HOW DO I GET OFF RPN
The HP 12c is a purely RPN calculator; it does not have an algebraic mode.
To switch the HP 12c Platinum to algebraic, press f [ALG].
Aug 23, 2010 | HP 12c Calculator
Manual HP 12C
Here is the link to the pdf manual for your HP12C.
Jun 16, 2010 | HP 12c Calculator
How do I get the 12C off the "equal" sign configuration. It's not computing by reverse polish notation.
I assume we're dealing with a 12C Platinum, since a 12C doesn't have a +"equal" sign configuration_.
Press f then RPN.
Feb 24, 2010 | HP 12c Calculator
My equal sign does not function.
Are we dealing with a 12C Platinum instead of a 12C?
On a 12C Platinum in ALG mode, you don't use the ENTER key at all, but the = key.
Feb 08, 2010 | HP 12c Calculator
How can i tell the difference b/w hp12c and hp12p. i bought a hp12p from ebay(it's a stupid decision, I know!) and when i solving for IRR, i felt its running quite slow. I think the guy sold me the hp12P...
I couldn't find any reference to a HP calculator model 12p.
There is a HP 12c financial calculator and a 12c Platinum financial calculator.
Check both models (for images, specifications, functions, user guides, etc.) :
HP 12c Financial Calculator
HP 12c Platinum Financial Calculator
Aug 06, 2009 | HP 12c Calculator
Computers & Internet Logo
23 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
